Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
61 registered (4WD, cb4017, clinebarger, boulderdentist, CKN, 3 invisible), 1041 Guests and 32 Spiders online.
65303 Members
67 Forums
285886 Topics
Page 1 of 2 1 2 >
#4475328 - 07/31/17 08:51 AM oops lost manual...
Chester11 Offline
Loc: PA
Hi Guys:
I have a few different 2 cycle engines (2 blowers, weed eater, tiller).
Has anyone noticed that some manufacturers do not put the oil mix on the device? First world problem, but this makes me nuts because I have to hunt down the manual every season - some of which I have lost in various moves.
For example - I have been running 50:1 through a Poulan Pro blower. But - I noticed a premix bottle I saved shows 40:1 for Poulan devices. (Poulan website also says 40:1, but Lowes website says 50:1 for this model).
Am I going to kill an engine running 50:1?
#4475340 - 07/31/17 09:00 AM Re: oops lost manual... [Re: Chester11]
HerrStig Offline
Loc: Boston, MA
Originally Posted By: Chester11
Hi Guys:
Write the mix on the unit with a marker. 50 to 1 with a good synthetic 2 cycle oil should be OK. I run a weed whacker and a little tiller on 50 to 1.
#4475342 - 07/31/17 09:01 AM Re: oops lost manual... [Re: Chester11]
jeepman3071 Offline
Loc: Storrs, Connecticut
In my experience, the mix ratio has more to do with the quality of the oil used.
I have a few older two stroke machines that say 40:1 or even 32:1. The oil quality back when these machines were made was not as good as today. I run 50:1 in them and they run perfect. I even had one of the chainsaws apart to replace a seal and it looked great inside.
I honestly think some of the manufacturers just keep the same recommendation in the manual for years without changing it. I remember seeing a fairly new snowblower from a big box store recommending SAE 20. I'm not sure if they even make that anymore.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4475358 - 07/31/17 09:16 AM Re: oops lost manual... [Re: jeepman3071]
Chester11 Offline
Loc: PA
This makes sense - I hate paying for premix, but the smoke is a lot lower. A 40:1 can I mixed myself smokes out the whole yard - I'm sure it was the stuff that came with the Kmart weedwacker.
What is a good quality oil? Everything I see appears to be a private brand.
#4475364 - 07/31/17 09:22 AM Re: oops lost manual... [Re: Chester11]
Kamele0N Offline
Loc: Slovenia
Anything that is API TC...JASO FD is good enough for 1:50 in any OPE
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4475370 - 07/31/17 09:27 AM Re: oops lost manual... [Re: Chester11]
Panzerman Offline
Loc: Port Orange, Florida
I usually just run 32:1 in everything because I am running Lawnboy mowers but it runs fine in the Echo too that calls for 50:1. If your smoke sensitive just run 40:1 in everything. It won't hurt.
I found more oil is better.
I miss the days of 16:1 and 20:1.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4475377 - 07/31/17 09:34 AM Re: oops lost manual... [Re: Chester11]
motor_oil_madman Offline
Loc: Houston, Texas
I buy my 2 stroke oil by the gallon and use the little measuring cup they give you with it. 2.6oz per gallon is 50:1 and I usually just put in 3oz
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4475387 - 07/31/17 09:46 AM Re: oops lost manual... [Re: Chester11]
jeepman3071 Offline
I don't use too much of it, so I just buy the semi-synthetic Husqvarna stuff from Amazon. They usually sell a case with 6 or 9 pre-measured bottles.
I've also used the Briggs and Stratton 2 stroke oil. Any name brand will be fine. I tend to avoid the no name brands like "leaf blower mix" or something from WalMart/Sears.
#4475483 - 07/31/17 11:36 AM Re: oops lost manual... [Re: Chester11]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
There isn't much difference between 40:1 and 50:1 so I would not panic if I got it wrong once or twice, but aside from the mix not being optimal you can always default to a stronger mix of oil to fuel. So running 40:1 in a machine that is supposed to have 50:1 isn't going to cause much problems.
I also have a DYMO labelmaker that I use for all kinds of stuff, but if you wanted, you could just create a label and stick it on the device if you wanted.
There are a number of labelmakers available, BROTHER also makes some, for example, but I like the DYMOs ... get one that uses D1 cartridges (eg Labelmaker 160; $14 on Amazon, although the better deal is one packaged with two tape cartridges), or if you are serious the RHINOs are the way to go, although they are not cheap.
The RHINOs do cable marking and although the appropriate cartridges are expensive, you can mark shrink tubing for cable wiring with them. Handy if you do any electrical work on automotive applications.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4475618 - 07/31/17 01:42 PM Re: oops lost manual... [Re: Johnny2Bad]
Chester11 Offline
Loc: PA
Thanks - been looking for a label maker for a bit, just have not pulled the trigger. For $14 I'll pick one up.
#4475695 - 07/31/17 03:10 PM Re: oops lost manual... [Re: motor_oil_madman]
Linctex Offline
Loc: Waco, TX
Pretty much the same here.
I pay no attention to what the sicker on the equipment says, and they ALL get the same premix.
#4475696 - 07/31/17 03:11 PM Re: oops lost manual... [Re: Johnny2Bad]
Linctex Offline
Loc: Waco, TX
There isn't much difference between 40:1 and 50:1 so I would not panic if I got it wrong once or twice, but aside from the mix not being optimal you can always default to a stronger mix of oil to fuel. So running 40:1 in a machine that is supposed to have 50:1 isn't going to cause much ANYproblems.
Fixed that for you.
#4476375 - 08/01/17 10:15 AM Re: oops lost manual... [Re: Johnny2Bad]
bubbatime Offline
Loc: South Florida
Actually, on today's sealed carburetors with sealed mixture screws, running 40:1 in a 50:1 machine, or vice versa, has a very large chance of not running correctly. I used to have customers by the boat load bring me two cycle equipment that "wasnt running right". I would drain the tank, refill it with the correct fuel mix that the manufacturer suggests, and bam, the equipment was running like new. I've seen it a hundred times.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4476689 - 08/01/17 04:10 PM Re: oops lost manual... [Re: bubbatime]
Chester11 Offline
Loc: PA
Thanks for the replies all. I got them all labelled out. All are 50:1 except for the cheap weedeater brand trimmer. It bogs down even with the premix hi octane stuff, so unless I can figure out how to adjust the carb via youtube, this may be it's last season.
I'm considering an electric to replace it. But that is another topic.
#4477086 - 08/02/17 03:34 AM Re: oops lost manual... [Re: Chester11]
Kamele0N Offline
Loc: Slovenia
Clean your carburator... Optionally...remove its spark arestor from muffler and report back
Page 1 of 2 1 2 >
