Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
28 registered members (biggusblockus, 4WD, c502cid, agh13tz, 5 invisible), 734 guests, and 35 spiders.
Topics290,921
Posts4,852,540
Members66,055
Most Online3,590
Jan 24th, 2017
Ford Coil on Plug - removal tips to prevent damage #4475327
07/31/17 08:50 AM
07/31/17 08:50 AM
SW Ontario Canada
KGMtech Offline OP
KGMtech  Offline OP
SW Ontario Canada
Hi,
Saturday I tried to replace the plugs on the 2009 Flex with 3.5L V6, pulled the coil out of # 1 and the lower rubber piece was left remaining on the plug - I suspect the dealer tech that did the last change didn't use any dielectric grease on the rubber boot and now it welded itself to the porcelain. Tried to get that rubber piece (Motorcraft WR6135) to come off the plug in one piece, no such luck, pieces chunked off with use of my long handled needle nose pliers.
I stopped the spark plug project. These rubber parts are $ 9 CAD each. Is there a better way to remove these without damaging? Not a lot of room down at the bottom of the hole..
Thanks again if you can offer some advice!
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4475339
07/31/17 09:00 AM
07/31/17 09:00 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
I did the sparkplugs at 78k on my SHO (Same design as the NA 3.5) and tore a couple from the factory. So I don't think they used dielectric either. Or it dried up. What I did was get them all out and went to the dealer to replace the boots I tore. I think I only tore 1 or 2 of them so it may get better as things go along.
Only thing I could think would be to try to get some WD40 down there but you would have to then clean the boot really good on reinstallation.
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4475505
07/31/17 12:01 PM
07/31/17 12:01 PM
saginaw michigan
saginawmale50 Offline
saginaw michigan
soak with pb blaster for a few days
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4475715
07/31/17 03:40 PM
07/31/17 03:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Any way to get compressed air in there?
It'll inflate the rubber like a balloon so it pops off easily without tearing
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4475845
07/31/17 06:31 PM
07/31/17 06:31 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
You should replace the coil boots during a tune up. It's a piece of rubber that's been through 100k miles of heat cycles.
I always price them out for a tune up. Most customers refuse them assuming I'm trying to scam them but I keep doing it!
Re: Ford Coil on Plug - removal tips to prevent damage [Re: saginawmale50] #4476012
07/31/17 09:00 PM
07/31/17 09:00 PM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
Bad idea. PB is petroleum based and will make the boots swell so they won't hold in the high voltage.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Ford Coil on Plug - removal tips to prevent damage [Re: cb_13] #4476019
07/31/17 09:06 PM
07/31/17 09:06 PM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
I totally agree and do the same thing with my customers.
Think of it this way- people don't typically run plug wires longer than the typical 100k plus spark plugs, so why run the boot again?
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4476351
08/01/17 09:41 AM
08/01/17 09:41 AM
SW Ontario Canada
KGMtech Offline OP
KGMtech  Offline OP
SW Ontario Canada
UPDATE:
I purchased 6pc of the boots from the local Ford dealer, with the understanding that if I didn't need all 6 they could be returned.
I made myself a pick from a piece of coat hanger, about 7 inches long with a 3/16" bend on the end. Fit down the plug hole and slide past the stuck boot, twist and pull up. Couple of attempts and the boot comes out without damage. I needed 2pc of the rubber boots, 4 will be returned. The original 4 undamaged rubber boots all looked in excellent condition, very pliable, no cracks, no discolouration after 168,000km.
New plugs installed with a blob of dielectric grease applied inside the boots, some anti-seize on the threads and job done in about 1.5 hours including the removal of the intake manifold. Now Flex is set for another 5 years :o)
1984 Yamaha XJ750RL
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4476886
08/01/17 07:59 PM
08/01/17 07:59 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I did plugs on my fusion around 120k. They all came off no trouble, they were lubed from the factory but I put some dielectric grease in there anyway
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4476909
08/01/17 08:19 PM
08/01/17 08:19 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I did the ones on my Mustang early just to see how they were. I always twist the coils off the plugs.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford Coil on Plug - removal tips to prevent damage [Re: KGMtech] #4479018
08/04/17 01:20 PM
08/04/17 01:20 PM
FL
9050lx Offline
9050lx  Offline
FL
Just changed Motorcraft Platinum plugs on a 2003 4.6L. 198,000 miles,2nd time plugs have been changed. gaps at.060 grown from .054.Boots look perfect.WD40 spray,twist and they come right out.Cylinder #4 spark plug is always the tightest,lol.
