Are they actual oils to buy of higher grade than what is available in the stores... or are they things you 'add' to oil?
I assume they are add ons. Why not buy Mobil 1 and then just add the product you need to make that already good oil burn through less so it actually lasts much longer than it currently does? Can be that simple... ye?
Makes me wonder why on earth they didn't just make it last longer by not breaking down considering they got all that.
These are the base stocks used to blend oils, not "add-ons".
