NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
83 registered (2K2AcuraTL, andyd, 92saturnsl2, 4WD, Ag76, 10 invisible), 1585 Guests and 32 Spiders online.
65294 Members
67 Forums
285769 Topics
Page 1 of 2 1 2 >
#4475211 - 07/31/17 06:01 AM Drills
greasegunn Offline
Loc: NY
After struggling to drill out a broken stud on an exhaust flange Iím in the market for some better drills. Laying under the car is not my idea of fun so I want something that will zip through materials commonly found on automobiles as quickly as possible. Looks like the choices are High Speed Steel, cobalt, and carbide. Or maybe I should just buy inexpensive drills and treat them as throw aways? What are the pros and cons of each? For example I understand that carbide tends to be brittle. What is everyone else using with good success?
#4475224 - 07/31/17 06:31 AM Re: Drills [Re: greasegunn]
Bumble_guy Offline
Loc: Northern Illinois
Cobolt is your friend
1981 Kenworth 1984 International 1996 chevy pickup 2000 GMC, skid steer ,2000 goergie boy motorhome 36f, 2006 Mustang GT Convertable
#4475237 - 07/31/17 06:46 AM Re: Drills [Re: Bumble_guy]
Kira Offline
Loc: Champlain/Hudson Valley
Is "Cobalt" that Home Depot store brand name or a type of steel alloy? serious question
#4475240 - 07/31/17 06:50 AM Re: Drills [Re: greasegunn]
jjw6455 Offline
Loc: ohio
I struggled with that exact same stud on my Mazda 6, went through 3 or 4 bits and wasn't getting anywhere. Picked up a cobalt bit from the local store and it zipped through the stud in 30 seconds.
#4475245 - 07/31/17 06:57 AM Re: Drills [Re: greasegunn]
bioburner Offline
Loc: Minnesota
Cobalt is a type of steel, very expensive but ideal for drilling on hardened steel. Great for drilling out bolts before using a extractor or when drilling gun receivers for scope mounts and the metal is surface hardened or like the old Springfields just plain hard steel. The negative is that its brittle, so drill straight and get the surface center punched to prevent the tip from walking. Learn how to sharpen bits properly. 30 seconds at the grinding wheel putting a good point on can reduce efforts needed to drill.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4475280 - 07/31/17 07:59 AM Re: Drills [Re: greasegunn]
Trav Offline
Loc: MA, Mittelfranken.de
Cobalt M42 jobber length bits and some smaller left handed ones for broken bolts and studs. For drilling through broken bolts I sometimes use solid carbide bits, you only need a few sizes but they are expensive an 1/8 and 1/4 will get you started with a pilot hole for most broken bolts then use the LH bit.
Edited by Trav (07/31/17 08:02 AM)
#4475301 - 07/31/17 08:17 AM Re: Drills [Re: Kira]
HerrStig Offline
Loc: Boston, MA
"Kobalt" is a Lowes brand.
#4475302 - 07/31/17 08:18 AM Re: Drills [Re: greasegunn]
Astro14 Offline
Loc: Virginia Beach
All cobalt bits are expensive.
I've got a whole set. Nothing better.
But even cobalt dulls. Get a drill doctor and keep them sharp.
You'll be amazed.
You don't need a King Kong drill, just good, sharp, bits.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
16 Tundra 1794 5W30 Valvoline
#4475357 - 07/31/17 09:15 AM Re: Drills [Re: greasegunn]
9050lx Offline
Loc: FL
Sears has a set they occasionally offer for a little over 30 bucks on sale.Probably chinese but they seem to work well.
#4475371 - 07/31/17 09:27 AM Re: Drills [Re: jjw6455]
greasegunn Offline
Loc: NY
As it turns out my issue was also on a Mazda 6 - the stud from the muffler that attached to the pipe had broken off. I needed to drill out the stud put in a nut and bolt.
#4475372 - 07/31/17 09:28 AM Re: Drills [Re: Astro14]
Trav Offline
Try solid carbide, they are amazing at cutting through hardened metal and stay sharp a long time. Both the cobalt and carbide give cordless drills much better performance.
This will go through a broken bolt like a hot knife though butter.
http://www.ebay.com/itm/1-8-Solid-Carbid...4-/131380163688
#4475396 - 07/31/17 09:57 AM Re: Drills [Re: greasegunn]
Bandito440 Offline
Loc: NEUS
Carbide is the proper choice here. Be sure to avoid chatter; they can be brittle.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
#4475422 - 07/31/17 10:17 AM Re: Drills [Re: greasegunn]
Dyusik Offline
Loc: US-WA
+1 for cobalt, those bits are worth every penny.
95 Cherokee 190K DELO 10W30,XG8
07 IS250 97K FB ?w??,FULL
04 YZF-R1 19K DELO 15w40,XG7317
99 HD XL1200S 18K VR1 20w50,1515
14 RX450h 30k PP 0w20,NAPAG
#4475671 - 07/31/17 02:37 PM Re: Drills [Re: greasegunn]
Bumble_guy Offline
I don't know if you have Menards out by you but a set of cobalt bits by mastercraft 26 bucks ,work well
#4475697 - 07/31/17 03:13 PM Re: Drills [Re: bioburner]
Linctex Offline
Loc: Waco, TX
Correct, and I never waste my money on anything of lesser quality.
Page 1 of 2 1 2 >
