Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
123 registered members (addyguy, 1978elcamino, 2015_PSD, 69Torino, 2K2AcuraTL, 15 invisible), 1,876 guests, and 57 spiders.
Topics286,116
Posts4,902,933
Members67,565
Most Online2,967
Mar 10th, 2019
VOLVO - XC90 V8 oil recommendation engine B8444S #4475037
07/30/17 09:45 PM
07/30/17 09:45 PM
OZ
mrsquigle Offline OP
OZ
Hi from Australia.
Seeking Oil recommendations for my 2011 Volvo XC90 in the V8 B8444S option.
My Manual calls for 0w-30 grade A5/B5, and recommends the Castrol Professional. I have not been able to source this specific oil in Australia, so looking for a comparable oil that is readily available to me in Sydney.
Below are the oils I have been able to find locally, but uncertain if suitable for my vehicle
Mobile 1 0w-30 advanced fuel economy
Mobile 1 0w-40
Mobile 5w-30
Nulon 5w-30 Fuel efficient ACEA A5/B5
Penrite 0-30
Penrite 5w-30
I am open to other suggestions not mentioned above, these are simply oils that I found readily available in my area.
Thanks in advance.
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475045
07/30/17 09:55 PM
07/30/17 09:55 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The M1 5w30 or 0w40
I'd run 10w30 also, or 5w40, 10w40, 15w40
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475057
07/30/17 10:05 PM
07/30/17 10:05 PM
OZ
OZ
thank you for the fast response.
Mobil 1 does not list as being A5/B5 grade, is this critical in my selection? also, I was a little concerned going to 0w40, what would be the advantage or disadvantages of going heavier oil grade.
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475136
07/30/17 11:40 PM
07/30/17 11:40 PM
Michigan
NO2 Offline
NO2  Offline
Michigan
Shell Helix ultra 5w-30 is commonly available in Australia. It meets A5/B5
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475145
07/31/17 12:12 AM
07/31/17 12:12 AM
Crawfordville FL
Crawfordville FL
It's rather hot in Australia. Cold cranking isn't really a concern, but high oil temps are very possible. A thicker oil gives more of a buffer compared to a 30 at a given temp. If you just putter around the 30 will be fine, but if you put that V8 to work I'd run a 40 in your climate.
I believe the A5/B5 is a resource conserving spec like ilsac is here in the States. If that's the case then I wouldn't worry about it. Someone more familiar with euro specs will need to chime in
EDIT
I was right
Quote:
The A/B class's A5/B5 oils have lower HTHS viscosities, which means that they provide better fuel economy but they may not provide adequate protection in engines that are not designed for them. ACEA A3/B3 and A3/B4 on the other hand require oils with higher HTHS viscosities that may not provide as good fuel economy as an A5/B5 oil but may offer better engine protection in certain engine designs.
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475172
07/31/17 02:24 AM
07/31/17 02:24 AM
OZ
OZ
Interesting thank you Silverfusion.. It seems like a protection vs fuel economy grading. I would much prefer to sacrifice fuel economy and have a happy engine
- Would using an A3/B3 graded oil harm my engine?
- Would a 0w30 A3/B4 be thicker oil than 0w30 A5/B5, and therefor a step in between a 0w40 oil.
In my search I also found a Nulon 5w-30 European in the A5/B5. It was a cheaper oil, which then makes me skeptical of its performance when comparing to some of the well known more expensive brands. I prefer to pay a little more if it has a proven reputation, given the recommended oil by Volvo seems to be at the top end of synthetic oils.
Anyhow.. please keep the suggestions coming. It would also be great to hear from fellow XC90 V8 owners with their experience.
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475185
07/31/17 03:47 AM
07/31/17 03:47 AM
Belgrade, Serbia, Europe
DS9 Offline
DS9  Offline
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475209
07/31/17 05:57 AM
07/31/17 05:57 AM
South Wales, UK
Bailes1992 Online content
Bailes1992  Online Content
South Wales, UK
I'd look for something that carried Ford WSS-M2C913D specification if you're struggling to find an A5/B5 0w30 oil.
However, if it was my eneigine I would be running a *w30 or *w40 A3/B4 oil for maximum protection.
'17 Volvo V40 D3 Geartronic - Total V-Drive 0w20 & Comma MVATF
'18 Dacia Sandero 0.9T - Fuchs GT1 5w40 & Sintofluid 75w80
'96 LR Defender 300TDi - Fuchs GT1 5w40, Sintofluid 75w80 & Sintopoid 75w90
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475260
07/31/17 07:28 AM
07/31/17 07:28 AM
OZ
OZ
Ok thanks, would I be safe running a A3/B4 oil such as 0w40 Mobil 1. This oil seems very popular but cannot find any recommendations for the V8 Volvo specifically.
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475272
07/31/17 07:46 AM
07/31/17 07:46 AM
Connecticut
Sam_Julier Offline
Sam_Julier  Offline
Connecticut
The least expensive 0W30 that meets the A5/B5 spec. But I wouldn't hesitate to run M1 0W40 despite not having the A5/B5 spec.
2013 Toyota Avalon Hybrid TGMO 0W20, 68k
1993 Volvo 245 T5 10W30, 153k
1993 Volvo 244 PP 10W30, 166k
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4475421
07/31/17 10:16 AM
07/31/17 10:16 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
That oil would be a great choice. The Volvo V-8 is a good engine, but like all Volvos, sensitive to oil quality vs. change interval. The PCV system (flame trap in Volvo vernacular) will become plugged with sludge if an oil is run too long, and the resulting pressure in the crankcase will cause oil leaks, or worse, seal failure.
So, any long drain oil, or any decent oil changed more frequently, is a good choice.
For your climate, any of those viscosities should do, because your engine is naturally aspirated, and doesn't have the oil temp rise of a turbo. I think it uses oil jets for piston cooling, but heat on the pistons is more a result of load on the engine than outside site temperature.
If the rest ofhe Aussies are running a XXw40, then you might consider that. But on this engine, a good XXw30 should be fine.
It's a quality, and drain interval, not viscosity, question.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4476102
07/31/17 10:51 PM
07/31/17 10:51 PM
OZ
OZ
Thanks Astro14, this is very helpful information, particularly advice regarding PCV system and drain interval.
I just found my local supplier carries A5 Castrol 0w30 Edge professional, available in 20 litre drums (part number 3374588). It specs on the drum.. API SL, ILSAC GF-2 ACEA A5/B5, A1/B1
Would this be quality suitable for my engine?
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4476189
08/01/17 05:41 AM
08/01/17 05:41 AM
Crawfordville FL
Crawfordville FL
I would find something that meets API SN
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: mrsquigle] #4476197
08/01/17 05:58 AM
08/01/17 05:58 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
That would be an excellent oil.
32 Packard 15W40
05 MB S600 0W40 M1
Re: VOLVO - XC90 V8 oil recommendation engine B8444S [Re: SilverFusion2010] #4476202
08/01/17 06:03 AM
08/01/17 06:03 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Why?
Here is the North American owners manual specification for oil.
The Castrol fits that...
32 Packard 15W40
05 MB S600 0W40 M1
