ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
104 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Doh! Check the clutch cable tension on those bikes #4474993
07/30/17 08:54 PM
07/30/17 08:54 PM
Where the wind comes sweepin'
Reddy45 Offline OP
Reddy45  Offline OP
And just like that, we say goodbye to 4 clean quarts of Rotella T6 5W40 with less than 1000 miles on it...
I couldn't figure out why my bike wasn't shifting well, so I changed the oil early.
And then the day after I changed the oil, I thought.. I wonder if the clutch lever has too much slack? Yup that was it.
duh duh duh duh duh duh duh duh
Re: Doh! Check the clutch cable tension on those bikes [Re: Reddy45] #4475031
07/30/17 09:41 PM
07/30/17 09:41 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
didnt the clutch feel weird? then again im pretty anal about my controls/cables. they have to be lubed and set!
if you have fresh oil you need to drain....dump it into a clean container then pour it into a container through a paint filter..dont just waste it.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Doh! Check the clutch cable tension on those bikes [Re: Reddy45] #4475135
07/30/17 11:40 PM
07/30/17 11:40 PM
Reddy45 Offline OP
Reddy45  Offline OP
The clutch lever pull felt fine, but it was incredibly difficult to click the shifter between gears. I just am not used to checking the clutch freeplay on a regular basis so this didn't occur to me.
There was maybe an extra 3mm of play at the lever compared to the factory specification, so it didn't take much stretch in the clutch cable for this to happen.
Anyway, I have been rather paranoid about running T6 5W40 on this bike in the summer months because it tends to run VERY hot. Before I knew the clutch freeplay was the culprit, I assumed that the oil had sheared down too much and was to blame.
I have T4 15W40 in there now and a brand new clutch cable on the way.
Re: Doh! Check the clutch cable tension on those bikes [Re: Reddy45] #4475258
07/31/17 07:22 AM
07/31/17 07:22 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
we gotta know...what bike???
especially one that holds 4qts!!!
motorcycle oil myth buster
Re: Doh! Check the clutch cable tension on those bikes [Re: sunruh] #4475279
07/31/17 07:56 AM
07/31/17 07:56 AM
Central Maine
Altydoc Offline
Altydoc  Offline
Central Maine
I'm guessing a liter bike? My R1 takes 4qts.
Re: Doh! Check the clutch cable tension on those bikes [Re: Reddy45] #4475308
07/31/17 08:29 AM
07/31/17 08:29 AM
Reddy45 Offline OP
Reddy45  Offline OP
Triumph Tiger 800
