Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
84 registered members (Billbert, 53' Stude, BHopkins, A310, bdcardinal, 08z06, 12 invisible), 1,555 guests, and 38 spiders.
Topics290,852
Posts4,851,447
Members66,044
Most Online3,590
Jan 24th, 2017
A/C gauge reading question #4474851
07/30/17 05:24 PM
07/30/17 05:24 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
On my 2009 Honda CRV with 95,000 miles...
After a long trip on the interstate (3 hours) I noticed a few drops of water on the passenger floor board. Turns out, all the plastic under that side of the dash was cold and covered in condensation. In fact, the side against the center console was like touching ice. The A/C cools, but is not as cold as it once was. A friend let me borrow his gauges and thermometer. Ambient temp is around 90. With the AC on max and recirculating, temp in the center vent only gets down to 42-44. With the compressor running, the low side shows 35-40 and the high side around 250. The high side needle "wobbles" and the low side one does not.
I am NOT an AC man, and hooking the gauges up is about the extent of my ability with that system. Before I take it to a shop, any insights into what I may be looking at?
Thanks
Re: A/C gauge reading question [Re: podan] #4474855
07/30/17 05:30 PM
07/30/17 05:30 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
High side pressure is within reason for the ambient, if not slightly high. Make sure the condenser is clean and the fan is running well.
Low side is perfect. And the vent temperature is good.
If you still think its not cooling as well, you might look for a air flow restriction. Does this vehicle have a cabin filter? If so what is its condition?
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: A/C gauge reading question [Re: Colt45ws] #4474862
07/30/17 05:41 PM
07/30/17 05:41 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I'm an A/C rookie too.
Suggestion: See that your drain pipe is clear. Sounds like (from my HIGHLY LIMITED experience) it's clogged and the condensation tray is full of water.
The evaporator's fins hit the water and chill it. The system has less cold to deliver to the air.
Scold me if I'm wrong.
Re: A/C gauge reading question [Re: podan] #4474863
07/30/17 05:45 PM
07/30/17 05:45 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The water is condensation. Sounds like the drain is plugged. The wobbling high side is worn pistons or valves in the compressor
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: A/C gauge reading question [Re: podan] #4474980
07/30/17 08:32 PM
07/30/17 08:32 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
The cabin air filter is less than 2 months old.
The drain line is open, and a lot of water is draining out of it underneath the vehicle.
I just had front end open, condenser is nice and clean. Electric fans appear to be working well and moving a lot of air.
Re: A/C gauge reading question [Re: podan] #4474990
07/30/17 08:51 PM
07/30/17 08:51 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Vent temps at idle seem pretty good. Clean the condenser real good with condenser cleaner. Might bring the high side down a bit. Maybe
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: A/C gauge reading question [Re: Chris142] #4474998
07/30/17 09:00 PM
07/30/17 09:00 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
If OP is really in New Orleans, the humidity there is likely horrid...
Re: A/C gauge reading question [Re: JHZR2] #4475014
07/30/17 09:22 PM
07/30/17 09:22 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
Yes I really am in New Orleans. Today the humidity was not bad, but it's usually terrible!
Re: A/C gauge reading question [Re: podan] #4475027
07/30/17 09:34 PM
07/30/17 09:34 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Since nobody is paying attention to my thread, I'll try the question here:
Ambient Temp: 102.2* F
Vent Temp: 55.6* F
Low Side Pressure: 53 PSI
High Side Pressure: 260 PSI
R143A range at 100* F is supposed to be 50-55 Low 315-325 High
Should I add more refrigerant ?
Re: A/C gauge reading question [Re: Merkava_4] #4475042
07/30/17 09:51 PM
07/30/17 09:51 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Vent Temp: 55.6* F
Because you were asking about vent temperatures in multiple locations, which can be attributed to a lot of things.
What does your FSM say the pressures should be?
Have you evacuated and refilled by mass?
Re: A/C gauge reading question [Re: JHZR2] #4475064
07/30/17 10:09 PM
07/30/17 10:09 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I haven't checked the FSM for the pressures because I didn't know they'd be in there. Just going by the R134A chart. I didn't evacuate it because I didn't open the system up to change parts; I just topped the system off. There are no leaks that I know of. Somebody on here said that the R134A molecule is so small that it eventually works its way through the rubber hoses.
Re: A/C gauge reading question [Re: podan] #4475314
07/31/17 08:35 AM
07/31/17 08:35 AM
Toronto, Canada
KrisZ Offline
KrisZ  Offline
Toronto, Canada
The evaporator might be icing up. When it does it affects the vent air flow. Low charge can cause the evaporator to ice up.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: A/C gauge reading question [Re: podan] #4475432
07/31/17 10:26 AM
07/31/17 10:26 AM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Following this thread. Our 08 is having issues only in traffic or a long stop light when the ac doesn't work. At speed works fine.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: A/C gauge reading question [Re: podan] #4475433
07/31/17 10:29 AM
07/31/17 10:29 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
What are the readings at a faster rpm, say 1500?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
