IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
113 registered members (53' Stude, 66Monza, 2K2AcuraTL, 77GrandPrix, -SyN-, 28oz, 9 invisible), 1,898 guests, and 55 spiders.
Topics295,230
Posts4,930,603
Members66,716
Most Online2,553
Oct 27th, 2018
Best Dextron VI 6 Power Steering Fluid #4474568
07/30/17 09:45 AM
07/30/17 09:45 AM
Arlen Texas..... (Houston)
TX_1821 Offline OP
TX_1821  Offline OP
Hello yall
Recently bought a 16' buick lacrosse.
Want to replace the PS fluid with something great, also maybe magnefine inline filter too.
(Want best I can get, as it'll be cheap to do. Ie, maybe use a whole quart)
Vehicle calls for:
Hydraulic Power Steering System- DEXRONŽ-VI Automatic Transmission Fluid.
Some Dextron 6 fluid:
-Valvoline
-ACdelco 10-9395
-Mobil 1 103529
-Castrol Transmax
-Havoline
Any recommendations for brands or types of fluid to use?
Also would "Lubeguard Power Steering Protectant" be any good, as supplement add on?
^Maybe it's "Snake Oil"???
Note: Plan to keep car for +100K miles
Thanks for any comments!!! cheers
Computers don't make mistakes...What they do they do on purpose"
-Dale Gribble
16' Lacrosse 3.6 LFX
Oil: QSUD 5w30 & Fram Ultra
ATF: Valvoline Dex 6
Re: Best Dextron VI 6 Power Steering Fluid [Re: TX_1821] #4474595
07/30/17 10:33 AM
07/30/17 10:33 AM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
It is Dexron
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Best Dextron VI 6 Power Steering Fluid [Re: TX_1821] #4474608
07/30/17 10:47 AM
07/30/17 10:47 AM
USA
slacktide_bitog Offline
USA
the cheapest licensed Dexron VI you can find smile
There's usually no reason to change the PS fluid, especially on a car as new as yours
Re: Best Dextron VI 6 Power Steering Fluid [Re: TX_1821] #4474673
07/30/17 12:34 PM
07/30/17 12:34 PM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
You are way, way, way overthinking power steering fluid here. Like already mentioned, any licensed Dexron VI will do you fine.
2018 RAM 2500 Cummins 6.7L (Delvac 1300 15W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Best Dextron VI 6 Power Steering Fluid [Re: TX_1821] #4474685
07/30/17 12:57 PM
07/30/17 12:57 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
This is more important than the color of the container the fluid comes in.
What I do after that is every time I service the transmission (drain/fill every 30k), I pull one of the reservoir hoses on the PS system and drain it into a container, then fill with clean fluid. That and an inline filter should take your PS pump to 200k+, and you don't have to lift the front end and do a full flush ever.
If you want to be really efficient, keep the old PS fluid in a jar/container, use as a penetrating oil or cleaner, cutting fluid for drill bits, etc.
Re: Best Dextron VI 6 Power Steering Fluid [Re: Hootbro] #4475369
07/31/17 08:26 AM
07/31/17 08:26 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 agreed. Given the choices you provided I would go with the Castrol. They make top notch ATFs
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
