New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
97 registered members (2015_PSD, andyd, Astro14, ArrestMeRedZ, askani79705, AndyB, 6 invisible), 1,376 guests, and 42 spiders.
Topics290,748
Posts4,849,591
Members66,034
Most Online3,590
Jan 24th, 2017
AC longetivity #4474438
07/30/17 08:16 AM
07/30/17 08:16 AM
NY
greasegunn Offline OP
NY
So my impression is that the AC system may be one of the most problematic systems on modern cars. How long has everyone gone without doing any kind of repair or refrigerant recharge? I seem to make it to the 5 - 7 year range before I see a decrease in cooling performance and need some kind of work.
Re: AC longetivity [Re: greasegunn] #4474441
07/30/17 08:23 AM
07/30/17 08:23 AM
South Central PA
Delta Online happy
Delta  Online Happy
South Central PA
Our old 2001 Expedition that was bought in 2007 and we never touched the AC system 10 years it was in the family. Went through some of the hottest Mississippi summers and still blowed cold the day it was traded in. The rear heater core was a different animal though...
On the flipside, mother had a 2002 Camry Solara that was bought new and needed charged in less than 3 years.
The S10 seems to need half a can every 6 months or so. Not worth the money to replace the leaking compressor at this point.
'17 VW GTI 2.0T - 6MT - 9K - Edge 0w40
'15 Camry SE - 2.5 - 20K - PP 0w20
'99 S10 - 2.2 5MT - 155K - T6 0w40
Re: AC longetivity [Re: greasegunn] #4474445
07/30/17 08:27 AM
07/30/17 08:27 AM
Perth, Western Australia
Brad_C Offline
Brad_C  Offline
All Automotive A/C leaks. If you re-gas it every couple of years it'll last until you suffer an external mechanical failure (like a clutch bearing). If you don't, then you'll restrict oil circulation until you lunch the compressor.
Unfortunately most people are in the "out of sight, out of mind" mentality and thus they run it until it "don't blow cool no more", and by that time most of your oil is in the evaporator and your compressor becomes an aluminium dust factory.
Re: AC longetivity [Re: greasegunn] #4474465
07/30/17 08:48 AM
07/30/17 08:48 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Brad c nailed it...the oil moves with the refrigerant. The oil also seeps out the many connections ,compressor shaft seal etc. We recomend a recharge with oil added every 60k.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: AC longetivity [Re: Brad_C] #4474467
07/30/17 08:50 AM
07/30/17 08:50 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
That must be me. My current DD has 15 years and 75K miles on the original AC system. Never touched or recharged. Maybe I should? Blows as cold today as when I bought it in 2009.
Curiously, I think my previous DD (also a Lincoln Continental) also went 12 yrs and 230K miles on original AC when the car died of other causes.
My 1999 had the AC go due to a compressor seal leak after 13 yrs. Been fine for the past 5 yrs.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: AC longetivity [Re: greasegunn] #4474471
07/30/17 08:51 AM
07/30/17 08:51 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
My Accord went 19 years before the charge finally got low enough to need a recharge. At that point I converted the R12 system to R134a, recharged, and I was good to go. That was 6 years ago and it's still working great.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: AC longetivity [Re: 69GTX] #4474495
07/30/17 09:22 AM
07/30/17 09:22 AM
Brad_C Offline
Brad_C  Offline
Does it? You did brand new temperature and pressure readings to compare with now? Or are we talking "butt dyno" and "it's still good enough for me even though it might have been actually better when new".
As your refrigerant level drops you lose subcooling from the condenser, then you start to bubble through the expansion device and ultimately under-fill the evaporator, so you _do_ lose system efficiency and therefore cold at the evaporator. Of course with Automotive systems they are mostly over-specced to begin with, you won't actually notice extended cycle times and the resulting power loss and fuel consumption until you start sweating. The overall result is vaguely similar cabin temperatures. So unless you measure, you don't actually know.
I'd put money on it.
Re: AC longetivity [Re: greasegunn] #4474498
07/30/17 09:24 AM
07/30/17 09:24 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
2003 4Runner, 160K+ a/c never touched, lots of hard pulling in the desert, works like new.
I've wondered if slightly improper care will actually damage a sealed system like a/c. This happened to my home a/c and it was expensive to fix. My current home a/c is 17 years old and besides keeping the system clean along with the electrostatic and regular furnace filters there has been none of that periodic maintenance by a service company done and it works like new.
Re: AC longetivity [Re: Brad_C] #4474507
07/30/17 09:47 AM
07/30/17 09:47 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
As long at it is still cold, who cares?
Re: AC longetivity [Re: Slick17601] #4474515
07/30/17 09:52 AM
07/30/17 09:52 AM
Chris142 Offline
Chris142  Offline
if its low on refrigerant the compressor is being starved for oil.
Re: AC longetivity [Re: greasegunn] #4474535
07/30/17 10:10 AM
07/30/17 10:10 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
The AC in my 21 year old 30ZX still freezes you out!!
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: AC longetivity [Re: greasegunn] #4474546
07/30/17 10:21 AM
07/30/17 10:21 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I was a mechanic at a Honda dealer before eventually becoming a mechanic at UPS. The 6th generation Civic had crummy AC from the factory and a few models often had it it dealer installed like the HX and the CX hatchback. The AC at it's best performed poorly in those.
Me: 13' VW GTI 3 door 6 speed manual
Re: AC longetivity [Re: greasegunn] #4474560
07/30/17 10:34 AM
07/30/17 10:34 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
My 01 Tacoma went 15 years before it developed a leak. I've been topping it off for the last two summers but it's getting worse so it's time to find the leak.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: AC longetivity [Re: greasegunn] #4474619
07/30/17 12:05 PM
07/30/17 12:05 PM
Caribbean
Nissan101 Offline
Nissan101  Offline
Caribbean
2004 nissan n16, the ac have never been touched by me and still blows cold to this day.
Caribbean heat too laugh
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: AC longetivity [Re: greasegunn] #4474649
07/30/17 12:50 PM
07/30/17 12:50 PM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
My 95 Nissan truck was still freezing cold and untouched when I sold it in 2014.
