Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
TCam, OzFrog, Kursk, DMB, bcrossen
66060 Registered Users
76 registered members (AndyB, 92saturnsl2, 69GTX, 4WD, 1JCB, 65convertible, 12 invisible), 1,565 guests, and 29 spiders.
Topics290,932
Posts4,852,664
Members66,060
Most Online3,590
Jan 24th, 2017
AC pressure, compressor not running #4474295
07/30/17 01:28 AM
07/30/17 01:28 AM
Cascadia
slowdime Offline OP
slowdime  Offline OP
Cascadia
I normally don't touch AC systems, but long story short, shop wanted $1000 to replace compressor and condenser when the only part that had failed was the compressor clutch. I replaced it myself and it's working great. My wife's cousin was over today as I was working on my wife's car and said her AC hasn't been working for quite some time. I hooked up the AC manifold I had purchased and the high pressure side was 150psi, but the low pressure side was 350psi. I was stumped and doubled checked to make sure everything was connected properly. It was about 108 degrees today. The compressor doesn't come on, fuse and relay seem okay, tested the compressor clutch coil for continuity and its okay. I asked if she had ever had it recharged, thinking someone may have added too much, and she said no. What on earth could cause such a high reading on the low side? Maybe the previous owner added some refridgerant?
2005 TrailBlazer I6 7qts of free M1 & Wix
2010 Sentra PP & Wix
Re: AC pressure, compressor not running [Re: slowdime] #4474298
07/30/17 02:15 AM
07/30/17 02:15 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The low pressure side is reading high because the compressor is not on.
Re: AC pressure, compressor not running [Re: slowdime] #4474324
07/30/17 03:35 AM
07/30/17 03:35 AM
SA
LvR Online content
LvR  Online Content
SA
Doesn’t make sense .................
Compressor not running means the hp and lp sides should be at roughly the same pressures because the hp side bleeds down via the expansion valve to the lp side.
Stuck closed expansion valve and system in protection because of over pressure?
Re: AC pressure, compressor not running [Re: slowdime] #4474334
07/30/17 04:07 AM
07/30/17 04:07 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Can't get the low side to 350 psi IMO.
Re: AC pressure, compressor not running [Re: Shannow] #4474383
07/30/17 06:55 AM
07/30/17 06:55 AM
Perth, Western Australia
Brad_C Offline
Brad_C  Offline
Easy easy. Put the car in a paint oven. ~78C will do it.
Re: AC pressure, compressor not running [Re: slowdime] #4474384
07/30/17 06:57 AM
07/30/17 06:57 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
VW?
Re: AC pressure, compressor not running [Re: Merkava_4] #4474449
07/30/17 08:33 AM
07/30/17 08:33 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Even the pressure in the can is nowhere near that high!
Re: AC pressure, compressor not running [Re: slowdime] #4474470
07/30/17 08:50 AM
07/30/17 08:50 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Ya you simply cant have that much pressure on the low side. The evaporator would have split open a long time ago.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: AC pressure, compressor not running [Re: slowdime] #4474502
07/30/17 09:39 AM
07/30/17 09:39 AM
Toronto, Canada
KrisZ Offline
KrisZ  Offline
Toronto, Canada
Is the clutch getting the 12v signal?
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: AC pressure, compressor not running [Re: slowdime] #4474575
07/30/17 10:55 AM
07/30/17 10:55 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
At least it still HAS pressure smile. Jumper the clutch to 12 volts and (quickly) check the pressure. Don't let run long.
Re: AC pressure, compressor not running [Re: Trav] #4474597
07/30/17 11:36 AM
07/30/17 11:36 AM
Cascadia
slowdime Offline OP
slowdime  Offline OP
Cascadia
Originally Posted By: Trav
VW?
Yup. A 2004 Jetta.
Re: AC pressure, compressor not running [Re: slowdime] #4474598
07/30/17 11:36 AM
07/30/17 11:36 AM
USA
mk378 Offline
mk378  Offline
USA
Readings taken with the compressor not running are only useful to know whether or not all the refrigerant has leaked out.
Re: AC pressure, compressor not running [Re: slowdime] #4474747
07/30/17 03:28 PM
07/30/17 03:28 PM
Trav Offline
Trav  Offline
VW?
Yup. A 2004 Jetta.
Yep been there done that the readings are correct. Bad Sanden compressor, get one from Hella/Behr # HELLA 351125751 (best compressor for the money). You can sometimes replace the control valve but if it doesn't fix it its a PITA putting the compressor in and out again and again.
Replace the receiver dryer and expansion valve, there will be no debris from the control valve failure.
A word on the expansion valve on these, it uses 2 long screws that go into a clamp that attaches to the evap core, these screws are often seized, if they don't move with slight pressure forget it, just leave it.
I have had to cut a line with a cutoff wheel and mirror to get them out, its difficult and risky for the evap core.
Edit: PM if you need more info on this, there is a white temp switch in the cooling system that controls clutch operation and a few other things that tend to fail.
Re: AC pressure, compressor not running [Re: Trav] #4474823
07/30/17 04:50 PM
07/30/17 04:50 PM
Cascadia
slowdime Offline OP
slowdime  Offline OP
Cascadia
VW?
Yup. A 2004 Jetta.
Thanks Trav.
I'll talk to her, she's a bit of a tight wad and may not want to put any money in to it. It's over 100 degrees here every day in the summer though, she may change her mind.
