Does anyone know what types of exhaust hardware are generally acceptable?
I know on some systems they use locking flange nuts. I don't know what warrants that. For example my Honda uses locking flange nuts, but it also uses spring bolts and has no flex joint, where as the car I am replacing this exhaust on does use a flex joint and no spring bolts. I'm assuming the spring bolts are replacements for flex joints since the engine will still torque the exhaust to some degree so there has to be movement somewhere.
I bought some stainless steel bolts that I plan to use with zinc-plated flange nuts I bought. The nuts are not locking and I didn't buy any lock washers either. I'm hoping to avoid galling and couldn't find stainless steel locking nuts to match anyway. Down the line the zinc-plated nuts will probably rust away before the stainless steel. I'm planning to copper anti-seize the whole setup.
Do the zinc and stainless steel work with each other galvanically?
Am I likely to experience problems by not having used locking nuts or washers?
Should I have bought flange bolts to match the flange nuts?
