Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
115 registered members (ABerns, 65convertible, addyguy, 928, AdditiveOCD, 9 invisible), 2,283 guests, and 60 spiders.
Topics286,013
Posts4,900,707
Members67,545
Most Online2,967
Mar 10th, 2019
Exhaust hardware type... #4474146
07/29/17 08:37 PM
07/29/17 08:37 PM
New York
NoNameJoe Offline OP
New York
Does anyone know what types of exhaust hardware are generally acceptable?
I know on some systems they use locking flange nuts. I don't know what warrants that. For example my Honda uses locking flange nuts, but it also uses spring bolts and has no flex joint, where as the car I am replacing this exhaust on does use a flex joint and no spring bolts. I'm assuming the spring bolts are replacements for flex joints since the engine will still torque the exhaust to some degree so there has to be movement somewhere.
I bought some stainless steel bolts that I plan to use with zinc-plated flange nuts I bought. The nuts are not locking and I didn't buy any lock washers either. I'm hoping to avoid galling and couldn't find stainless steel locking nuts to match anyway. Down the line the zinc-plated nuts will probably rust away before the stainless steel. I'm planning to copper anti-seize the whole setup.
Do the zinc and stainless steel work with each other galvanically?
Am I likely to experience problems by not having used locking nuts or washers?
Should I have bought flange bolts to match the flange nuts?
2015 Civic LX Coupe
Re: Exhaust hardware type... [Re: NoNameJoe] #4474176
07/29/17 09:31 PM
07/29/17 09:31 PM
Tennessee
OilSwag Offline
OilSwag  Offline
Tennessee
Well I only have experience in non salty conditions. I'm not in a snowy region and I'm not by the beach. So in a full exhaust I can use aluminized pipe for exhaust instead of stainless and not have issue like someone in New York or wherever. For an almost fool proof leak proof connection V band is the king in my opinion unless the whole exhaust is welded. I am not afan of flex joints at all. Until I bought my really used G35 did I ever have a car with flex joints. I had full exhaust on Mustangs and LT1 cars and a few 350s and various other cars without any issues. I do think a flex joints can help but it's going to be the weakest link in the exhaust. If your car is low to the ground and scrapes I can see the flex busting. I'm sure any hardware can last enough, obviously stainless is the way to go but not a must. I think a good diy exhaust coating is enough for hardware and weld seams. I live in Tennessee so don't have the salt issues but haven't had to cut anything off or torch anything either.
03 Infiniti G35 209K, Castrol Edge 5W30 topped with Edge HM, Fram Ultra Filter, Berryman/MMO fuel maintenance in 93 E0, all synthetic fluids
Re: Exhaust hardware type... [Re: NoNameJoe] #4474214
07/29/17 10:13 PM
07/29/17 10:13 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
regular muffler clamps are grade 2 hardware. I use grade 2 5/16 coarse hardware on the flange connections between the cat and the resonator instead of OEM BMW stuff of a higher grade and way more 'spensive. Doesnt make any difference, they both rust solid. The OEM Boysen exhaust isn't life time mostly because my '88s were survivors long past the average age. I much rather deal with frozen grade 2 [censored] if I have to shear it or cut it. Exhaust hardware is one time use. I've sheared and then had to drill out a few stainless bolts. Its real slow work because fast speeds will burn an HSS bit. Even grade 8 is overkill except for studs. I use brass or copper nuts on exhaust manifold flanges down pipes. If you wanna put your money to good use, buy brass or copper nuts, not stainless. grin2
Thick oil is better grin2
Re: Exhaust hardware type... [Re: NoNameJoe] #4474233
07/29/17 10:49 PM
07/29/17 10:49 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
The only exhaust I've had to work on was my Mercedes and it has copper hardware.
Re: Exhaust hardware type... [Re: NoNameJoe] #4474250
07/29/17 11:00 PM
07/29/17 11:00 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
deleted.
LA 318 Roller Cam
Pennzoil Platinum 10w-30 SN Plus
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: Exhaust hardware type... [Re: NoNameJoe] #4474315
07/30/17 03:19 AM
07/30/17 03:19 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Steel bolts and copper nuts will not stick to each other and will be relatively easy to undo.
That said, if the exhaust fits properly youll only fit and forget - stick it together with whatever fixings you have and in 5-8-10 years when it's time for a new exhaust just cut the old one off.
Also, flexi joints are only a band-aid for bad engine/gearbox mounts. Get decent mounts and ere is no requirement for a flexi.
Cable ties should hold it
