1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
33 registered members (Char Baby, BobGoblin, Bailes1992, billt460, Blkstanger, anndel, 3 invisible), 902 guests, and 34 spiders.
Topics296,903
Posts4,961,306
Members66,997
Most Online2,688
Jan 19th, 2019
Kubota do not use oil spec #4474028
07/29/17 03:42 PM
07/29/17 03:42 PM
Mississippi
Von Offline OP
Von  Offline OP
Mississippi
So my non-emissions Kubota 7040 tractor says use a bunch of acceptable specs but DO NOT use CJ-4 engine oil because it is for DPF type engines and "cannot be used on this tractor."
Rotella 15-40 is what I've always used and what the dealer said was OK.....but I finally read the owner's manual 2 years later.
If the CF/CI type acceptable ratings are on the bottle WITH the CJ-4 rating does it matter???
I've already put 165 hours on the tractor with no visible problem.
Thanks,
Von
Re: Kubota do not use oil spec [Re: Von] #4474054
07/29/17 04:41 PM
07/29/17 04:41 PM
MI
doitmyself Offline
doitmyself  Offline
MI
If you go to the Tractorbynet web site, you will find many discussions about this. If I remember correct, most believe that the "no CJ4 oil in Kubotas" was a blunder inspired by the idea that Kubota sells tractors around the world and CJ4 was not suitable in some countries due to fuel quality, etc.. Something to that effect: http://www.tractorbynet.com/forums/oil-fuel-lubricants/186236-final-answer-kubota-cj-4-a.html
Its all a moot point now. The following link is the NEW, current Kubota recommendation. At the bottom it says that is supersedes all recommendations as of May, 2012.
http://www.kubota.com/service/LubricantMaintenance.aspx
DIESEL ENGINE OIL:
EGR Type................................API Classification
Interim Tier4 and Newer ........CJ-4 Required**
External EGR ......................... CJ-4, CI-4**
Non-EGR............................... CJ-4, CI-4, CH-4**
**As of May 2012 this information supersedes all previous publications regarding the use of CJ-4
Re: Kubota do not use oil spec [Re: Von] #4474055
07/29/17 04:47 PM
07/29/17 04:47 PM
Mississippi
Von Offline OP
Von  Offline OP
Mississippi
THAT's what I needed. grin Thanks so much. Von
Re: Kubota do not use oil spec [Re: Von] #4474175
07/29/17 08:30 PM
07/29/17 08:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
If CJ oil is good enough for a Powerstroke with HPOP and HEUI system,
...... then how could it NOT be good enough for a Kubota?
Which one "works the oil" harder?
Re: Kubota do not use oil spec [Re: Linctex] #4474373
07/30/17 05:18 AM
07/30/17 05:18 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
The Kubota. smile
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Kubota do not use oil spec [Re: Von] #4474632
07/30/17 11:23 AM
07/30/17 11:23 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Its good to pay attention to details like this. Ag. and grounds equipment manufacturers seem to make numerous mistakes in their owners manuals about lube specifications. I know someone who ruined a diesel engine by putting plain automotive type coolant in it. I remember back around 1996 when I purchased a case of 10W30 oil for my workplace Kubota and on the box it stated for the first time "For Use in Gasoline Engines Only". What the heck? Yep, thats when they took the "C" diesel rating off all the "regular" oils and a telephone inquiry confirmed that the additive levels were no longer suitable for diesel engines.
Re: Kubota do not use oil spec [Re: Von] #4475168
07/31/17 12:45 AM
07/31/17 12:45 AM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
Doesn't exactly make sense, CJ-4 is proclaimed backward compatible, far as counties that use high sulphur diesel, the TBN is the same in both CI-4 and CJ-4, only change is the add pack, CI-4 1500ppm ZInc / CJ-4 1200ppm Zinc.
Slightly more anti wear in CI-4.
Re: Kubota do not use oil spec [Re: Fraser434] #4478822
08/04/17 07:13 AM
08/04/17 07:13 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Tbn of ci4 ci4 plus was commonly 12 they backed it down to 10 with cj4.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
