ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
68 registered (93cruiser, AdmdeVilleneuve, andyd, 4WD, ammolab, 10 invisible), 1510 Guests and 64 Spiders online.
65303 Members
67 Forums
285902 Topics
#4473787 - 07/29/17 10:19 AM T/C Encore Pro Hunter
billt460 Offline
Loc: Glendale, Arizona
This is my new Thompson Center Stainless Encore Pro Hunter in .308, with a 15" fluted barrel I picked up yesterday. I'm anxious to light it up. With only 1" less barrel than a lot of 16" .308 rifles, it will be interesting to see what kind of velocity I'll be getting from some of the medium and slower burning powders. My favorite .308 handload has always been 42.0 grains of Varget under the 168 Gr. Sierra Matchking bullet. So I'll most likely start with that.
I haven't decided on optics and mounts yet. I've got some time before it starts cooling off here, and I'll have quite a few new guns to try out when it does.
http://i.imgur.com/RRaoGpW.jpg?2
#4473793 - 07/29/17 10:27 AM Re: T/C Encore Pro Hunter [Re: billt460]
2015_PSD Offline
Loc: SE Texas
I just sold two of those--one in .204 Ruger and the other in 30 T/C. I bought them years ago and never fired them. I have to say they are "heavy duty" and I realy like the design, just lost interest.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4474087 - 07/29/17 07:08 PM Re: T/C Encore Pro Hunter [Re: billt460]
AZjeff Online   content
Loc: PV Az
No reason is needed to buy and own any firearm, (but) a .308 single shot pistol seems like a "because I can" kind of thing. I once owned a T/C Contender in .221 Fireball... fun enough but couldn't find a good use for it. Will you shoot it offhand?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP *gasp*
16 Silverado 1500 4.3 Ecotec3, DI, AFM 5W-30 PP
Why know when you can guess?!
#4474246 - 07/29/17 10:56 PM Re: T/C Encore Pro Hunter [Re: billt460]
userfriendly Offline
Loc: LaFinDuMonde
I'll guess 2400 fps.
#4474356 - 07/30/17 05:24 AM Re: T/C Encore Pro Hunter [Re: AZjeff]
billt460 Offline
Originally Posted By: AZjeff
......Will you shoot it offhand?
Most likely at the plates at 200 yards on our club range.
#4474357 - 07/30/17 05:27 AM Re: T/C Encore Pro Hunter [Re: userfriendly]
billt460 Offline
I'm thinking it will easily achieve whatever ballistics come out of my 16" barreled AR in the same caliber. It's barrel is only 1" less, but it has no bleed off to operate a gas system. It will be interesting to get the chronograph out, and compare it on a load to load basis with my Savage Model 12FT-R in .308. It has a 30" barrel.
#4521928 - 09/21/17 07:39 AM Re: T/C Encore Pro Hunter [Re: billt460]
billt460 Offline
Well, it finally cooled off enough around here. And I was able to get the .308 Encore out for some range time. I took 2 different factory loads with me, (Remington 150 Gr., and Federal 180 "Power Shock" loads), as well as some handloads I built up around R-P cases 42.0 Gr. of Varget under Sierra 168 Gr. Matchkings.
From a solid rest at 50 yards the gun printed dead on both in elevation and windage. No adjustment to the iron sights was necessary. At 50 yards I could easily get baseball sized groups with both the Remington and Federal factory ammunition. The gun functioned flawlessly. The action opened and closed effortlessly. And the cases could easily be extracted with my fingers. The gun raises the cases about a 1/4" out of the chamber, but does not eject them. The hammer seemed a bit too tight, but the trigger let off was very crisp, albeit heavy. I would guess around 6 to 7 pounds.
The problem was recoil and muzzle flip. This gun has a ton of it! Much more than I expected. I have 2 Magnum Research BFR revolvers in both .45-70 and .500 S&W Magnum. As well as a Ruger Super Redhawk in .454 Casull. And this gun is far more difficult to control. Perhaps it's the long 15" barrel, that gives the muzzle more leverage to rise and whip up. In any event it's a beast to hold on to. I only got 30 rounds through it before the hide was completely worn off my trigger finger where it was hitting the lower part of the frame above the trigger guard, and I had to quit.
I came home and cleaned the gun, and gave everything a liberal oiling. Especially the hammer and trigger area. Perhaps they assembled the thing dry. I don't know. But after lubrication, and working the hammer and trigger several dozen times, everything seemed a lot better. This happened last Friday. The following Monday I went back to the range. This time I taped up my finger heavily, and continued the session.
I knew the gun was printing dead on, so I went to the 200 yard rifle range and had at the steel plates there. We have them in sizes from 8" all the way up to manhole size and above, (48"). Taking careful aim I had no trouble ringing all of them. I was surprised at how accurate the iron sights on this gun were. Both the hammer and trigger were MUCH SMOOTHER. The lube job most definitely did the trick. The trigger now seems to be letting off around 5 pounds. And the hammer requires much less effort to cock, and is much smoother doing it.
This time I ran my handloads through it, and the recoil, while still very heavy, seemed more controllable. I finished up, satisfied with the gun, and it's overall performance and accuracy. This obviously isn't a gun you are going to pour rounds through. But it does what it's supposed to do. If I were to plan a hunting trip around this weapon, I would look into equipping it with some type of optic. But seeing as my hunting days are pretty much behind me, (except for perhaps Doves), it will pretty much be relegated to the job of range toy.
I think the next time I bring it out, I'll take my 30" barreled .308 Savage Model 12F-TR with it, and set up my chronograph. That way I can get some velocity differences between the 30" barrel of the Savage, to the 15" barrel of the Encore with identical loads in identical conditions. It should be interesting to see the spread.
