WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
26 registered members (burla, chance, Char Baby, bmod305, bbhero, arthuro, 3 invisible), 833 guests, and 33 spiders.
Topics290,810
Posts4,850,765
Members66,036
Most Online3,590
Jan 24th, 2017
Question about limited slip differential #4473722
07/29/17 08:41 AM
07/29/17 08:41 AM
MD
Toby45 Offline OP
Toby45  Offline OP
MD
Hello Guy's, I am new here and would like change the rear end fluid in my 2016 SS Camaro it calls for GM #8886264 I can't seem to find any other lube that cross reference's the GM fluid. What is so special about that fluid other than it has the limited slip additive?
Re: Question about limited slip differential [Re: Toby45] #4473733
07/29/17 08:56 AM
07/29/17 08:56 AM
CO
UberArchetype Offline
CO
My WAG would be, nothing. 75W/90 with a LS additive is probably one of the most common gear lubes on the market - literally dozens of different brands with that basic spec.
Re: Question about limited slip differential [Re: Toby45] #4473737
07/29/17 09:00 AM
07/29/17 09:00 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Make sure any lube you use is specified for LSD use; that is critical. Aside from that, you have many choices, but the GM lube is excellent. For a car like the late model Camaro SS, it's what I would use. For other, less critical applications (say, a GM truck) I would use one of the aftermarket lubes.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Question about limited slip differential [Re: Toby45] #4473761
07/29/17 09:45 AM
07/29/17 09:45 AM
utah
dareo Offline
dareo  Offline
utah
Lots of people seem to have chattering problems with aftermarket fluids that only go away with the gm ls fluid. Not sure why.
2016 Golf Wagon 5MT, 2014 Accord Sport 6MT, 2016 GMC 1500 SLT 6.2
Re: Question about limited slip differential [Re: Toby45] #4473806
07/29/17 10:39 AM
07/29/17 10:39 AM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
I'm fairly certain it's just a 75w90 GL5 with limited slip additive -- the Red Line and Motul sites both seem to agree. My Corvette (same engine) specs the same fluid. Tons of choices out there.
2017 Chevrolet Corvette Grand Sport
Re: Question about limited slip differential [Re: dareo] #4473808
07/29/17 10:40 AM
07/29/17 10:40 AM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
The GM fluid might have a higher dose of LS additive.
My mantra has always been to start with a smaller dose and "add to taste". I can never hear the chattering.
Re: Question about limited slip differential [Re: Johnny2Bad] #4473829
07/29/17 11:19 AM
07/29/17 11:19 AM
NJ
Padawan Offline
Padawan  Offline
NJ
I agree. It's very easy to source (can even get it with free one-day shipping from Amazon) and not terribly expensive, so I'd simply stick with the recommended OEM fluid.
Re: Question about limited slip differential [Re: Toby45] #4473904
07/29/17 01:38 PM
07/29/17 01:38 PM
CA
user52165 Offline
user52165  Offline
CA
Why are you changing on a 2016 car?
Been around these 40+ years. Always use the GM additive.
If all OK, leave it alone.
Re: Question about limited slip differential [Re: Toby45] #4473908
07/29/17 01:43 PM
07/29/17 01:43 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
What kind of differential do those use? Is it a clutch type or a Torsen? My Mustang uses a Torsen T-2 and any kind of LSD additive is a no-no.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Question about limited slip differential [Re: Toby45] #4473970
07/29/17 03:14 PM
07/29/17 03:14 PM
BC, Canada
userfriendly Offline
BC, Canada
I thought Camaros like pickup trucks have the standard G80 locker, if that is the case, no LS fluid is needed.
www.eaton.com
www.dana.com
Re: Question about limited slip differential [Re: user52165] #4474011
07/29/17 04:21 PM
07/29/17 04:21 PM
Chicago, IL
dparm Offline
dparm  Offline
Chicago, IL
GM recommends changing it after the first track day/competitive driving event.
Re: Question about limited slip differential [Re: Toby45] #4474026
07/29/17 04:41 PM
07/29/17 04:41 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
Put in exactly what GM specs. This is a $ 40,000+ dollar car, treat it as such.
Re: Question about limited slip differential [Re: Toby45] #4475456
07/31/17 11:10 AM
07/31/17 11:10 AM
MD
Toby45 Offline OP
Toby45  Offline OP
MD
Thanks so much Guys! I ordered the GM fluid.
