Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (97K15004WD, 53' Stude, AZjeff, andyd, BeerCan, 64bawagon, 7 invisible), 1,936 guests, and 40 spiders.
Topics295,122
Posts4,928,094
Members66,688
Most Online2,553
Oct 27th, 2018
Ford 6.7 powerstroke severe duty oil #4473693
07/29/17 06:59 AM
07/29/17 06:59 AM
Northeast
buzzy3 Offline OP
buzzy3  Offline OP
Northeast
Still feeling out the new 6.7 powerstroke, and about to do my first long heavy towing. Manual mandates 5-40 oil for severe service...in this case towing over 1000 miles on the change cycle. I expect the IOLM to tell me to change oil at somewhere around 5000 miles as it will factor in towing etc.
Is this engine that hard on oil? Is the mandate to use 5-40 really a mandate to use synthetic, perhaps because of high engine temps? It seems like the low temp benefits of a 5-40 oil would not be an issue here, so to me, it seems like a mandate to use synthetic on a low mileage drain and fill schedule.
I don't have an issue doing it but would like to understand the requirement and the reasoning behind it.
Thanks!
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473718
07/29/17 07:34 AM
07/29/17 07:34 AM
oh
roadrunner1 Offline
roadrunner1  Offline
oh
The IOLM will surprise you, depending on your rear-end you may see 10,000 mi. before the IOLM message to "change oil now" pops up. I have the 3.31 rear and its not uncommon to go 10,000 mi.
I can't answer the 5w-40 recommendation, with no cold weather there is nothing wrong with 15w-40. I use nothing but 10w-30 and every UOA has come back stellar.
'15 F350 6.7
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473741
07/29/17 08:10 AM
07/29/17 08:10 AM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Our 6.7 at work spends most of the time with a trailer behind it and has over 100k on it. It gets 15w-40 Delo changed according to the OLM.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473743
07/29/17 08:13 AM
07/29/17 08:13 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Currently running 15w40 VPB here in the midwest.
I see no reason for 5w40 unless your temperature mandates it.
I will be switching to 10w30 next spring, partially based on roadrunners continued good success, and whether by design, or the young oil jockey reading the cap, the majority of local trucks serviced at the dealer getting 10w30 for all use, and they haven't stopped yet!
beanoil: Tough under heat, real dirty afterwards.
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473747
07/29/17 08:21 AM
07/29/17 08:21 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I ran Rotella T6 in my older Dodge Ram with Cummins and now run it in my Ford F250 with Powerstroke. But for now running the CJ-4 flavor.
Going to DELO 400 5W40 CJ-4 because I can find it.
I feel 5W40 is a good oil regardless of severe service.
2015 Ford F250 w/Powerstroke
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473817
07/29/17 09:52 AM
07/29/17 09:52 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, it's the 40 part that counts smile
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473845
07/29/17 10:42 AM
07/29/17 10:42 AM
MD
claluja Offline
claluja  Offline
MD
How heavy are you towing? My 6.7 oil temp gets to 225-235 degrees towing 14K in the summer, using motorcraft 5w40 for example.
Think it's the 40 that matters most. However, I've always wondered whether the 5 was important for extended idling periods when the engine is running at less than operating temperature (I do alot of overnight idling on some long towing trips). Note that extended idling is considered severe service by Ford.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: Ford 6.7 powerstroke severe duty oil [Re: claluja] #4473893
07/29/17 12:10 PM
07/29/17 12:10 PM
Northeast
buzzy3 Offline OP
buzzy3  Offline OP
Northeast
Towing about the same as you...maybe 14,500. I have read that the 230's is pretty normal for entine temps. And I know that I am in a severe duty bracket, but I can come up with no reason why Ford mandates the use of 5-40 for towing...at least on my 2017. Just curious...but I like to know the reasons for these odd requirements.
Re: Ford 6.7 powerstroke severe duty oil [Re: roadrunner1] #4473894
07/29/17 12:12 PM
07/29/17 12:12 PM
Northeast
buzzy3 Offline OP
buzzy3  Offline OP
Northeast
Is that 10,000 towing mileage? I hope so...that's about what my Duramax wanted me to change at.
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4473932
07/29/17 01:09 PM
07/29/17 01:09 PM
oh
roadrunner1 Offline
roadrunner1  Offline
oh
I don't tow every day, but the truck is loaded daily. Your rear end is the determining factor, according to the owners manual. The lower rpm's the longer the IOLM will go.
'15 F350 6.7
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4493484
08/20/17 08:25 AM
08/20/17 08:25 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Had some stuff happen recently, and ran up some miles.
Changed my 6.7 yesterday from VPB 15w40 to Delo Severe Duty 15w30 and a Donaldson P502503.
I'm not worried in the least about this oil.
It performed great in my 6.0, I expect with it's narrow spread and .12 P and Z it will perform just as well in the 6.7 .
https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=413394&docFormat=PDF
Re: Ford 6.7 powerstroke severe duty oil [Re: beanoil] #4494232
08/21/17 06:51 AM
08/21/17 06:51 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
That oil should be great for you and anyone else with a Powerstroke (or any other diesel pickup). It's not for extended intervals, but the average diesel pickup owner is quite conservative, anyway.
I'm curious how old the oil you bought is? I rarely see the 15W30 but when I do, the bottles are covered in dust. I recently saw a fellow owner/op getting an oil change and putting it in his C15 Cat, so it's still available. It's been on the market for a few years now but don't hear much about the stuff.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: Ford 6.7 powerstroke severe duty oil [Re: buzzy3] #4494242
08/21/17 07:10 AM
08/21/17 07:10 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
dustyroads, my bottles are from 2014. Bought on sale at Amazon back at introduction. I've got 6 more changes left in the stash.
Re: Ford 6.7 powerstroke severe duty oil [Re: beanoil] #4494264
08/21/17 07:34 AM
08/21/17 07:34 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
thumbsup Ok thanks. I thought it was right around three years ago, now. At the introduction, truck stops had posters on the walls promoting the 15W30. They said that with an oil change, Chevron would provide 10 free oil analyses. That only lasted for a few months and I never did try it in my trucks.
Still a great choice if you have it or can get it.
