Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
125 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,235 guests, and 63 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Copper spark plug question #4473468
07/28/17 10:07 PM
07/28/17 10:07 PM
Caribbean
Nissan101 Offline OP
Caribbean
How often should i replace NGK copper spark plugs?
Thank you :-)
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: Copper spark plug questions [Re: Nissan101] #4473472
07/28/17 10:10 PM
07/28/17 10:10 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I believe that most applications with copper plugs call for replacement at 30k
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Copper spark plug questions [Re: Nissan101] #4473474
07/28/17 10:12 PM
07/28/17 10:12 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have found the energy of the ignition system plays a bigger role than mileage. I have had some go 50,000 miles.
An MSD ignition system will wear them out faster... but because of the high amperage (which causes the wear in the first place) they'll keep firing well long after the gap has exceeded .080"
Re: Copper spark plug questions [Re: Nissan101] #4473477
07/28/17 10:16 PM
07/28/17 10:16 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
true - I've run copper plugs up to 45k with no problems; but generally the mfr specs 30k. I'm thinking that with the MSD the issue is not only higher voltage but also the fact that the MSD ignition fires multiple times per event; at least below 3000 rpm or something like that.
Re: Copper spark plug questions [Re: Nissan101] #4473482
07/28/17 10:23 PM
07/28/17 10:23 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Check em first, assess their wear, make decision
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Copper spark plug questions [Re: Nissan101] #4473493
07/28/17 10:38 PM
07/28/17 10:38 PM
USA
ArcticDriver Offline
USA
Why run them a long time?
They are $5/each.
Vehicles run better with new plugs.
Good choice running NGK.
Multiple Diesel and Gasoline vehicles
Re: Copper spark plug questions [Re: Nissan101] #4473508
07/28/17 11:05 PM
07/28/17 11:05 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
I may not have run the NGK plugs (original and 1st replacement set) much beyond the recommended 30K in my Mazda, but later I ran equivalent Champion copper ones well over 100K with no problems, meaning no detectable improvement in power or fuel economy when I finally replaced them. I did clean and regap them a couple of times. I suspect the NGKs could've done the same, if I'd given them a chance.
2011 Toyota Prius now at 97K
Re: Copper spark plug questions [Re: ArcticDriver] #4473509
07/28/17 11:06 PM
07/28/17 11:06 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
They are $5/each.
5 dollars each for copper plugs?
where are you getting ripped off at?
Re: Copper spark plug question [Re: Nissan101] #4473535
07/28/17 11:40 PM
07/28/17 11:40 PM
CA
user52165 Offline
user52165  Offline
CA
Why copper? Platinum or iridium are usually best.
What application and what is OEM?
Re: Copper spark plug question [Re: Nissan101] #4473562
07/29/17 12:27 AM
07/29/17 12:27 AM
USA
oldhp Offline
oldhp  Offline
USA
What is a copper spark plug? Do you mean copper core? Almost all plugs have a copper core to aid in heat removal.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Copper spark plug questions [Re: Rand] #4473570
07/29/17 12:51 AM
07/29/17 12:51 AM
USA
USA
They are $5/each.
laugh
Exactly !
Re: Copper spark plug question [Re: Nissan101] #4473583
07/29/17 01:55 AM
07/29/17 01:55 AM
Caribbean
Caribbean
Its normal v power spark plugs.
Nissan N16 -10w30
Nissan S13 -20w50
Re: Copper spark plug question [Re: user52165] #4473584
07/29/17 01:56 AM
07/29/17 01:56 AM
Caribbean
Caribbean
OEM is copper.
Nissan N16 -10w30
Nissan S13 -20w50
Re: Copper spark plug questions [Re: ArcticDriver] #4473598
07/29/17 03:01 AM
07/29/17 03:01 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
They are $5/each.
laugh
Exactly !
Still cheaper then ignition coil...wich can fail prematurely if it has to cope with worn out plugs for too long...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Copper spark plug questions [Re: Nissan101] #4473631
07/29/17 05:51 AM
07/29/17 05:51 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Chrysler sold millions of new gen 5.7 Hemis with cheap conventional plugs and a 30k replacement schedule.
Yet the 6.1 liter SRT engine shipped with top of the line NGK Iridiums despite having the exact same ignition setup. recommended interval? 105k miles. Newer model 5.7s like our 14 RAM have iridiums now.
Just changed the plugs out in a service van here, GM 6.0 engine. Almost no wear despite 113k miles and over 2500 hours of stationary operations.
We have run them over 200k miles before with only one coil replaced ever, so I guess the coils are not guaranteed to fail...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Page 1 of 3 1 2 3
