AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
54 registered (cjcride, Astro14, BrewCityR, d00df00d, bullwinkle, ccs368, 5 invisible), 1003 Guests and 24 Spiders online.
65294 Members
67 Forums
285754 Topics
#4473368 - 07/28/17 08:34 PM High Moly Oils bad for Rocker Arm Needle Bearings?
davison0976 Offline
Loc: NJ, USA
I was looking at some UOAs the other day and noticed some oils, like RedLine for example, have higher level of Moly. Should high Moly oils and Moly additives be avoided in engines where rocker arms have needle bearings, like Pentastar V6, for example? IIRC the general consensus is not to use Moly grease in needle bearings. What about the oils?
#4473390 - 07/28/17 08:54 PM Re: High Moly Oils bad for Rocker Arm Needle Bearings? [Re: davison0976]
PeterPolyol Offline
Loc: toronto
The only thing to worry about is 'bearing skate'. It's when the bearing experiences such little friction that the needle/roller doesn't even turn, but instead slides or 'skates' in a fixed position. This can cause a flat spot if the needle does this for an extended period of time.
I personally don't think there is a practical concern for the roller in the follower to fail because of this with moly engine oil formulations.
#4473419 - 07/28/17 09:20 PM Re: High Moly Oils bad for Rocker Arm Needle Bearings? [Re: davison0976]
Dyusik Offline
Loc: US-WA
If only was in the same amounts as in grease, but this is less than a tenth of a percent for most, and even in red line doses there are dispersants in the oil helping things move along, when flow of oil should be enough on its own.
Although it is fun to speculate, I get trapped in thoughts like this often.
Edited by Dyusik (07/28/17 09:20 PM)
95 Cherokee 190K DELO 10W30,XG8
07 IS250 97K FB ?w??,FULL
04 YZF-R1 19K DELO 15w40,XG7317
99 HD XL1200S 18K 76 20w50,1515
14 RX450h 30k PP 0w20,NAPAG
#4473512 - 07/28/17 11:11 PM Re: High Moly Oils bad for Rocker Arm Needle Bearings? [Re: davison0976]
Rand Offline
Loc: NE,Ohio
High moly grease is usually 5%
Very High moly oil is .2% max.
2017 Jeep Cherokee Trailhawk V6
