Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
87 registered (928, 71Chevyguy, 1JZ_E46, 2015_PSD, 14Accent, 9 invisible), 1586 Guests and 42 Spiders online.
65303 Members
67 Forums
285861 Topics
#4473335 - 07/28/17 08:06 PM Gas scooter wont start
Jukebox Offline
Loc: United states
I bought this used Viza venom 33cc motor scooter two years ago I rode it for a month then winter came and I put didnt touch it for a month or two. The engine wouldn't start and in the process I broke the rope to the starter. While trying to restring it the recoil spring came out and I have yet been able to get in back into the housing. I just cleaned out the carburetor and put fresh mixed gas and got a new spark plug in there, im using a 18v wireless drill to try and start it but its not starting any suggestions, I believe the issue is with the carburetor the gas intake seems to be missed up but I dont have the patience to tinker with it, Please let me know if you have any feed back on what might be going wrong!
#4473359 - 07/28/17 08:25 PM Re: Gas scooter wont start [Re: Jukebox]
ArcticDriver Offline
Loc: USA
Is it getting fuel?
Is the spark plug saturated with fuel?
Multiple Diesel and Gasoline vehicles
#4473384 - 07/28/17 08:47 PM Re: Gas scooter wont start [Re: ArcticDriver]
Jukebox Offline
Loc: United states
I believe there is some promblem with the fuel deliver but the spark plug is covered in oil when I take it out to make sure im geting ignition, I believe there may be a oil build up/ carbon build up, but when I took of the exaughts to remove exscess oil it sitll wouldnt start. And i believe its getting some fuel cause at one point it started up for about 10 secounds then died
#4473386 - 07/28/17 08:49 PM Re: Gas scooter wont start [Re: Jukebox]
Jukebox Offline
Loc: United states
Is there anyway to test if its revieving fuel or not?
#4473609 - 07/29/17 03:45 AM Re: Gas scooter wont start [Re: Jukebox]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Open the carb. Bet you find crud clogging the idle jet a minimum, and probably the main jet too.
#4474299 - 07/30/17 02:22 AM Re: Gas scooter wont start [Re: Jukebox]
JTK Offline
Loc: Buffalo, NY
A quick search on eBay showed replacement recoil assemblies for under $10. Replacement carbs about the same.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4475402 - 07/31/17 10:01 AM Re: Gas scooter wont start [Re: Jukebox]
jeepman3071 Offline
Loc: Storrs, Connecticut
If the plug is covered in oil the mixture might be too rich (sounds like it runs on mixed gas). Try replacing the plug if it seems to be getting fuel.
If you replace the plug and it won't fire, spray a small amount of carb cleaner in the carb and see if it fires on that. If it fires on the carb cleaner, you have a fuel delivery problem.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
