Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
Geardaddies, 01ws666, ariefnrst, tcoffin014, Schm1d
66658 Registered Users
102 registered members (ArrestMeRedZ, andyd, Alfred_B, 28oz, AZjeff, 15 invisible), 1,903 guests, and 39 spiders.
Topics294,983
Posts4,925,346
Members66,658
Most Online2,553
Oct 27th, 2018
Coolant in oil? #4473173
07/28/17 03:15 PM
07/28/17 03:15 PM
PA
Chester11 Offline OP
PA
Hi guys:
2007 Mazda 6i here.
It has a small coolant leak that I can't seem to chase down.
Will a standard Blackstone UOA tell me if the car is leaking coolant into oil?
Re: Coolant in oil? [Re: Chester11] #4473181
07/28/17 03:25 PM
07/28/17 03:25 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
It will, but I hope your not using an oil that contains sodium to skew the results. Let your engine sit on ramps for hours
letting the engine cool down. Crack the drain bolt and see if any coolant dribbles out.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Coolant in oil? [Re: skyactiv] #4473189
07/28/17 03:40 PM
07/28/17 03:40 PM
PA
PA
using the mazda FL22. I took the under cover off a few months back, and don't see any leakage.
it is difficult to read the tank. I can smell burning coolant - so it is going somewhere.
Re: Coolant in oil? [Re: Chester11] #4473204
07/28/17 03:59 PM
07/28/17 03:59 PM
North TEXAS
oldoak2000 Online content
oldoak2000  Online Content
North TEXAS
prolly weeping onto exhaust manifold somewhere; oil level will INCREASE if it's ending up inside the block.
If you've already replaced all hoses AND waterpump, I've had good luck locating TINY leaks by totally emptying all coolant (including block), then pressurizing to 15/20 #'s with AIR, then listening around for HISSING sound - head cracks/gasket leaks are revealed by removing plugs and listening inside spark-plug hole (use a rubber tube - one end at ear, other in plug-hole, or anywhere leak suspected.
Re: Coolant in oil? [Re: Chester11] #4473253
07/28/17 05:06 PM
07/28/17 05:06 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Take it to a reputable mechanic to get it checked. You don't to guess with coolant
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Coolant in oil? [Re: Chester11] #4473611
07/29/17 03:20 AM
07/29/17 03:20 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I would get the oil analyzed for contamination. Small internal leaks will not give the oil the milkshake appearance, as I found out, so you never really know.
The "thinking" man's friend.
