Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
40 registered members (Black_Thunder, carlprop, bbhero, Ag76, ArrestMeRedZ, 3 invisible), 894 guests, and 58 spiders.
Topics286,170
Posts4,903,521
Members67,572
Most Online2,967
Mar 10th, 2019
5.3 LS 300k Busted Piston #4473141
07/28/17 03:18 PM
07/28/17 03:18 PM
Lynchburg, Va
JasonC Offline OP
JasonC  Offline OP
Lynchburg, Va
Here is a pic from a 2003 Silverado 5.3 with 300k. It broke a valve which caused it to punch a hole in the Piston and trashed the combustion chamber. This truck was bought in 2006 with only 40k and it has always used M1 5w30. I'm impressed with how clean the tops of the pistons are. The rest if the bottom end was just as clean. We believe that a clogged cat is what caused the pressure buildup and broke the valve.
2012 Buick Verano 2.4
2006 Ford Mustang GT Convertible
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473144
07/28/17 03:25 PM
07/28/17 03:25 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Your pic is on photobucket. They are blocking links to other websites.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473145
07/28/17 03:26 PM
07/28/17 03:26 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
never mind
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473150
07/28/17 03:30 PM
07/28/17 03:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I kind of doubt that. I've floated many exhaust valves due to excessively high back-pressure on turbocharged race engines, and never had a failure like THAT! ("Float" is really only about .010"-.020" off the seat, any way)
clogged converter = engine has no power or quits, not broken valves.
This was a metallurgical flaw.
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473172
07/28/17 04:09 PM
07/28/17 04:09 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
So check the cat. I doubt it's the cause, though, more like a bad valve.
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473207
07/28/17 05:01 PM
07/28/17 05:01 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Valve guides got loose and let the valve bend when it seated and it eventully broke off.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 5.3 LS 300k Busted Piston [Re: Chris142] #4473274
07/28/17 06:41 PM
07/28/17 06:41 PM
Lynchburg, Va
JasonC Offline OP
JasonC  Offline OP
Lynchburg, Va
Incorrect. There was nothing wrong with the guide or the valve spring. The converter was clogged.
Re: 5.3 LS 300k Busted Piston [Re: Linctex] #4473276
07/28/17 06:42 PM
07/28/17 06:42 PM
Lynchburg, Va
JasonC Offline OP
JasonC  Offline OP
Lynchburg, Va
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473277
07/28/17 06:43 PM
07/28/17 06:43 PM
Lynchburg, Va
JasonC Offline OP
JasonC  Offline OP
Lynchburg, Va
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473389
07/28/17 08:52 PM
07/28/17 08:52 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
crazy! what are you gonna do with it?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473407
07/28/17 09:13 PM
07/28/17 09:13 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Were you redlining it when that happened?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473636
07/29/17 06:07 AM
07/29/17 06:07 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
300k with stock parts the valve guides were definitely worn. We have raised and killed dozens of 5.3's and they rarely break. We have had many clogged cats at high miles and yet zero engine failures, even when racing them at far past factory redline.
Sorry, but I don't see a clogged exhaust breaking a valve like that...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: 5.3 LS 300k Busted Piston [Re: JasonC] #4473957
07/29/17 02:42 PM
07/29/17 02:42 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I dealt with a clogged cat on my Navigator. It was clogged so bad that I had to disable overdrive and floor the truck to get to 55 mph. Even that never broke a valve.
I suppose anything is possible, but I have much much doubt that a clogged cat was your issue.
I'm betting it was one of the other top causes of valve fracture.
Re: 5.3 LS 300k Busted Piston [Re: tomcat27] #4475437
07/31/17 10:39 AM
07/31/17 10:39 AM
Lynchburg, Va
JasonC Offline OP
JasonC  Offline OP
Lynchburg, Va
We put some JB Weld on the Piston and slapped it back together. Should be good for another 300k. J/K we have a crate motor going back in.
