Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
56 registered members (alarmguy, Ablebody, 69Torino, 10ecfarmer, 65convertible, 4 invisible), 973 guests, and 28 spiders.
Topics290,870
Posts4,851,622
Members66,044
Most Online3,590
Jan 24th, 2017
Way too much fuel--coming out of the exhaust--22RE #4472801
07/28/17 08:54 AM
07/28/17 08:54 AM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
Just got my 1992 Toyota pickup with the 22RE put back together the other day. Basically rebuilt the top end plus new timing chain and other new parts. Did not have the injectors rebuilt, but I did clean up the holes where the injector seats into the lower intake, and I did install seal kits for each injector.
Went to crank it for the first time, and it fired right up. Started smelling fuel after it ran for about a minute, but could not find a visible leak. Shut it off, and looked for seeping around the fuel connections, but could not find any leaks. Started the engine the second time, and the fuel smell got stronger, and it ran for about another minute before I shut it down. Engine did start to lope right before I shut it down because it was being flooded with fuel.
Fuel was 100% coming out of the exhaust. It was pumping so much fuel it was ridiculous. It has been sitting the last two days waiting on me to fix it. I was so mad at the time because I had put so much love, labor, and money into it. An old gent I know said just walk away from it, and let it sit for a couple days, and then fix it, so that's what I am trying to do now.
Stuck open injector/s, grounded injector/s, fuel pressure regulator stuck closed not allowing fuel to return to tank, and cold start injector malfunctioning by continuously pumping fuel when it's only suppose to pump fuel for seconds on startup is the only things I know that would cause the over fueling.
Going to install a new Kyosan pressure regulator and some new injectors. Want to do some testing before those parts come in. Can't find a noid light that will plug into a Denso fuel injector harness to check and see if I am getting pulses instead of staying on to rule out a grounded injector. None of the noid kits that I have looked at mention Toyota.
Need my truck, so any and all advice would be appreciated. Thanks!
1992 Toyota Pickup--Formula Shell 10W-30--Fram PH3614
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4472861
07/28/17 09:35 AM
07/28/17 09:35 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Sounds like you are already guessing at the culprit. pinched off return would be my guess.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Way too much fuel--coming out of the exhaust--22RE [Re: OVERKILL] #4472886
07/28/17 09:51 AM
07/28/17 09:51 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Especially since it got progressively richer over several minutes.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: OVERKILL] #4472909
07/28/17 10:11 AM
07/28/17 10:11 AM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
The pressure regulator is 25 years old now. It did sit on a work bench dry without fuel for eight days. I am thinking that it just went defective sitting there dry. My understanding of how the pressure regulator functions is that if it gets stuck closed then the return will be shut off, and the fuel will only have one way to go which would be into the fuel rail.
The return hose from the pressure regulator to the return tank line at firewall is about 12 inches or so long, and it is not pinched. Did not mess with the return tank line from the firewall back to the tank. Anything is possible though, and I did not think about it being pinched from firewall to tank, but I do not think it is likely. Thanks for the tip!
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4472931
07/28/17 10:41 AM
07/28/17 10:41 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Does the regulator have a vacuum port on it? I know from my experience with return-based Ford vehicles that the regulator was vacuum controlled (vacuum reduced fuel pressure at low load) and that if the diaphragm in the regulator ruptured that they fuel would be drawn straight into the intake via that vacuum hose and would result in a scenario strikingly similar to what you are presently experiencing.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4472966
07/28/17 11:19 AM
07/28/17 11:19 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Don't forget to change the oil when you get it sorted out. That much fuel in the oil is not good for lubrication.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Way too much fuel--coming out of the exhaust--22RE [Re: OVERKILL] #4472976
07/28/17 11:34 AM
07/28/17 11:34 AM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
Yes the fuel pressure regulator has a return line and a vacuum line.
Very good diagnosis because I think that's what is going on. Fuel being sucked straight into the intake via vacuum hose because of a bad regulator. Will be easy to check. Will pull the vacuum hose off the regulator port, and see if it leaks fuel.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: bubbatime] #4472978
07/28/17 11:37 AM
07/28/17 11:37 AM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
I will. I pulled the dipstick yesterday, and it already had a faint smell of fuel.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4473031
07/28/17 12:48 PM
07/28/17 12:48 PM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
You smell fuel- raw fuel or unburnt/poorly burnt/rich out the tailpipe?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4473042
07/28/17 01:03 PM
07/28/17 01:03 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Cold start injector is a common failure.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Way too much fuel--coming out of the exhaust--22RE [Re: The_Eric] #4473078
07/28/17 01:58 PM
07/28/17 01:58 PM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
It's was raw fuel coming out of the tail pipe. It was blackish looking from the soot in the exhaust system. It was also coming out of the exhaust manifold too where it connects to the down pipe. Thought it was going to catch on fire. Engine only ran for a couple minutes total, and it did run good up until it started loping because of the cylinders being flooded.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: Chris142] #4473083
07/28/17 02:01 PM
07/28/17 02:01 PM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
I will unplug it after it starts running to see if the flooding stops. Not sure of the best way to test it.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4473146
07/28/17 03:27 PM
07/28/17 03:27 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That won't help - because if it's stuck open, it's going to flow whether there's an electric signal or not!
Re: Way too much fuel--coming out of the exhaust--22RE [Re: Linctex] #4473629
07/29/17 05:45 AM
07/29/17 05:45 AM
NC
BigD1 Offline OP
BigD1  Offline OP
NC
Yes that sounds right.
I did find how to test the resistance of the cold start injector. Otherwise, the only other way that I have found to test it is to crank the engine with the cold start injector pointed down into a container to catch fuel, and watch what happens. Seems dangerous to do it that way.
Re: Way too much fuel--coming out of the exhaust--22RE [Re: BigD1] #4473735
07/29/17 08:57 AM
07/29/17 08:57 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Clamp off the fuel line to the cold start injector. Most engines start fine without it. Also is the gunk coming out of the tail pipe just condensation from sitting?
Thick oil is better grin2
