Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
69 registered members (Berny, BeerCan, bigal51, b1amgm47, Best F100, aquartlow, 5 invisible), 1,271 guests, and 48 spiders.
Topics295,174
Posts4,929,165
Members66,700
Most Online2,553
Oct 27th, 2018
M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 #4472754
07/28/17 07:09 AM
07/28/17 07:09 AM
Lynchburg, VA, USA
SF0059 Offline OP
SF0059  Offline OP
Lynchburg, VA, USA
First UOA from my Mazda 6 and the 2.5 doesn't fail to impress. The engine is mostly driven on highways and open back roads. I could extend the OCI to 7500mi and the warranty would be fine. However, I am rotating the OEM tires every 5k to make them last as long as possible, so it is just easier to do everything at 5k. Here is the report.
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472764
07/28/17 07:27 AM
07/28/17 07:27 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Is the SkActive a turbo? Looks good but I certainly would not use the Moly additive. M1 uses Tri Nuclear Moly and the additive may create more problems than the cure. M1 0-20 AFE is plenty capable of protecting your engine for hundreds of Ks of miles. Thanks for posting.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472771
07/28/17 07:35 AM
07/28/17 07:35 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Just playing devils advocate:
Looks like M1 EP and 10K OCI would be better here. Or just rotate at 7500 Miles.
there is waste in this plan given the "mostly highway miles" which are easy on the OCI.
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472776
07/28/17 07:38 AM
07/28/17 07:38 AM
MN
oil_film_movies Offline
MN
I'm wondering if the Ceratec did anything at all for wear, since you just equaled the Universal Average (per 1k miles) for iron. It could have reduced friction in non-hydrodynamic regions of the engine for all anybody knows.
A well formulated oil like the ones you're using don't need it.
Insolubles was low. Was that a Fram Ultra oil filter you used, like in your Odyssey?
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472822
07/28/17 08:09 AM
07/28/17 08:09 AM
Lynchburg, VA, USA
SF0059 Offline OP
SF0059  Offline OP
Lynchburg, VA, USA
Hey Guys, thanks for the feedback.
@tig1 The 2.5 is NA. The moly was to more closely duplicate Mazda's OEM Syn w/moly. I will say this about it... since I changed the oil and didn't put Ceratec in I am down 1.5mpg on the highway. Anecdotal at best, but I'll be interest to see what happens when I put it back. Also, because my OCI is so short, I'm running whatever name-brand 0w20 is on rollback at Walmart. Over the first 3 changes it has received PP, M1 and now Castrol. I'm not too concerned by tri-nuc moly issues, especially since I will only be running M1 sporadically.
@ARCOGraphite, I would absolutely run a 10k OCI if I could under warranty. I was pushing up to 14k on M1EP on my RAV4 when I sold it. The maximum allowable interval according to Mazda is 7500. I agree it is a bit of a waste to change it at 5k, but when I find the time to rotate the tires I just do the oil as well. Alternating service schedules is for guys who have more time than I have right now. However, you better believe I will be extending the OCI when the warranty is up!
@oil_film_movies, I am using the OEM 1WPE-14-302 filter, presumably made by Denso. I have a dissection of it and I was impressed with its construction. here.
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472854
07/28/17 08:29 AM
07/28/17 08:29 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Perhaps the loss in MPG is more because you switched from M1 0-20AFE to Castrol. M1 touts that 0-20AFE will produce .5-2.5 MPG gain. Real numbers or not that seems to fall into the ballpark for your 1.5 MPG loss. Also I would only do UOAs after two OCs in a row with the same oil.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472922
07/28/17 09:27 AM
07/28/17 09:27 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Nice post - I too would just extend the OCI & rotation to 7500 miles. Highway miles are easy on tires too. Skip the Ceratec IMO - it's a new car, you don't need to "engineer" a special oil.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4472941
07/28/17 09:58 AM
07/28/17 09:58 AM
Slinger, Wisconsin
BrewCityR Offline
BrewCityR  Offline
Slinger, Wisconsin
7.11 cSt .... you should be getting 45 mpg shocked
2006 Infiniti M45 Sport (me) - Castrol Edge 0w40 - Fram FPS7317
2016 Mazda CX-5 AWD Grand Touring (wife) - Castrol Edge 0w20 - Premium Guard PG4612EX
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: tig1] #4472965
07/28/17 10:19 AM
07/28/17 10:19 AM
MN
MN
No, you misunderstand that the claimed 0.2% to 2.3% MPG advantage with the AFE oils are compared to a higher viscosity oil. That means comparing a 0w20 to a 5w30 with naturally greater hydrodynamic drag. The friction modifiers in the 0w20 and 0w30 oils are nothing special. It does help during warmup to have the "0w" rating, but many other oils have 0w.
Mobil probably sells a lot of the AFE flavor by confusing people exactly as you are. I think its intentional, since most people won't understand or read the fine print, & Mobil marketers know that.
Mobil's statement: "Low viscosity, advanced full synthetic formula
Helps increase engine efficiency and improve fuel economy, based on 0.2-2.3 percent potential fuel economy improvement obtained by switching from higher viscosity oils to a 0W-20 or 0W-30 grade. Actual savings are dependent upon vehicle/engine type, outside temperature, driving conditions and your current motor oil viscosity."
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4473122
07/28/17 01:40 PM
07/28/17 01:40 PM
Florida, Cape Coral
Eddie Online sleepy
Eddie  Online Sleepy
Florida, Cape Coral
Impressive low fuel in oil for the DI SkyActiv engine. Mazda seems to have solved the fuel dilution issue. Agree with moving to 7,500 mile OCE & rotation. Ed
CX5 Touring 2.5L :-)
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: oil_film_movies] #4473156
07/28/17 02:45 PM
07/28/17 02:45 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Remember that tig1 works for Mobil, which he will deny.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: BrewCityR] #4473158
07/28/17 02:48 PM
07/28/17 02:48 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
He's close to 35. SF0059 Fuelly
I'm doing a little better. Ti Flash
The tires are notorious for getting noisy with uneven wear so keeping them rotated regularly will keep the [censored] Dunlops happy for a while longer. I'm planning on doing the same.
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: LotI] #4473560
07/28/17 11:25 PM
07/28/17 11:25 PM
Lynchburg, VA, USA
SF0059 Offline OP
SF0059  Offline OP
Lynchburg, VA, USA
Wow, dude, you are crushing the mpg game! Are you driving mostly highway?
I am at a little bit of a disadvantage being a manual transmission. Also, my whole commute is hills. If anyone is familiar with Route 29 from Lynchburg to Charlottesville, you know what I am talking about.
Mazda really didn't think through the MT mapping as well as the AT. The fuel consumption goes up significantly if you drive above 64-65 mph. I'm talking a 3-4 mpg hit if you drive 68-69. Eventually I'm going to have Orange Virus remap the ECU to be more conservative cruising in overdrive. According to OV, the ECU runs super aggressive during cruising.
Lastly, the tires. Those Dunlops have a BAD reputation. So far they have been wearing OK, but you really need to keep them at a 5k rotation or they will get all kinds of wonky. However, at 5k I'm getting really good, even wear.
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: SF0059] #4473565
07/28/17 11:35 PM
07/28/17 11:35 PM
Lynchburg, VA, USA
SF0059 Offline OP
SF0059  Offline OP
Lynchburg, VA, USA
I really find it amusing that near perfect wear numbers become a springboard for advising against additives. Only on BITOG!
I will stir the pot some more... I kept the factory fill for 5k miles and also purposely drove it pretty aggressively during that break-in period. Flame suit on hornets...
That being said, great discussion, guys. I appreciate everyone weighing in!
Re: M1 AFE 0w20, 4634mi OCI, 14762mi 2017 Mazda 6 [Re: tig1] #4473616
07/29/17 03:45 AM
07/29/17 03:45 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
No they don't....
Quote:
Savings would be based on 0.2-2.3 percent potential fuel economy improvement obtained by switching from higher viscosity oils to a 0W-20 or 0W-30 grade.
BTW, how do you KNOW that M1 uses trinuclear ?
Yes, they have a patent, but a patent isn't a recipe.
And in order for Trinuclear to work, ot breaks down to MoS2, which is embedded in the phosphate glass layer produced by the ZDDP breakdown...
