Originally Posted By: rooflessVW
Originally Posted By: userfriendly
I did the 0W40 thing until one day I got sick of paying big bucks for engine oil for an 04 C240.
After that, above freezing it got 15w40.
$25 for 5 quarts is too much?
Originally Posted By: JimPghPA
A So in regards to what oil should you use, if you do not want your main seals to leak, then use the Castrol Edge 0W-30 European formula in the black bottle.
There is no longer angering special about that oil, unless you are finding older SL stock. Castrol 0W-30 and 0W-40 are now basically the same oil, with the 40 having a slightly higher HTHS. The Castrol 0W-30 that Mercedes used to recommend was the different, "green" Castrol.
Yeah Mobil 1 0w40 is about $25 at Walmart for a 5 quart jug. They also have their $12 rebates twice a year so it drops it down to around $13 for a 5 quart jug. Should start up again in September.
I'm not sure why he's using 15w40, I don't really know of any oil in that weight that meets MB 229.5 spec.
According to this Mercedes chart, there isn't a single oil thicker than 5w40 that meets that spec:
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
