WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
22 registered members (Buzzsaw, chance, BretK, BlakeB, BISCUT, Blkstanger, 2 invisible), 708 guests, and 32 spiders.
Topics290,810
Posts4,850,751
Members66,036
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Oil shear ? #4472692
07/28/17 06:34 AM
07/28/17 06:34 AM
MA.
Camprunner Offline OP
MA.
If an oil inside a motor shears down a grade is it still protecting at that level or is the oil and add pack compromised to a point where the oil is not lubracating properly?
Re: Oil shear ? [Re: Camprunner] #4472697
07/28/17 06:40 AM
07/28/17 06:40 AM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
It's still protecting to an extent, but how much is it being ran AFTER it sheared down?
One would need a UOA to know for sure. I personally like oils with higher starting TBN's for this reason.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Oil shear ? [Re: Camprunner] #4472704
07/28/17 06:53 AM
07/28/17 06:53 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
When an oil shears, only the VII polymer shears. The other stuff in the oil (ZDDP, dispersants, detergents, AOs, FMs etc) absolutely doesn't shear. So other than for a drop in viscosity, the oil continues to do what it's supposed to do.
Re: Oil shear ? [Re: Camprunner] #4472712
07/28/17 07:01 AM
07/28/17 07:01 AM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
popcorn
Re: Oil shear ? [Re: Camprunner] #4472716
07/28/17 07:10 AM
07/28/17 07:10 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
A sheared oil (and by extension, a fuel-diluted oil) is still offering protection, albeit at reduced protection level as a result of reduced oil film thickness consequential upon reduced operating viscosity.
However main bearings and con-rod bearings might predominantly still stays in hydro-dynamic lubrication regimes offering complete protection from abrasion/adhesion wear mechanisms.
Having said this, in the valve train systems and cylinder liner/piston ring tribo-pairs, there is increased levels of unfavourable boundary lubrication and mixed lubrication regimes ...... which are mitigated by essentially functioning anti- wear additive package.
The same cannot be said of gear-train systems, however.
Re: Oil shear ? [Re: zeng] #4472724
07/28/17 07:22 AM
07/28/17 07:22 AM
USA
ArcticDriver Offline
USA
So I understand better.
If I am using a 5w40 and it shears to a 30w, then isn't it still offering the same level of protection as a 30w?
If my vehicle manufacturer suggests I should use a Xw40, then aren't they factoring in that Xw40 oils are going to shear?
Multiple Diesel and Gasoline vehicles
Re: Oil shear ? [Re: Camprunner] #4472743
07/28/17 07:57 AM
07/28/17 07:57 AM
NY
DdDd Offline
DdDd  Offline
NY
An engineer with a half brain would spec a weight that is acceptable including shear for the duration. Then again a lot of hokey decisions get made by marketing too!
Oil film strength is a function of pressure and viscosity. If you can provide either in sufficient quantities you're doing good. My personal opinion is people who go up a weight to "stay in spec" are over thinking things. Modern engines have tighter tolerances and better oil pumps compared to yore.
I have yet to see an engine wiped out by 20weight oil. You'd think every 2017 model would be stranded on the side of the road.
Re: Oil shear ? [Re: DdDd] #4472749
07/28/17 08:04 AM
07/28/17 08:04 AM
USA
USA
Or more like a "resistance to pressure", right?
Re: Oil shear ? [Re: Camprunner] #4472762
07/28/17 08:23 AM
07/28/17 08:23 AM
Balearic Islands , Spain
FordCapriDriver Offline
Shearing is the destruction of the viscosity index improvers in an oil, it will cause the oil to get thinner, and it can increase the solid deposits in an engine.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Oil shear ? [Re: Camprunner] #4472769
07/28/17 08:33 AM
07/28/17 08:33 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Isn't it better for an oil to shear a tad than to oxidize?
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Oil shear ? [Re: FordCapriDriver] #4472774
07/28/17 08:35 AM
07/28/17 08:35 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Isn't solid deposits caused more from oil thickening(oxidizing) than shearing?
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Oil shear ? [Re: tig1] #4472802
07/28/17 08:54 AM
07/28/17 08:54 AM
NJ, USA
MotoTribologist Offline
NJ, USA
I'm also a bit confused at how shearing increases deposits....I'll await the explanation before further comment.
Re: Oil shear ? [Re: DdDd] #4472914
07/28/17 10:14 AM
07/28/17 10:14 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Wiped out vs. just simply excessive wear?
Real world experience seems to back up the advice of these experts too. Some of the best data from the modular community has come from Nick McKinney:
Quote:
"I have said it a few times now, heavier oil has better protection especially in the cam bores. ---I get 2-3 sets of modular heads a week through here, and any lay person just from looking would pick the 500,000 mile cores run on 15W-40 diesel spec all their lives over the typical Mustang head run 50,000 miles on the light stuff"
Fleets typically run their vehicles 250,000 to 500,000 miles! I've heard Nicks experience echoed several times by fleet managers. They wouldn’t run a 5w-20 oil for one minute.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Oil shear ? [Re: MotoTribologist] #4472918
07/28/17 10:17 AM
07/28/17 10:17 AM
Well, nowadays it isn't such a problem as modern oils contain less VIIs, and higher quality, more resistant VIIs, but back in the 70s when VII technology was still rudimentary and a lot of multigrade oils were absolutely packed full of them suchas some 10W-40 and 10W-50 mineral oils, when they were destroyed they did form sticky deposits inside engines and caused rings to stick etc etc etc..... or that is atleast what i've read!
Re: Oil shear ? [Re: 69GTX] #4473011
07/28/17 12:14 PM
07/28/17 12:14 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Third party hear-say doesn't count. smile
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Page 1 of 3 1 2 3
