2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
31 registered members (1345, anndel, bbhero, Ag76, andyd, 4 invisible), 1,105 guests, and 39 spiders.
Topics295,170
Posts4,929,097
Members66,700
Most Online2,553
Oct 27th, 2018
1982 onan 4.0 genset -Synthetic Or hdeo ? #4472585
07/27/17 11:15 PM
07/27/17 11:15 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
I drained the black 30 wt ( assuming) and refiled with supertech 15w40.
Since this is air cooled, should i stay with. 15w40 or go to a full synthetic 10w30 ?
I'm in az,i do personally see us running the generator in 80-100 weather and also cold ( 30 is coldest for us )
Supertech Junky
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: leroyd92] #4472614
07/28/17 01:44 AM
07/28/17 01:44 AM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I would stick with HDEO, whether synthetic or not. If you look at the additive package, volatility and TBN of HDEO compared to any PCMO; HDEO pretty much blows everything else away, especially with the additives.
For your machine and climate, I would recommend an HDEO 10w-30. Wal-Mart carries Rotella and Delo HDEO 10w-30 for a good price. That should cover your temp range and give good protection. Synthetic 5w-40 HDEO would work very well also. 15w-40 might start off a bit thick for a machine that doesn't get a lot of use and the temp can get to 30F degrees.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: leroyd92] #4472827
07/28/17 08:12 AM
07/28/17 08:12 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'd stick with 15W-40
Is this Onan 1800 RPM or 3600 RPM?
If it's 3600 RPM, it will last forever.
If it's 1800 RPM, it will last forever & ever & ever & ever & ever.....
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: leroyd92] #4472885
07/28/17 08:51 AM
07/28/17 08:51 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I think you're right on the money with the ST 15w40 you already have installed in the engine. Robust add pack at a value price. I wouldn't change a thing.
Luke
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: leroyd92] #4472948
07/28/17 10:05 AM
07/28/17 10:05 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
15W40 minimum
20W50 for any long stretches of use (several days of use)
Absolutely no xW30 weight oils
No. The guy lives in Arizona. 15W40 minimum for his engine/climate. The SuperTech 15W40 he chose is a great choice.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: leroyd92] #4472975
07/28/17 10:33 AM
07/28/17 10:33 AM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
15-40 is the lube recommended by Onan. I use 15-40 in mine anywhere from S. AZ to the mtns of NM where I live and never had a problem.
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: 1982 onan 4.0 genset -Synthetic Or hdeo ? [Re: pkunk] #4475010
07/30/17 08:17 PM
07/30/17 08:17 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I was assuming 10w-30 was the factory recommended weight and 15w-40 was just everyone's suggestion to go a little thicker because it is an old engine.
I will stick with the first part of my post though, HDEO is the way to go. 10w-40 PCMO is going to have a lot less additives.
