Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
64 registered members (aquariuscsm, 2009Edge, 4WD, Boomer, 5 invisible), 1,289 guests, and 40 spiders.
Topics295,254
Posts4,930,944
Members66,721
Most Online2,553
Oct 27th, 2018
Ran Coleman generator after sitting for 26 months #4472517
07/27/17 09:44 PM
07/27/17 09:44 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline OP
JimPghPA  Offline OP
We have two generators, a Generac 2000 Watt inverter, and a 5000 Watt/6250 Watt peak Coleman Powermate with a Tecumseh 10 HP engine. I run the carb dry and then take off the carb bowl and empty out the last bit of gasoline every time I run a generator. I also use Sta-Bil at the recommended dosage of one ounce per 2.5 gallons.
I ran the Coleman today after it sat unused for 26 months. It ran OK. The last time I used it was during a 7 hour outage back in May two years ago. Today it ran with two 1500 Watt electric heaters as the load and it worked OK. I was concerned that it might have lost the residual magnetism but it produced electricity without any problems. So it looks like it can sit for 26 months and still work properly when needed.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472546
07/27/17 10:09 PM
07/27/17 10:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I've got a VERY old Coleman (bright green) with a 8Hp Briggs engine. I think it's from the early to mid 80's. They really built them well back then. It's never caused problems. EVER.
My other Coleman Powermate is much newer (black & red) with a Briggs 10HP OHV engine. The engine runs well, but the generator head is a worthless chunk of trash.
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472553
07/27/17 10:18 PM
07/27/17 10:18 PM
Maryland USA
rubberchicken Offline
Maryland USA
I probably have the same Coleman Powermate 6250 model- purchased new around 2005. Although it works as intended, I feel its overall a piece of [censored]. Very loud, crude, high vibration. Considering I only use it about once a year, it does the job.
One thing I do that you should consider- when you put it away, pull the plug and squirt some engine fogging oil down the cylinder. This keeps residual moisture from rusting the cylinder walls and piston rings. Since I have boats and PWC I usually have a can of fogging oil on hand.
Re: Ran Coleman generator after sitting for 26 months [Re: rubberchicken] #4472566
07/27/17 10:32 PM
07/27/17 10:32 PM
JimPghPA Offline OP
JimPghPA  Offline OP
Yes, I used the Sta-Bil fogging oil sprayed down the spark-plug hole and pulled the rope several times with a paper towel over the spark-plug hole. I then replaced the spark-plug and pulled the rope stopping at the beginning of a compression stroke so the valves are closed. This sets the valve springs not to be in full compression, and also with the valves closed moisture can not get into the cylinder.
JimPghPa
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472582
07/27/17 10:58 PM
07/27/17 10:58 PM
Maryland USA
Maryland USA
thats a good point- I should check my generator to make sure both the valves are closed.
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472742
07/28/17 06:56 AM
07/28/17 06:56 AM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
Thanks for the reminder, I need to 'exercise' my old Troybilt.
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472817
07/28/17 08:05 AM
07/28/17 08:05 AM
California
Errtt Offline
Errtt  Offline
California
I usually run my inverter gen monthly, with some load, usually close to an hour. Doesn't use much fuel, but I still use gas with the blue Stabil, just in case I miss months of no usage. I shut the fuel valve after each run and let it die.
Now at the end of the month it's time for the monthly run. Plan is, a longer run and get something out of this time. So it should be about a 6 hour run because the load will be the Masterbuilt electric smoker with a few racks of ribs. So this run should have somewhat of a payback, get to eat smoked ribs. Don't fail me now generator eek
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472911
07/28/17 09:11 AM
07/28/17 09:11 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
In case if it will lost magnetism some day....just use 12v car battery....and send 2-3 short pulses trough generator conectors to induce its magnetism back wink
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4472956
07/28/17 10:13 AM
07/28/17 10:13 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I have a Coleman generator. It has a plastic tank, so dont have to worry about a metal tank rusting. I run it completely out of fuel. I dump a few splashes of fuel in it every couple months to exercise it.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: Ran Coleman generator after sitting for 26 months [Re: Kamele0N] #4473479
07/28/17 09:19 PM
07/28/17 09:19 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Most folks plug in something with brushes, Like a drill or grinder... hold the trigger down, and give the wheel/chuck a spin by hand. That always gets it going.
a HEAVY load is NEEDED once in a while - the load increases residual magnetic strength, and burns off carbon deposits from the exhaust valve.
Re: Ran Coleman generator after sitting for 26 months [Re: JimPghPA] #4473781
07/29/17 09:08 AM
07/29/17 09:08 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have a Coleman Powermate 5KW, but it has the Subaru Robin engine. I shut mine down the same as you. Never has failed to start.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 61K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
