1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
42 registered members (billt460, c502cid, anndel, billpace1956, Brad_C, 5 invisible), 1,034 guests, and 31 spiders.
Topics296,903
Posts4,961,302
Members66,997
Most Online2,688
Jan 19th, 2019
Ester-based oil additives? #4472170
07/27/17 03:26 PM
07/27/17 03:26 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
I am trying to school myself on ester-based oil additives/cleaners, which is what I gather Auto-RX is primarily. In my thinking (which could be wrong), the idea of a leave-in cleaner is very attractive compared to harsher instant flush compounds.
Are there other similar products out there?
Would using a high % ester-based oil achieve the same thing over time? Or are there certain types of esters that provide the solvency, and those are not what is found in typical engine oil?
I'm sure there must be old discussions on this subject, but I've been unable to get a clear answer or find a relevant thread.
Re: Ester-based oil additives? [Re: Oro_O] #4472174
07/27/17 03:33 PM
07/27/17 03:33 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I was literally just looking into this same topic and would also like to know more. Maybe running 1 quart of a ester based oil like RLI or Red Line along with your other oil could help a lot with cleaning...and cheaper than ARX
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Ester-based oil additives? [Re: Oro_O] #4472223
07/27/17 04:44 PM
07/27/17 04:44 PM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
Lubegard's Engine Oil Protectant has them. I use this product on my oil changes. smile
Lubegard Bio/Tech Engine Oil Protectant
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Ester-based oil additives? [Re: TheKracken] #4472247
07/27/17 05:16 PM
07/27/17 05:16 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Don't do it. Assuming you are using a quality oil, everything is in the package that you need.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Ester-based oil additives? [Re: ltslimjim] #4472251
07/27/17 05:22 PM
07/27/17 05:22 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
"LUBEGARD® ENGINE OIL PROTECTANT contains Liquid Wax Ester (LXE®) Technology, the lubrication system of the future."
The reminds me of the 1980's - when people said "never use Pennzoil because it contains wax and causes sludge"!
Re: Ester-based oil additives? [Re: Oro_O] #4472372
07/27/17 07:26 PM
07/27/17 07:26 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Lots of oils contain wax. So what ...
AFAIK, Auto-RX has some animal fats in it that are completely different from most oil. That's the point. Cleaning often requires a change in chemistry for anything to happen.
The slowest and easiest, most gentle way to clean an older engine is to rotate through oils of target viscosity with wholly differing add paks. Sodium based, magnesium based, etc.
The next best way is BG109 (EPR), a full can per oil change at around 5,000 miles and a good oversized filter to catch the stuff that come loose over time.
The most aggressive way is with KREEN from Kano Labs. 8 oz or bigger dose and a 2,000 mile oil change using Super Tech. Also use oversized filter as stuff will be coming loose ...
Re: Ester-based oil additives? [Re: BrocLuno] #4472559
07/27/17 10:29 PM
07/27/17 10:29 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Do you know if they sell kreen on amazon? I cant seem to find it...so I use amsoil flush but I want something more aggressive for sure.
Also, are HDEO's still known for really good cleaning? I have lots of m1 tdt 5w40 to use and I really want to clean out the sienna and truck.
I was planning to cycle through different types of oil to clean as well. Using HDEO first then a ester based oil and then pennzoil gtl ultra for the last cleaning.
Re: Ester-based oil additives? [Re: Oro_O] #4472572
07/27/17 10:42 PM
07/27/17 10:42 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Auto-RX is an ester made of Fatty acids derived from lanolin.
The ester is made by reacting that fatty acid with pentaerythritol (a special alcohol) to form the ester.
So the result is a POE or polyol ester.
The LubeGard LXE is an ester made of Fatty acids derived from rapeseed.
The ester is made by reacting that fatty acid with a special alcohol to form the ester.
Originally Posted By: tig1
...Assuming you are using a quality oil, everything is in the package that you need.
True
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Ester-based oil additives? [Re: Oro_O] #4472620
07/28/17 01:57 AM
07/28/17 01:57 AM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
Is the Lubegard XLE mostly ester? I had not heard of that before this thread - though I knew of the "red" version and have used it in the past. I read as much as I could about it, but was unclear if that was a majority or small amount of the product. In quart containers, it makes a more economical approach than $40 for 12 oz. of ARX. Based on the description, it sounds like the two products should have similar efficacy, though the LubeGard product does not appear to be marketed in the same way.
I have a vehicle with a specific oil coking issue that years of HDEO and M1 use will not address. This is not for prophylactic use or because I think quality oils are inadequate in general.
Re: Ester-based oil additives? [Re: Oro_O] #4472622
07/28/17 02:20 AM
07/28/17 02:20 AM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
Well, some engine models have specific issues that no lube will fix, but could perhaps minimize the effects of in a best case scenario. You may need to swap to a high mileage oil like MaxLife, they do have a fully synthetic version.
Lubegard is just an additive for boosting some of the crankcase fill. I primarily use it for fun at this point; no harm no foul. Potential MPG gains of course are probably negated by price point somewhat. It does have a bit of moly. Someone did a VOA, linked here:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3951216/1
It appears to be able to give some moly, calcium, phosphorus a nice shot and 3.7 TBN in an additive isn't bad. It's not meant to replace quarts of oil in the sump. I'm not sure if it's the base oil itself being esters and it mixed with another carrier or what, though. confused
Regardless, sometimes you can find the 32oz for a good price on Amazon. I got this following the dosage recommendations I can basically get 3 OCI uses out of it:
https://www.amazon.com/Lubegard-40902-Tech-Engine-Protectant/dp/B006HI8HYA/
Sometimes it's priced better in this bottle (different name same product):
https://www.amazon.com/Lubegard-30916-Heavy-Engine-Protectant/dp/B006HI8H90/
Re: Ester-based oil additives? [Re: ltslimjim] #4472624
07/28/17 02:26 AM
07/28/17 02:26 AM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
Yes, the FS Maxlife HM in 10w-30 looks like a very good oil; I use M1 HM 10w-30 in my vehicles so oil quality is not an issue. But those oils can't clean everything so I was looking to take advantage of the unique properties esters bring to the table.
Re: Ester-based oil additives? [Re: Oro_O] #4473121
07/28/17 01:37 PM
07/28/17 01:37 PM
NJ, USA
MotoTribologist Offline
NJ, USA
Diesters provide more solvency that polyol esters, but they aren't as stable (more volatile). I'm pretty sure polyol esters are the more commonly used in PCMO due to their stability and relatively good solvency.
That being said, I think Brocluno's method of rotating through quality products with differing detergent chemistry types would leave your machine pretty [censored]'n'span clean if you are concerned the M1 you're already using isn't doing that already.
Re: Ester-based oil additives? [Re: ltslimjim] #4474370
07/30/17 05:15 AM
07/30/17 05:15 AM
New York
pbm Offline
pbm  Offline
New York
[url=Ithttps://www.amazon.com/Lubegard-40902-Tech-Engine-Protectant/dp/B006HI8HYA/][url=Ithttps://www.amazon.com/Lubegard-40902-Tech-Engine-Protectant/dp/B006HI8HYA/][url=Ithttps://www.amazon.com/Lubegard-40902-Tech-Engine-Protectant/dp/B006HI8HYA/]Ithttps://www.amazon.com/Lubegard-40902-Tech-Engine-Protectant/dp/B006HI8HYA/[/url][/url][/url]
Are these 2 really the same product? I'm not doubting you Slim but I'm wondering why LG would use 2 different SKUs and call it something slightly different if they are the exact same?
'Journalism is Dead'
Re: Ester-based oil additives? [Re: Oro_O] #4474466
07/30/17 07:48 AM
07/30/17 07:48 AM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
I don't have it on hand but I recall someone reputable on the boards sharing what Lubegard responded with to this very question of what the difference was. It was simply marketing, IIRC. Probably one of the older LG threads a few years ago. It was one of those copy/paste email replies from a company.
However, lately I've noticed the regular is a better price.
Re: Ester-based oil additives? [Re: Oro_O] #4474494
07/30/17 08:22 AM
07/30/17 08:22 AM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
I found it:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/2687190/Re:_Lubegard_Bio-tech_Regular_#Post2687190
