Detroit 51 series 2 cycle diesel
by Red91. 03/25/19 01:54 PM
Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
128 registered members (555, 1nighttrain, 4WD, 928, 69Torino, 2012AccentSE, 14 invisible), 2,249 guests, and 65 spiders.
Topics286,402
Posts4,907,677
Members67,614
Most Online2,967
Mar 10th, 2019
The one time, #4471865
07/27/17 11:09 AM
07/27/17 11:09 AM
SW Florida
Taildragger Offline OP
SW Florida
In all of my years, the one time that I didn't check that the old filter gasket came off with the filter, it didn't.
Re: The one time, [Re: Taildragger] #4471879
07/27/17 11:22 AM
07/27/17 11:22 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
Thanks for the reminder. Hope nothing bad happened.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: The one time, [Re: Taildragger] #4471890
07/27/17 11:32 AM
07/27/17 11:32 AM
SW Florida
SW Florida
Couldn't add the photos but I dumped about 4 quarts of M1 on the shop floor. Ugghh!
04 F-150 5.4
73 Big Block, 4sp Corvette
15 Mazda 3
Couple of airplanes
Re: The one time, [Re: Taildragger] #4471906
07/27/17 11:50 AM
07/27/17 11:50 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
I have only had one in the past 20 years that stuck, and that was about a year ago.
I did catch it though.
Bet you never forget to check again.
At least it didn't leak out during use and blow the engine.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: The one time, [Re: Taildragger] #4471948
07/27/17 12:41 PM
07/27/17 12:41 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Oh no!
Re: The one time, [Re: Taildragger] #4472000
07/27/17 01:33 PM
07/27/17 01:33 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Had that problem a lot with cartridge filters when I was just a lil grease monkey. You knew to ALWAYS look for the gasket left up there. Now where heading back to cartridge filters and ditching the spin ons.
The Vette SB I had shoehorned into a 74 Vega had camel hump heads (2.02I) and the filter boss was for the old loaded cartridge - like your Home's #2 Fuel Oil Tank filter setup.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: The one time, [Re: ARCOgraphite] #4472041
07/27/17 02:07 PM
07/27/17 02:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Mr. Gasket makes an adapter that bolts up pin place that lets you use a FL-1A spin-on.
Did that to my ol' 283.
Re: The one time, [Re: Taildragger] #4472113
07/27/17 03:25 PM
07/27/17 03:25 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I try to make sure to always look at the old filter. If I don't, I still rub my finger around the machined metal flange to check for burrs. If there's rubber left behind, it won't be hard to find.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: The one time, [Re: Taildragger] #4472122
07/27/17 03:34 PM
07/27/17 03:34 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
An engine I worked on for quite a while had different spin on filters. One filter (turbo soakback) would leave its gasket 50% of the time. It was kind of a PITA to do, so you only did that once.
Re: The one time, [Re: Taildragger] #4472406
07/27/17 08:58 PM
07/27/17 08:58 PM
Wisconsin
WiskyBadger Offline
WiskyBadger  Offline
Wisconsin
I cut all my filters and pull off the gaskets off before I cut them. That's my safety for the stuck gasket.
11 Silverado 60k Rotella Gas Truck and Carquest filter
11 Traverse 118k Super Tech FS HM and Carquest filter
78 Chevy C10 Stepside
Re: The one time, [Re: Taildragger] #4472826
07/28/17 09:11 AM
07/28/17 09:11 AM
Palmyra, PA
kmrcstintn Offline
kmrcstintn  Offline
Palmyra, PA
got bit by this once when I was younger...took a fram ocod off & didn't check before putting on new filter (another fram ocod), start engine & almost 3 qts spill onto parking lot! landlord was [censored]...sopped up what I could and agreed to remove rest with degreaser (?simple Green?); a few times I used autolite filters (commercial frams) on the motorcycle for shorter OCI's during storage...every time the gasket stuck to engine case;each time I got into habit of looking & feeling to prevent issue
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: The one time, [Re: Taildragger] #4472866
07/28/17 09:39 AM
07/28/17 09:39 AM
Morris County NJ
steve20 Offline
steve20  Offline
Morris County NJ
You unknowingly did yourself a favor IMO--best place for M1 IS on the shop floor
Steve
Re: The one time, [Re: Taildragger] #4472879
07/28/17 09:45 AM
07/28/17 09:45 AM
Florida
johnpawl Offline
johnpawl  Offline
Florida
Complacency will do that once in a while...
17' Hyundai Tuscon 1.6T
95' Ford F150 XLT 4x4 5.0
94' Mitsubishi Eclipse 1.8
Re: The one time, [Re: Taildragger] #4473003
07/28/17 12:00 PM
07/28/17 12:00 PM
The Garden State
Whimsey Online content
Whimsey  Online Content
The Garden State
Being a long time member of BITOG I've learned to make sure the oil filter gasket is removed with the filter. Then I clean the filter mounting surface and then lube the oil filter gasket with SYNTHETIC oil, not taking any chances LOL LOL. This site has made me an*l LOL LOL!
Whimsey
Re: The one time, [Re: Taildragger] #4473080
07/28/17 01:58 PM
07/28/17 01:58 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
I never saw a gasket stick on the wrong side, whether with cartridge or spin-ons. A stuck spin-on gasket would be hard to miss if you cut the old filter apart, as I often did, or if you felt and wiped the mounting flange to be sure it was free of migrating dirt, as I usually did.
2011 Toyota Prius now at 97K
