MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
131 registered members (4WD, 69Torino, 2012AccentSE, 97K15004WD, 64bawagon, 2009Edge, 12 invisible), 2,211 guests, and 68 spiders.
Topics286,400
Posts4,907,633
Members67,614
Most Online2,967
Mar 10th, 2019
Where do I buy a PTCR for a split AC? #4471357
07/26/17 08:21 PM
07/26/17 08:21 PM
IL
Vern_in_IL Offline OP
IL
My PTCR in my Nordyne Central Air Conditioner Model NS6QD-036K blew... I think the AC was short cycled during last thunderstorm.
Where do I get one of these? I checked the compressor and it checked good. The cap checks good, the PTCR was overheating and shorted out the low voltage call line from the main indoors unit and blew it's 3 amp fuse. The fuse was blowing when I called for AC, and then I found the blown PTCR in the outdoor unit that melted into the low volt line.. The AC HV line breaker had not thrown.
Re: Where do I buy a PTCR for a split AC? [Re: Vern_in_IL] #4471370
07/26/17 08:45 PM
07/26/17 08:45 PM
IL
IL
From what I'm reading I can install what is known as a Hard start kit, install in parallel with the run cap. in the same config. as the PTCR, thoughts?
Re: Where do I buy a PTCR for a split AC? [Re: Vern_in_IL] #4471373
07/26/17 08:51 PM
07/26/17 08:51 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
I advise a quality HSK that uses a relay to remove the start capacitor from the ckt once the RPMs are high enough. Installed one on my unit a few decades ago.
Re: PTCR, you may find one locally, however not all distributers will sell OTC. Check WW Grainger also.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Where do I buy a PTCR for a split AC? [Re: sleddriver] #4471692
07/27/17 08:22 AM
07/27/17 08:22 AM
Saint John,IN
Highboy Offline
Highboy  Offline
Saint John,IN
2006 Scion tC PP/Denso
2008 Scion tC MaxLife/Fu
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2012 Hyundai Sonata Castrol Magnatec 5w30 /Oem filter
Re: Where do I buy a PTCR for a split AC? [Re: Vern_in_IL] #4472927
07/28/17 10:32 AM
07/28/17 10:32 AM
Florida
laserred96gt Offline
Florida
What year is that a unit? I don't remember last time I saw a PTCR in a unit,most condenser just have a run cap now days. A hard start would help.
2017 4Runner Limited, 44k
04 E-150, 4.6, 231K, Synblend 5w20.
11 Camry 2.5, 63K, PU 5w20.
