Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
25 registered members (2015Corolla, Char Baby, Astro14, BlakeB, DaleRider, Ablebody, 2 invisible), 716 guests, and 37 spiders.
Topics290,745
Posts4,849,459
Members66,033
Most Online3,590
Jan 24th, 2017
torque wrench out of calibration #4471317
07/26/17 07:18 PM
07/26/17 07:18 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
I just sent my Snap On 5-75 ft lbs 3/8 drive to Team Torque in North Dakota for its annual calibration like I do every year. With the light use it sees (drain plugs, intakes, I mostly use it in the 18-50 ft lb range), its probably unnecessary to do it yearly but it gives me peace of mind. They called me back today, they said it was reading high on the low side of the scale, in the 15 to 16 pound range and that it would need to be adjusted and calibrated, and they wanted the ok from me to do it. they said they do see them reading high sometimes and that after adjusting it it should be fine. I was just puzzled in regards to the high reading as the wrench is never abused, always set back to 5 lbs after use and always wiped clean with a rag. they said they could tell I always turn it down after use and that I dont abuse it, as keeping the wrench dialed high would cause it to read high. Anyone ever ran into the same situation with a torque wrench that was well taken care of?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: torque wrench out of calibration [Re: mobilaltima] #4471325
07/26/17 07:26 PM
07/26/17 07:26 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Try keeping it stored at 0 ft.lb or buy a split beam torque wrench that you don't have to do anything to when storing it.
Re: torque wrench out of calibration [Re: Trav] #4471330
07/26/17 07:36 PM
07/26/17 07:36 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
I was aaaaalways told to turn it to zero and that's what I did for years. Just the other day I heard someone caution against turning it to zero and, sure enough, Snap-On says to turn it to the lowest setting on the scale. I'm confused shrug This is almost as bad as the time I found out that PLL is a dexclone!
Re: torque wrench out of calibration [Re: mobilaltima] #4471331
07/26/17 07:40 PM
07/26/17 07:40 PM
Golden Meadow, LA
Golden Meadow, LA
I do keep it at the lowest setting, which is 5 ft lbs
Re: torque wrench out of calibration [Re: mobilaltima] #4471338
07/26/17 07:51 PM
07/26/17 07:51 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It's just how it is....Especially with click-type torque wrenches. Good for you that you have it calibrated every year. Dial-Type torque wrenches retain their calibration longer but are more expensive.
I have my 3 (1/4", 3/8", 1/2") Snap-On torqOmeters calibrated every 2 years.
I stepped into the 21st century last year & bought a digital "techwrench" torque wrench & like it so far.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
Re: torque wrench out of calibration [Re: Ethan1] #4471375
07/26/17 08:51 PM
07/26/17 08:51 PM
Trav Offline
Trav  Offline
I don't have a Snap-On but a Hazet click type the others are spit beam that do not need setting lower to store but the clicker has 0 on the scale and I set it to that, you can feel the spring go slack inside.
I guess Snap-On must have a reason, I would like to know what it is though. Maybe they are afraid someone will go beyond zero? shrug
Re: torque wrench out of calibration [Re: mobilaltima] #4471402
07/26/17 09:29 PM
07/26/17 09:29 PM
Upper Midwest by the Lakes USA
SumpChump Offline
SumpChump  Offline
I was told to not store at zero but rather at a small percentage.
Re: torque wrench out of calibration [Re: mobilaltima] #4471404
07/26/17 09:29 PM
07/26/17 09:29 PM
Port Aransas, TX
Stevie Offline
Stevie  Offline
Port Aransas, TX
I've gone back to the old beam style torque wrench. Just bought a new Craftsman a few months back.
Re: torque wrench out of calibration [Re: mobilaltima] #4471420
07/26/17 09:47 PM
07/26/17 09:47 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Trav - Sturdevant Richmont claims that "some" wrenches can have an internal part become disoriented if spring pressure is reduced to zero, maybe causing it to go out of calibration: http://www.srtorque.com/error-proofing-t...-quality-score/
Precision Instruments recommends their micrometer wrenches be "returned to the bottom of the scale", similar to what SnapOn recommends. Some brands go down to zero, others don't.
Re: torque wrench out of calibration [Re: doitmyself] #4471533
07/27/17 12:22 AM
07/27/17 12:22 AM
Trav Offline
Trav  Offline
Thanks for that, it makes sense now.
Re: torque wrench out of calibration [Re: Trav] #4471545
07/27/17 01:03 AM
07/27/17 01:03 AM
co
NissanMaxima Offline
co
Hi:
I've been considering buying a quality torque wrench like those offered by SnapOn but am curious why you don't send it back to them for calibration. I thought they offered this service when I looked into buying one a long time ago. Is it more expensive?
Re: torque wrench out of calibration [Re: mobilaltima] #4471637
07/27/17 07:33 AM
07/27/17 07:33 AM
GA
Pike51 Offline
Pike51  Offline
GA
Torque wrenches will always need to be calibrated after some use, just like anything else over time. When I worked for a tool supply company, they suggested getting them checked every 6 months with heavy use. It's not a big deal, just send it back and let them calibrate it.
1951 Chevy pickup 350/700r4
2013 GMC Sierra 1500 4x4
Re: torque wrench out of calibration [Re: mobilaltima] #4475044
07/30/17 09:54 PM
07/30/17 09:54 PM
Chicago
bowlofturtle Offline
Chicago
How much does sending it in cost? I've never done this on my 8 year old bluepoint 3/8 but i no more longer us it for engine work. Now its just some suspension stuff that doesn't need to be exact.
My toys
-05 Infiniti G35x 121k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 7k
-98 Nissan Maxima 145k
-09 Toyota Camry V6 86k
Re: torque wrench out of calibration [Re: bowlofturtle] #4483390
08/09/17 07:41 AM
08/09/17 07:41 AM
DELAWARE
Hootbro Offline
Hootbro  Offline
DELAWARE
Really depends on the particular shop you send it to. I have seen ranges of $50 - $100 depending on the style and type of torque wrench. This of course does not include shipping costs both ways nor does it include the cost of adjustment if needed.
2018 RAM 2500 Cummins 6.7L (Factory Fill 5W-40)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: torque wrench out of calibration [Re: mobilaltima] #4483415
08/09/17 08:29 AM
08/09/17 08:29 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Angle Repair... cost about $50/ea (including shipping it there) for the Snap-On wrenches I sent them.
I store the clickers at 20% of full scale, which standard practice at the aviation company I work as well. Anywhere from the lowest setting on the wrench to 20% is fine. I've heard not storing them at "zero" either because the internals can comes loose/out of alignment. However that's not the case with Snap-On, CDI and PI wrenches I've worked with.
