I am a month away from fluid and filter change on my 6 speed auto (09G). VW ATF (G 055 025 A2) is 25 and change per quart, Fuchs ATF 4400 is 11.50 and Castrol Import Multi Vehicle is 4.99. Fuchs purportedly is exactly equivalent and the Castrol is recommended for Audi part number G 055 025 A2 but not VW specifically. This is a 2009 Passat 2.0 turbo gasser with 75K.
Would the Castrol be compatible with the VW fluid?
Sure would like some expert advice!
