Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
112 registered members (53' Stude, addyguy, 240_Ed, 38Chevy454, 77GrandPrix, 14Accent, 14 invisible), 2,034 guests, and 66 spiders.
Topics286,203
Posts4,904,125
Members67,576
Most Online2,967
Mar 10th, 2019
Amsoil ATF, 60K, 04 Duramax TCase #4471166
07/26/17 04:25 PM
07/26/17 04:25 PM
Texas
dhellman12 Offline OP
Texas
First OCI since installing the transfer case pump upgrade kit from Merchant.
Make/Model: GM Transfer Case
Vehicle: 2004 Chevy 2500HD
Code:
OIL		Ams ATF	Ams ATF	Maxlife
MILES IN USE	60,000	48,337	49.981
MILES		208,629	148,629	99,996
SAMPLE TAKEN	7/12/17	8/14/13	7/19/11
ALUMINUM	21	12	23
CHROMIUM	1	0	0
IRON		138	57	89
COPPER		39	38	50
LEAD		67	39	84
TIN		1	0	0
MOLYBDENUM	0	0	1
NICKEL		7	3	9
MANGANESE	14	28	37
SILVER		0	1	0
TITANIUM	0	0	0
POTASSIUM	2	3	2
BORON		230	261	109
SILICON		76	8	14
SODIUM		6	8	10
CALCIUM		231	260	271
MAGNESIUM	303	131	246
PHOSPHORUS	542	614	328
ZINC		8	6	21
BARIUM		0	0	1
SUS @ 210	52.4	49.8	44.9
cSt @ 100	7.99	7.21	5.68
FLASHPOINT	460	455	385
WATER %		0.0	0.0	0.0
INSOLUBLES %	TR	0.1	0.2
TAN		2.8	1.9
Blackstone Comments:
We think this is about the longest you'll want to run between changes with this transfer case. Iron isn't high compared to averages, but the wear rate is showing a substantial increase in this report relative to the previous sample. The viscosity also tested a little thick, which can happen during extended oil runs. Insolubles are better though at just a trace, so oxidized solids aren't excessive this time. The TAN shows more acidity at 2.8, but that is not overly acidic in our opinion. Stay around 60K miles for the next interval for a good comparison to this report.
05 Kawasaki BF750 - 277hrs
12 Jeep 3.8L - Amsoil ASL 5w30 68K
04 DMax 6.6L - Amsoil AME 15w40 230K
00 WS6 5.7L - Amsoil ASL 5w30 254K
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4471240
07/26/17 05:46 PM
07/26/17 05:46 PM
NY
demarpaint Offline
demarpaint  Offline
NY
How many miles is the recommended interval for the T-case? How long does Amsoil say to run the fluid?
God Bless Our Troops
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4472550
07/27/17 11:13 PM
07/27/17 11:13 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4472808
07/28/17 08:57 AM
07/28/17 08:57 AM
Texas
Texas
I'm not sure on the manufacturer recommendation for service interval, I'll take a look and see what I can find. I've done 30K on past vehicles before I started doing UOA with samples.
The product line is coded as ATF from Amsoil, it's their multi-vehicle transmission line (http://www.amsoil.com/shop/by-product/tr.../?code=ATFQT-EA).
SERVICE LIFE
Normal Service: Follow the vehicle manufacturer's normal-service drain interval.
Severe Service: Double the vehicle manufacturer's severe-service drain interval.
Change at the vehicle manufacturer's recommended drain interval outside U.S. and Canada.
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4472813
07/28/17 09:01 AM
07/28/17 09:01 AM
Texas
Texas
Ok just found it in the manual. 50K is the OEM recommendation for transfer case fluid change.
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4475513
07/31/17 12:11 PM
07/31/17 12:11 PM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I don't have enough data on this piece of equipment to comment about ranges and trends. Too few people take UOAs on these. Wish I could help you more, especially since I also have one in my barn! I am debating on when to change lube; approaching 50k miles total vehicle, but only 40k since I did my pump-rub elimination kit at 10k. I'm running Mobil 1 ATF in mine.
The only thing I can say about this UOA you've posted is that the wear rate just about doubled. How much of that is due to the extra 10k miles we don't know. I suspect some of it is due to the rework maybe? I've not done the M/A piece, but I've done two others using the "plate" style upgrade. But it's an easy remove/replace; I don't know why that would make Fe jump up as it has here.
On a completely unrelated note, dhellman12, have you ever had to deal with an oil leak at the rear of the engine block, suspected to be from the turbo oil drain return line? It looks like a nightmare to get to. Either pull the cab or pull the tranny to make it "easier" (as if doing either of those could be called easy in the first place .....)
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4476547
08/01/17 01:44 PM
08/01/17 01:44 PM
Texas
Texas
I was thinking the same thing regarding the kit and the 2x wear, not sure why/how that could be related. Guess I'll know more after another 60K run.
So far I have not had to deal with an oil leak on the Duramax, so can't really help you on that one. Pulling the cab or tranny sure doesn't sound like fun to me. I know Merchant usually has some good how-to videos on some of the more common dmax issues, not sure they have anything to help with this one though. Good luck with it.
Did mean to ask if you've done any after market tuning on yours? I have just the standard Hypertech tune on my truck today, but was wondering if it would be worth trying to find someone who could do a more customized tune for my truck and bolt-ons. Even if I did go that route, finding someone I could trust would be another challenge...
Re: Amsoil ATF, 60K, 04 Duramax TCase [Re: dhellman12] #4477130
08/02/17 06:38 AM
08/02/17 06:38 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
No sir, my truck is bone stock in terms of performance enhancements.
I don't begrudge anyone who wants more power or economy; some of the tuners are very decent.
But I've been plenty happy with the torque and economy my truck has from stock, so I've never been interested in getting any power upgrades.
I have what I consider to be reliability enhancements:
pump rub eliminator kit (plate style)
power steering fluid cooler
rear diff cover fins for cooling
tranny cooler inverted
PCV reroute
EGT gauge (with no tuner, I didn't "need" it; it was a toy I wanted).
Regarding the EGT gauge - there was a lot of debate several years ago about how much heat the stock Dmax was putting out, and how that might affect the pistons, etc. GM's official statement at the time was that the Dmax (the LBZ, which is what I have) can take 1350 degF as a pre-turbo temp, as a sustained heat cycle. IOW - it can run at that temp all day long and not melt things. But guys with tuners are obviously getting above that. So as a baseline, I wanted to know what the "real" stock tune cycles would do. Pulling our RV out west in summer, we went over the Rockies in CO and all the valleys and canyons of UT and AZ and back up. There were times when I had the throttle pinned to the floor for minutes on end. I will pulling the RV uphill and passing big-rigs like they were standing still. And yet, the pyrometer never showed anything greater than 1320F at WOT. I guess the GM engineers did a good job of controlling the fuel flow and heat management after all! Now, because I've convinced myself the stock tune will never exceed the temp limits, I just ignore the gauge; it's a device that has no real value any longer for me, but taking it out really doesn't make things any better, so I just leave it there. If you are going to run a tuner, it is an absolutely necessity if you ask me. Some tuner brands (Banks is one I can think of) will assure you that their tunes don't exceed safe limits, but I think you have to use a pyro gauge in-line so that their programming can "track" the EGT and know when to back off? I cannot assure you of that; it's just something that I would be VERY cautious about prior to running a tune. The number one concern about any tuner I have is EGTs and melting pistons. As long as you can assure it's not happening, that's great! I've just never been unhappy with the stock tune; the torque and economy are more than enough for me.
Another side note -
Check under your truck for corrosion! My truck has been absolutely ravaged by the salt/water of the mid-west. So bad that I've had to replace my brake lines, tranny lines, fuel lines, fuel cooler and hydroboost pressure lines. Also, the cast iron metal of my AAM rear axle has rusted and flaked off so badly that about 50% of the material is gone in some areas! I am not exaggerating; I have pictures to prove it! YIKES!
