PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
125 registered members (2015_PSD, 01rangerxl, 2K2AcuraTL, 14 invisible), 1,991 guests, and 61 spiders.
Topics286,162
Posts4,903,349
Members67,569
Most Online2,967
Mar 10th, 2019
STP S-10590, CUT OPEN #4471088
07/26/17 02:36 PM
07/26/17 02:36 PM
In the shop
53' Stude Online content OP
53' Stude  Online Content OP
In the shop
Afternoon folks smile
Filter and ST Synthetic 5w30 off of a friends 2015 F-150 extended cab work pickup for 5,000 miles. Put on a Federated filter he supplied and more ST Synthetic he brought. Enjoy the pics. Truck has 80,xxx miles on it also.
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471096
07/26/17 02:46 PM
07/26/17 02:46 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Interesting, I was expecting a Champ ecore made STP in this application. But this one is a M&H Puro made blue can STP. Knew 'some' AZ were using Puro made STP and iirc seems you posted one before from that region.
What I can see, this one looks quite good at 5k miles.
Thanks for c&p.
Re: STP S-10590, CUT OPEN [Re: Sayjac] #4471102
07/26/17 02:53 PM
07/26/17 02:53 PM
In the shop
In the shop
Thanks for c&p.
You're very welcome sir smile
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471121
07/26/17 03:16 PM
07/26/17 03:16 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Heh heh, You just wasted a perfectly good oil filter grin2
Thick oil is better grin2
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471126
07/26/17 03:25 PM
07/26/17 03:25 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Good looking filter
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: STP S-10590, CUT OPEN [Re: Sayjac] #4471194
07/26/17 04:52 PM
07/26/17 04:52 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Thanks for c&p.
I was thinking the same thing. Did not know Puro was doing STP filters.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: STP S-10590, CUT OPEN [Re: andyd] #4471271
07/26/17 06:19 PM
07/26/17 06:19 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yeah, he might want to go 2x oil OCI's on his filters
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471272
07/26/17 06:20 PM
07/26/17 06:20 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
These are the exact same as a 10575 (FL-500 size) - just longer?
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471274
07/26/17 06:21 PM
07/26/17 06:21 PM
In the shop
In the shop
Same as FRAM 10575 yes
Re: STP S-10590, CUT OPEN [Re: blupupher] #4471306
07/26/17 07:05 PM
07/26/17 07:05 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Thanks for c&p.
Another member with a display location out west (Idaho iirc) posted a Puro made blue STP a year or two ago. In this area they are still fram filtration what some call frampion filters. In this application the ff filter is an ecore.
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471429
07/26/17 09:58 PM
07/26/17 09:58 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
STP Filters were Ecores long before Fram & Champion Labs were owned by a common company.
All Motorking's posting about blue can STP Filters being offshored certainly appears to be inaccurate, whether Ecore or Purolator.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: STP S-10590, CUT OPEN [Re: 53' Stude] #4471631
07/27/17 07:24 AM
07/27/17 07:24 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
As Champ Labs alone previously (before ff) provided all AZ STP blue can filters it's true that some were "ecores" using the nylon/plastic cage. Others however were Champ classic metal endcap construction with a separate bypass. The S6607, and S2808 were examples of Champ classic construction. The 3614 has been an ecore using a combo valve. The old Super Tech filter line was very similar, but ST offered a classic construction 7317 application too.
One change in STP blue can supplied by 'fram filtration' fram/champ made filters is the S2808 now Fram fiber endcap construction. The S6607 still classic construction, the 3614 still an ecore. The ff made STP made filters still sold in AZ's locally, and the topic filter S10590 is an ecore.
Seems the information provided that all AZ STP blue cans had been 'off shored' and those ff made left old stock, was inaccurate. I found the topic S10590 with a manufacture date first week this month.
