ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
103 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Dexron 6 in a mMopar 904?. #4470797
07/26/17 10:17 AM
07/26/17 10:17 AM
Margate England
Claud Offline OP
Claud  Offline OP
Margate England
I want to drop the pan and change the filter onmy 904 transmission in my 1984 Chrysler Fifth Avenue.
I have around 7 liters of Dexron 6 available, will it be ok to put it in?. There is nothing wrong with the transmission as far as I'm aware, the oil is a good color and smells fine.
If Dexron 6 won't do, what will?.
Thanks in advance.
Claud.
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4470813
07/26/17 10:29 AM
07/26/17 10:29 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
NO!
Those transmissions do not like anything but the correct spec'd fluid.
There will be something wrong with the transmission if you put in the wrong fluid. They will not last with Dex/Merc.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4470836
07/26/17 10:42 AM
07/26/17 10:42 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Get the right fluid, and don't take chances.
God Bless Our Troops
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4470854
07/26/17 11:04 AM
07/26/17 11:04 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
<sigh>
YES, Dex VI is OK in that application, and here's why:
Dexron III was the original specified fluid for an 80s 904, and Dexron VI is PERFECTLY FINE because its long-term viscosity stability is so much better than Dexron III. An 80s 904 was built before there was any such thing as Mopar ATF+3 or +4 series fluids which were developed for the A604 (later 41TE) and followint transaxles. The 904 and 727 both work just fine with ATF+, but they dont NEED ATF+
DO NOT assume that just because its a Chrysler transmission that it has a special need for ATF+ type fluids. 40 years worth of Chrysler transmissions existed before ATF+ fluid existed. The old rear-drives do not need it, and to be quite honest even the 90s-built truck rear-drives (4xRH) that were based on the 904 and 727 don't really need ATF+ even though that's what they were filled with at the factory.
Personally, I tend to use Mobil 1 ATF in my old 727s, but Dexron VI would be my next choice and ATF+4 would be my third option.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4470930
07/26/17 11:54 AM
07/26/17 11:54 AM
California
nthach Offline
nthach  Offline
California
Chrysler didn't call for anything special in older Torque-Flite series, but they did call for it later on. Dex 6 should work fine.
ATF+3/4 came into the picture when the FWD trannies with electronic controls came onto the market.
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4470958
07/26/17 12:12 PM
07/26/17 12:12 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
On all my DEX6 jugs, I see nothing pertaining to Chrysler products. I myself would go with ATF 4 even on all the older units.I would research this, not on a forum where you will get a dozen different answers.
The "thinking" man's friend.
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4471008
07/26/17 01:09 PM
07/26/17 01:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I always ran a good Type-F in all my Torque-Flite 904's and 727's
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4471103
07/26/17 02:54 PM
07/26/17 02:54 PM
USA
oldhp Offline
oldhp  Offline
USA
When putting shift kits in Mopar 727's it was common practice to put 4qts Ford type F back in. Made the clutches stick faster for better, less slipping, gear changes.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4471188
07/26/17 04:49 PM
07/26/17 04:49 PM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
If the original spec for the ATF was Dexron 3, then Dexron 6 is a direct replacement for Dexron 3.
Re: Dexron 6 in a mMopar 904?. [Re: oldhp] #4471475
07/26/17 10:56 PM
07/26/17 10:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yep, I guess you and me were reading the same tech articles way back when thumbsup
Re: Dexron 6 in a mMopar 904?. [Re: Claud] #4471493
07/26/17 11:20 PM
07/26/17 11:20 PM
CT
CrAlt Offline
CrAlt  Offline
CT
ATF+ came out in the 90's to bandaid shuttering problems with the then new electronic lockup TC OD transmissions.
Your 904 came with Dexron.
Torqueflights will run on Type F...but if your just dropping the pan there will still be tons of Dex left up in the case and converter. I wouldn't mix personally. I ran type F in a 727 that I did some bubba hopups on (chucked accumulator spring, line pressure cranked, 5.0 kickdown lever etc). It worked fine but I wish I never switched. I was always worried about forgetting and topping off with DEX by mistake.
Dexron 6 is backwards compatible with all other dexrons before it.
Don't forget to adjust the bands when your in there cool
'16 Wrangler JK PYB 5w20 / MO 349
'77 Corvette JG HR2 10w30 / AC PF454
'83 Trans-Am JG HR2 10w30 / AC PF454
'91 Dodge D150 QSGB 10w40 / AC PF13
Re: Dexron 6 in a mMopar 904?. [Re: Linctex] #4471574
07/27/17 05:09 AM
07/27/17 05:09 AM
NSW Australia
peejaycruiser Offline
NSW Australia
I'm wondering what the worst case scenario would be to doing the same with the 4L60E?
02 Subaru Liberty RX 2.5 Nulon Fast Flowing 10W-40 OEM Filter
96 Toyota 80 Series 1HZ Sakura C-1112 Nulon High Torque 15w-40
Re: Dexron 6 in a mMopar 904?. [Re: peejaycruiser] #4471851
07/27/17 10:49 AM
07/27/17 10:49 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
DESTRUCTION.
Re: Dexron 6 in a mMopar 904?. [Re: peejaycruiser] #4472516
07/27/17 10:44 PM
07/27/17 10:44 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The stock Reaction Sun Shell & Forward Sprag don't like shock.
2001 Chevy Camaro L92/4L80E
Re: Dexron 6 in a mMopar 904?. [Re: Linctex] #4473579
07/29/17 01:36 AM
07/29/17 01:36 AM
USA
oldhp Offline
oldhp  Offline
USA
Yep, Straight from B&M Trans Shift Kits.
