Clear plastic scratch remover?
by Quattro Pete
55 seconds ago
Parking wars show.
by Chris142
1 minute 4 seconds ago
set for years
by 93cruiser
8 minutes 55 seconds ago
Looking to replace 2005 Sienna with SUV
by i6pwr
50 minutes 44 seconds ago
Trying to fix chainsaw
by turtlevette
Today at 06:48 PM
tire rotation
by marine65
Today at 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
Today at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
Today at 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
Today at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
106 registered (69Torino, Astro14, 93cruiser, 14Accent, 2015_PSD, 11 invisible), 1494 Guests and 56 Spiders online.
65303 Members
67 Forums
285878 Topics
#4470778 - 07/26/17 09:58 AM Patch for trans cooler line to limp to shop?
HoosierJeeper Offline
Loc: WI
Follow up to this thread (on my 96 Cherokee, 4.0 AW4 trans)
https://bobistheoilguy.com/forums/ubbthr...coo#Post4470396
The leak is in the rubber part of the line (circled in red)
[img]http://i.imgur.com/xIleDKW.jpg?2[/img]
The shop is about 5 miles away, just in town driving. Would it be foolish to try and splice it together to drive it to the shop? I was thinking either getting a barb and a few hose clamps or trying some rubber adhesive tape. Or should I just get it towed?
Thanks!
Edited by HoosierJeeper (07/26/17 10:00 AM)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4470804 - 07/26/17 10:24 AM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
funflyer Offline
Loc: Northern Arizona
I'd pick up a short piece of heater hose (2") with approx the same ID as that hose OD, split it, wrap it around that hole and secure it with a hose clamp or two. It may leak some while you drive to the shop but just top off the fluid before you go, it'll be fine.
Edited by funflyer (07/26/17 10:25 AM)
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
#4470832 - 07/26/17 10:39 AM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
John_VT Offline
Loc: Vermont
Barbed fitting and hose clamps would be all I'd do. Top off and on the road again.
14 crosstrek 5 spd.Milesyn sxr 0-20
98 k1500 suburban 5.7L.Milesyn sb 5-30
03 Pontiac Montana. St 5-30
01 mojave,86 trx350,2-110cc atv's
#4470844 - 07/26/17 10:52 AM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
NYEngineer Offline
Loc: NY, NY
I'd cut the line right at the leak and slip a hose over it and clamp it. It'll get you there. I believe trans cooler lines only have a max of maybe 15 psi.
#4470857 - 07/26/17 11:07 AM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
440Magnum Offline
Loc: Texas
SAE J30R9 fuel injection hose would be the best option. It can handle the heat, pressure (depending on vehicle, you can have ~60PSI in the cooler lines), and ATF chemistry. SAEJ30R7 fuel line would be a second choice for a short limp-in.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4470897 - 07/26/17 11:32 AM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
ArcticDriver Offline
Loc: USA
Follow the good advice above on a temp repair and be sure to check your ATF fluid level before you start driving to be sure you haven't lost alot already.
Multiple Diesel and Gasoline vehicles
#4470943 - 07/26/17 12:00 PM Re: Patch for trans cooler line to limp to shop? [Re: John_VT]
Linctex Offline
Loc: Waco, TX
100% - I've even done this with hydraulic hoses!! (turned out to be a permanent repair, too)
#4470961 - 07/26/17 12:14 PM Re: Patch for trans cooler line to limp to shop? [Re: Linctex]
John_VT Offline
Loc: Vermont
Yup I should have specified that would be a semi-permanent fix. Also was thinking it's a good time to put a inline filter in
#4471184 - 07/26/17 04:46 PM Re: Patch for trans cooler line to limp to shop? [Re: HoosierJeeper]
Loc: WI
Thanks for the help everyone. Got a piece of bigger hose to wrap around it (O'reilly's just gave me a piece from the scrap bin) and 4 hose clamps, made it just fine to the shop.
