Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
103 registered (bdcardinal, Balrog006, AITG, 2015_PSD, 11 invisible), 1441 Guests and 32 Spiders online.
65303 Members
67 Forums
285882 Topics
#4470580 - 07/26/17 04:25 AM Eurol Actence 5W-30 vs Motul Specific vs ELF
Al79 Offline
Loc: Ireland
Hi All,
First post in the forum, I have been reading you guys for a while, nice atmosphere!
I am looking for a bit of advice. I need to change the oil and I am considering these 3 alternatives:
Eurol Actene 5W30
Density at 20C : 0.8468 kg/l
Viscosity, kinematic at 40C: 69.7 cSt
Viscosity, kinematic at 100C: 12.1 cSt
Viscosity Index: 172
Viscosity, dynamic (CCS) Base number: 7.8 mg KOH/g
Sulphated ash: 0.51 wt%
Flash point : 209 C
Pour point: -42 C
Motul Secific 0720 5W-30
Density at 20C (68F) : 0.850
Viscosity at 40C (104F): 68.1 mm2/s
Viscosity at 100C (212F): 11.9 mm2 /s
HTHS viscosity at 150C (302F): 3.6 mPa.s
Pour point: -36C / -32.8F
Flash point: 224C / 435.2F
Sulfated ash: 0.49 % weight
TBN: 6.0 mg KOH/g
ELF Solaris 5W30 ( I found the tech specs in here )
TBN 7,17
TAN 1,63
Ash 0,47
PP -46C
FP(open) 242C
CSS -30C 5683
NOACK 9,5
Sulfur 0,129%
It is obviously for a diesel engine with DPF. I change the oil myself so the difference in price is not an issue. The Eurol is considerably cheaper than the other two, and it has the highest TBN... I am confused. Which is one is the best based on the tech specs?
Thank you!
#4470652 - 07/26/17 07:43 AM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
Virtus_Probi Offline
Loc: New England
Pour and flash points are not really especially meaningful in an engine, but I do like to see a big spread between the two temperatures...ELF wins that.
I don't know if NOACK loss is a big concern for diesel engines, but the ELF's 9.5% is a decent result and not seeing this provided when I research an oil always make me wonder if it's not very good. I would pick the ELF oil based upon the information you are able to provide.
Have you consider M1 5W30 ESP? I have run this on and off in my gas DIT engine due to its low NOACK loss (around 6%) and low ash/calcium, although it has slightly more ash than your oils above at 0.6%.
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4470662 - 07/26/17 07:51 AM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Virtus_Probi]
Al79 Offline
Loc: Ireland
Thanks for the response. Does the M1 5W30 ESP meets renault RN 0720? It needs to meet ACEA C4 I think.
Thank you
#4470714 - 07/26/17 08:57 AM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
drtyler Offline
Loc: GA
Mobil 1 5W30 ESP is ACEA C3 and does not have the Renault 0720 spec.
Looks like Mobil Super 3000 Formula R 5W-30 carries ACEA C4 and the Renault 0720 spec.
The NOACK, flash, and pour points certainly look good on the ELF oil, but I would have no problem running the Motul either.
Thank you
#4470727 - 07/26/17 09:13 AM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: drtyler]
Loc: New England
I would use which ever oil meets the spec and provides the least damage to my wallet!
Thank you
Looks like 5W30 ESP is C2/3 mid SAPS rather than the C4 low SAPS you need.
I am surprised that 0.6% is mid SAPS, but it is what it is! Sounds like the OPer should stick with an oil from the list above.
Last Change;
#4471059 - 07/26/17 02:01 PM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
chrisri Offline
Loc: Rijeka, EU
Any would do since they all meet the specs. Never heard of this Eurol company, but their site and oil finder looks legit. If the price difference is big enough and you're doing the OC by yourself use that and cut the OCI by 2K km. If there is any quality difference between them (which I doubt) this will be mitigated by shorter OCI.
Another option is Shell Helix Ultra Professional AR-L 5w30. Shell often is priced correctly, if so , look no further.
Cheers.
99 FIAT Punto Sporting 16v MST 5w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
#4471069 - 07/26/17 02:15 PM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
Al79 Offline
Loc: Ireland
Thanks all for the replies. Based on the specs, it looks like any of 3 options could be valid as they all meet RN 0720. Try and error then I guess.
Since Eurol has the highest TBN confused , is well priced, I can get it at my local autoparts shop and I do it my self, I think I will give this a go.
Thanks again.
Edited by Al79 (07/26/17 02:16 PM)
#4471419 - 07/26/17 09:46 PM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
1JZ_E46 Offline
Loc: Oregon
The Elf oil clearly contains a better quality base stock than the other two, based on its low pour point and high flash point. Elf is part of Total, which is one of the largest oil companies in Europe. That would be my choice.
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4472109 - 07/27/17 03:20 PM Re: Eurol Actence 5W-30 vs Motul Specific vs ELF [Re: Al79]
DS9 Offline
Loc: Belgrade, Serbia, Europe
Here, in Easthern Europe - Total engine oils (Quartz), especially Elf`s (Evolution) is one of the cheapest imported engine lubricants, among majors. Comparable Motul (Shell, Mobil, Castrol...) is about 20% or more higher in price.
Btw, Solaris FE is an older name for RN0720 Elf`s oil. They changed series names in 2013-2014. If you find these on the market it is an older stock.
New/recent name for the same (reformulated) oil is Evolution Full-Tech FE.
http://www.total-distributor-partners.com/media/66811/evolution_full-tech_fe_5w-30_042015_en.pdf
Anyway, I think your choice of RN0720 approved eurol is excellent.
Edited by DS9 (07/27/17 03:26 PM)
