Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
94 registered members (01rangerxl, 2015_PSD, 3Aone, -SyN-, 87sammy, 10 invisible), 1,821 guests, and 41 spiders.
Topics290,890
Posts4,851,970
Members66,047
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
2eha and toyota #4470556
07/26/17 01:18 AM
07/26/17 01:18 AM
FL
Deontologist Offline OP
FL
I have put SuperTech's "universal" coolant in two of my Toyota vehicles. I read on the label of the ST bottle that it contains 2-EHA. From what I understand, 2-EHA eats at silicone seals. I also read that Honda hates 2-EHA, and Toyota avoids it.
1) How screwed am I? I'm looking to keep both of the cars for about another 50k miles or so (both are 150k and over 10 yrs old).
2) Has anyone else used 2-EHA containing coolant in their car?
3) How can ST advertise a "universal" coolant when it's technically not?
Re: 2eha and toyota [Re: Deontologist] #4470566
07/26/17 02:12 AM
07/26/17 02:12 AM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
If you don't mind flushing it out then I would get some Zerex red coolant which is supposed to be exactly like toyota red and just put that in. Otherwise I wouldnt worry too much.....but if I was looking at buying your used vehicle I would walk away if it didnt have red coolant in it...
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: 2eha and toyota [Re: Deontologist] #4470568
07/26/17 02:52 AM
07/26/17 02:52 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Switch over to Prestone Dexcool. I've never had any problems with it. Mix it 50/50 with distilled water.
Re: 2eha and toyota [Re: Deontologist] #4470590
07/26/17 04:59 AM
07/26/17 04:59 AM
New York
pbm Online content
pbm  Online Content
New York
Thousands of Toyota owners have used Dexclones without any problems.
I wouldn't worry about it.
ST Universal used to be made by Old World Industries (makers of PEAK) although I'm not sure if that is still the case....at any rate I'm sure it's a quality product.
'Journalism is Dead'
Re: 2eha and toyota [Re: pbm] #4470605
07/26/17 06:04 AM
07/26/17 06:04 AM
TX
mooferz Offline
mooferz  Offline
TX
According to the SDSs, looks like it's made by Prestone nowadays.
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
Re: 2eha and toyota [Re: Deontologist] #4470612
07/26/17 06:12 AM
07/26/17 06:12 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
According to known information about 2eha and universal AFs your basic premises listed are correct.
1) Might be or maybe even likely fine for the ~50k you state. As you already did it unless you want to do a complete flush/exchange, might as well go with it.
2) Personally have avoided and avoid universal AF containing 2eha in non Dex spec'd vehicles. I'm sure others have used universal AFs in Toyotas, can't speak to their results. I am currently running Peak Global Lifetime Universal OAT (no 2eha) in an 01 Tacoma three plus years, original radiator, doing fine.
3) ST advertising as 'Universal' breaks no law. In fact the greatest amount of AP store private label and other 'universal' labeled AFs are the same as ST, ie., an OAT AF containing 2eha. Peak Long Life is an example of a non store brand that would be the same or similar to ST. "Iirc", seems Old World owner of Peak brand makes ST, seems the MDSD sheet might make reference to that.
EDIT. Saw comment above. Perhaps ST has changed makers/suppliers, but doesn't change main point about containing 2eha.
Re: 2eha and toyota [Re: Deontologist] #4470635
07/26/17 07:12 AM
07/26/17 07:12 AM
socal
barkingspider Offline
socal
When I had my Pontiac Vibe (same as the Toyota Matrix), I flushed the old coolant and used dexcool. It worked perfect. I wouldn't worry about using ST coolant. U should be good to go
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2eha and toyota [Re: Deontologist] #4470904
07/26/17 11:34 AM
07/26/17 11:34 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
I used peak/prestone in a Honda Accord I used to have and had a hose eat itself and various leaks started. It was high mileage though, and it might have happened regardless.
The Corolla in my signature has original WP, radiator, hoses in fact it's all pretty much original except serpentine belt tensioner, intake gasket and wear items. I used Zerex Asian drain and fill every 3 years starting at the 6th year.
1997 Maxima 181k, Edge 10w30, K&N HP-1003
2004 Corolla 191k, VWB 5w20 + SSS 10w40, MGL4967
Re: 2eha and toyota [Re: Deontologist] #4470947
07/26/17 12:06 PM
07/26/17 12:06 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
For no 3, their definition of "Universal" and your definition of "Universal" are different?
  • 2017 Toyota Sienna
Re: 2eha and toyota [Re: Deontologist] #4470966
07/26/17 12:23 PM
07/26/17 12:23 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
In the same AF section as ST, WM now sells Valvoline Asian Vehicle AF for ~$12/gal, it's the same as Zerex Asian Formula. Asian PHOAT AF perfect for Toyotas. Like the Asian OEM AFs comes as a premix.
Likely doesn't help with your question. Just pointing out there are many reasonably priced same as OEM 'type' aftermarket AFs that generally now can be easily found.
Re: 2eha and toyota [Re: Deontologist] #4471501
07/26/17 11:29 PM
07/26/17 11:29 PM
FL
FL
So I'm really confused now, and I don't know whether I should not worry about it or flush it out soon and replace it all with some Zerex Asian or equivalent.
I think I might flush it out with Zerex in the next few weeks just for some peace of mind. Just wish that there was a definitive answer. Is there a Toyota or Honda rep on the forums somewhere?
Re: 2eha and toyota [Re: Deontologist] #4471506
07/26/17 11:38 PM
07/26/17 11:38 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
It doesn't matter. BMW uses 2-eha, millions of cars are not running OEM coolant. If you are going to worry, flush it and move on. You will never rest easy while it is in there it sounds like.
Re: 2eha and toyota [Re: Deontologist] #4471522
07/27/17 12:13 AM
07/27/17 12:13 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: 2eha and toyota [Re: Deontologist] #4473791
07/29/17 10:26 AM
07/29/17 10:26 AM
FL
FL
The more I think about it, the more I might just leave the Super Tech in there. Because I've looked high and low or any official statement from Honda and Toyota about 2-EHA, and despite what people have said on forums like BITOG, neither of them have actually issued any official statement regarding 2-EHA.
The 2-EHA controversy seemed to have started with a few lawyers representing clients who claimed their cars were damaged by DexCool. And as we all know, lawyers tend to stretch the truth sometimes.
Re: 2eha and toyota [Re: Merkava_4] #4475018
07/30/17 09:28 PM
07/30/17 09:28 PM
Austin, TX
MaximaGuy Offline
MaximaGuy  Offline
Austin, TX
Worst advice. Dexcool will gel and kill your cooling.
My brother had a Honda with 168K miles and he took it to Sears Auto for his tires and they told him the coolant was in bad condition.
So they dumped Dexcool and 5K miles later the engine was in flames on 101.
OEM is the only way in the cooling department.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Page 1 of 3 1 2 3
