Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
41 registered members (Bjornviken, Ablebody, andyd, 6 invisible), 954 guests, and 39 spiders.
Topics290,743
Posts4,849,426
Members66,033
Most Online3,590
Jan 24th, 2017
A/C Leak Detector #4470465
07/25/17 09:51 PM
07/25/17 09:51 PM
Central Texas
borgward Offline OP
borgward  Offline OP
Central Texas
Need help choosing ultra violet leak detector light. I had my 2013 cars AC system serviced. They evacuated the system and recharged it with refrigerant that had a dye in it. said they could not find the leak and to bring it back in a week or two and they would check again. I brought it back and they were done in a few minutes and did not find a leak. There is a leak, or I would not have needed to have it recharged. Our 99 Tracer is still blowing ice cubes so I don't think its rubber hoses. I suspect the culprit is the evaporator. You can't get to it in the amount of time they took to check for a leak.
I plan to get a UV light detector tool and look at the evaporator myself. I saw a Walmart kit with penlight and yellow goggles in the 10 to 20 dollar range. Also saw stuff in the 70 to 200 dollar range.
Any advice on using these things?
Re: A/C Leak Detector [Re: borgward] #4470484
07/25/17 10:15 PM
07/25/17 10:15 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Sorry, no advice on that, but they do make sniffers too. A cheapo on eBay might be worth a try into the ducts and around joints.
Re: A/C Leak Detector [Re: borgward] #4470494
07/25/17 10:32 PM
07/25/17 10:32 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
WF-502B ultraviolet
Cheap $10 by itself, $18 with 2 batteries and charger. Probably not the fanciest, but it works great for me when using UV dyes.
Sniffers, all I can say is I like heater types vs halogen detectors. False positives greatly annoy me.
Re: A/C Leak Detector [Re: borgward] #4470501
07/25/17 10:51 PM
07/25/17 10:51 PM
Boulder, Colorado
boulderdentist Offline
Boulder, Colorado
Just a thought, five years ago had an evac and recharge, they put in dye and told me it might have a slight seep at the compressor shaft. I have also read there is a slight seep at the shaft to keep it lubricated? They said to come back if it quit cooling but luckily it has not in the five years since. You might be correct about the evaporator, I would not even know how to access it for visible leak check. I have an inexpensive UV flashlight to check for pet urine, have been told it works fine for AC dye as well. (Less than $10.00)
Good luck!
Re: A/C Leak Detector [Re: borgward] #4470553
07/26/17 01:06 AM
07/26/17 01:06 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I was going to recommend a brand called "Tracerline," but being that your car is called a "Tracer," this post becomes an unintended pun. grin2
Re: A/C Leak Detector [Re: borgward] #4470595
07/26/17 05:15 AM
07/26/17 05:15 AM
Maine
wormwood1978 Offline
Maine
Have both a cheap ebay blacklight flashlight and sniffer, both are perfect for what you're looking for. Two links below are exactly what I purchased this year and used to work on my ac system:
http://www.ebay.com/itm/21-LED-UV-Ultra-Violet-Flashlight-Blacklight-Aluminum-Torch-395nm-AAA-Batteries-/172793199468?hash=item283b46fb6c:g:lccAAOSwnK9ZUMxb
http://www.ebay.com/itm/AC-Refrigerant-Leak-Detector-Halogen-R134a-R410a-R22a-Air-Condition-HVAC-Checker-/201672491583?epid=633507198&hash=item2ef49e023f:g:OsgAAOSw5bFZZSSK
Re: A/C Leak Detector [Re: borgward] #4470633
07/26/17 07:07 AM
07/26/17 07:07 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
My Rav4 also has a refrigerant leak. I put the dye into it and bought the yellow glasses and special flashlight. Still can't find the leak.
Good luck!
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: A/C Leak Detector [Re: borgward] #4470833
07/26/17 10:39 AM
07/26/17 10:39 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
The only A/C leak that I have ever actually found was from one of the ports, and even then it was because I could hear it leaking. Good luck with that! On an old car I usually suspect the compressor shaft.
http://www.feoa.net -> for your Tracer
Re: A/C Leak Detector [Re: borgward] #4470852
07/26/17 10:58 AM
07/26/17 10:58 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The fancy detectors from Robbins are not cheap. (I think thats the name). But they have a sensor on a wand. That is what you want. Highly sensitive. Needs to be done in garage with all doors shut. Should not need to run the vehicle. Outside wind will cause problems with finding a leak.
You can try a dye and use yellow glasses and UV light.
Look for oily areas. That will be the leak. The high and low pressure port valves are often the problem.
Do not add leak stop of any kind.
2015 Ford F250 w/Powerstroke
