Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
81 registered members (beanoil, avi1777, ARCOgraphite, Bailes1992, BeerCan, Berny, 8 invisible), 1,649 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
Kohler 52-050-02 oil filiter cross reference #4470293
07/25/17 06:17 PM
07/25/17 06:17 PM
PA
Patrick0525 Offline OP
PA
Looks like a Fram Ultrta XG3614 is a good cross reference. Any problems problems choosing the Fram Ultra over the Kohler?
I read the the Fram 3614 pressure relief is 12 PSI. Is that a problem?
The specifications:
HT: 3-1/8-inch, outside diameter 3-inch, Seal outside diameter: 2-13/16
Relief pressure: 8-11 PSI, Anti-drain back valve
'14 Toyota Venza 3.5L 80K mi
TGMO 0W-20
PP 0W-20/Fram Ultra filter(spring/summer)
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470296
07/25/17 06:27 PM
07/25/17 06:27 PM
MD
AirgunSavant Offline
MD
I use them and others like the FL 910s etc. No issues.
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470313
07/25/17 06:53 PM
07/25/17 06:53 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I'm running the longer case CQ Blue 85516 (Wix made TG3600 equivalent) on the Kohler engine on my ZTR, there's plenty of room on my engine for this longer filter size.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470315
07/25/17 06:54 PM
07/25/17 06:54 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
I've had the Fram TG3614 on our 19hp Kohler for the last 10 hours of use. You're fine.
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470338
07/25/17 07:25 PM
07/25/17 07:25 PM
South Florida
bubbatime Online shocked
bubbatime  Online Shocked
South Florida
Not sure I would run a $9 Ultra over a $3 orange can...
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470349
07/25/17 07:39 PM
07/25/17 07:39 PM
Virginia
mattwithcats Offline
Virginia
Fram 3600 or equivalent if it fits, may be too long...
Fram 3614 or equivalent is just a little longer than the Kohler....
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470458
07/25/17 09:40 PM
07/25/17 09:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It won't, because the filter is about 10 times larger than it needs to be....
The bypass valve will never, ever open when run on an engine with such a tiny oil pump.
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470502
07/25/17 10:54 PM
07/25/17 10:54 PM
Golden Meadow, LA
mobilaltima Offline
mobilaltima  Offline
Golden Meadow, LA
We use Baldwin BT223 (3614 equivalent) on the Kohlers at work with no problem. But the proper substitute for the Kohler 52-050-02 is the Wix WL10068, made specifically for Kohlers.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Kohler 52-050-02 oil filiter cross reference [Re: JeepWJ19] #4470573
07/26/17 03:32 AM
07/26/17 03:32 AM
PA
PA
I just bought a club cadet Rzt S 42 zero turn with a Koehler 22hp 7000 Kt725. Is there enough room to fit the XG3614 since it much longer?
TGMO 0W-20
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470576
07/26/17 03:52 AM
07/26/17 03:52 AM
MD
MD
The Fleetguard LF 3826 is a short quality oil filter that fits the tight spaces.
I have pictures of one cut open on here.
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470599
07/26/17 05:31 AM
07/26/17 05:31 AM
wi
dave123 Offline
dave123  Offline
wi
What's wrong with OEM never heard or seen a issue currently running one right now yearly run and be cutting it in Open in October Ecore yes but see no problem with design.
Re: Kohler 52-050-02 oil filiter cross reference [Re: AirgunSavant] #4470603
07/26/17 05:54 AM
07/26/17 05:54 AM
PA
PA
Fram XG3614 height= 3.343"
http://www.fram.com/search-parts/Part-Detail/?PN=XG3614&CP=&PT=&OF=&MF=&OT=
Kohler sells three different sizes of oil filters:
(1) Small 2.25" (28-050-01-S)
(2) Medium 2.75" (12-050-01-S)
(3) Large 3.5" (52-050-02-S). The only difference between these three oil filters is the length, and thus the filtering capability. The smaller filters are made for applications where there is not adequate clearance for the larger filters
https://www.shopyourway.com/questions/1108268
Once, I get I need the ZTR mower, I need to determine what I have.
TGMO 0W-20
Re: Kohler 52-050-02 oil filiter cross reference [Re: Patrick0525] #4470614
07/26/17 06:25 AM
07/26/17 06:25 AM
PA
PA
Preliminarily, it looks like it is the 2.75" version
http://www.cubparts.com/oemparts#/Cub_Cadet/RZT-S42_KH_(17ARCBDS010)_(2017)/.Quick_Reference/NP100541-A/NP1005410013
Do you think there is enough clearance for the larger 3.5" version?
TGMO 0W-20
Re: Kohler 52-050-02 oil filiter cross reference [Re: dave123] #4470865
07/26/17 11:12 AM
07/26/17 11:12 AM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
Nothing wrong with OE filters except they're 3x the cost for 1/3 the filter.
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Kohler 52-050-02 oil filiter cross reference [Re: funflyer] #4470951
07/26/17 12:07 PM
07/26/17 12:07 PM
wi
dave123 Offline
dave123  Offline
wi
you have data that supports that statement that it's a 1/3 the filter or inferior in any way. I will be posting a UOA betting the filter is doing its job as good as any would. Me personally air intake is by far more important to keep in tip top shape.
