Originally Posted By: planeman223
Originally Posted By: PeterPolyol
Here's a thought. Maybe your Lexus, which is just 40 miles shy of 100,000, is losing it's smoothness to age and wear. Maybe it's reacting badly to operating conditions like pinging and it's retarding intake valve timing with throttle plate pegged open (the modern version of retarding ign timing), that would explain the 'throaty sound' and possibly the vibration.
IDK what the accelerator pedal mounting situation is on your lexus, but a modern Toyota Corolla seems to have it's pedals mounted to a piece of cardboard- press/release it, it sounds cheap as garbage. Both being DBW there is no direct mechanical connection between the drivetrain and the pedal, so it would be whatever the pedals mounted to that's possibly being excited by vibrations.
I sure hope not Pete because at 100,000 miles, this Toyota V8 is barely broken in.
On the LS400 line with the 1UZ-FE V8 engine, a fresh new set of motor mounts usually made the motor feel butter smooth again. But your issue really might be the oil; try a fill of the Valvoline because I've had that stuff make cars feel smooth as silk after an oil change. It's really weird how that works. Some placebo effect for sure but definitely some mechanical basis. People who are in tune with their motors can easily 'feel' when something is different, or feels off.
