Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
77 registered members (alarmguy, avi1777, Bailes1992, aquariuscsm, Astro_Guy, bcossa2001, 8 invisible), 1,069 guests, and 49 spiders.
Topics286,107
Posts4,902,709
Members67,563
Most Online2,967
Mar 10th, 2019
Honda gas cap questions #4469547
07/25/17 02:21 AM
07/25/17 02:21 AM
WatUpDoc
ltslimjim Offline OP
WatUpDoc
So, I did have that infamous "Check Fuel Cap" message once in my '07 Fit a while back, but it hasn't returned.
However, the nature of my question has to do with what is the definition of normal behavior for an OE Honda gas cap?
I did notice the gasket seemed to catch/release as if the gasket was binding a few months ago around this time. Obviously, I'm already suspecting the cap, but it has since then seemed to behave and I can tighten it to 2 or 3 clicks. The cap currently installed says "Tighten to Click" so I wasn't strictly following the 3 click rule often seen on aftermarket caps.
Sometimes when I go to re-fuel the cap seems to have loosened on it's own and requires minimal effort to unscrew. Is it not supposed to maintain the seal when you tighten it initially after refueling? Is that normal behavior? Am I not tightening it enough when going short of 3 clicks?
Thoughts appreciated and have a nice day. smile
Coffee2
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Honda gas cap questions [Re: ltslimjim] #4469569
07/25/17 03:35 AM
07/25/17 03:35 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You mean there's a 3 click rule? I always turn it to 3 clicks because I like hearing 3 clicks. grin
Re: Honda gas cap questions [Re: ltslimjim] #4469591
07/25/17 04:39 AM
07/25/17 04:39 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Do you refuel the gas tank while the engine is running?
Our friends '07 Honda Pilot requires(as do all vehicles) to turn off the engine while refueling, otherwise they would get a CEL. Apparently, they were in the practice of keeping their engine running while refueling their vehicle as they had often gotten that dreaded CEL...due to the gas cap.
Although I don't make it a habit of refueling with the engine running(I have done it), and I have never gotten a CEL after refueling my gas tank on any modern vehicle while keeping the engine running.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Honda gas cap questions [Re: ltslimjim] #4469595
07/25/17 04:42 AM
07/25/17 04:42 AM
PimTac Offline
PimTac  Offline
The new CR-V has no gas cap. That solves that problem.
Cannot see signatures any longer so it doesn’t matter.
Re: Honda gas cap questions [Re: PimTac] #4469606
07/25/17 05:07 AM
07/25/17 05:07 AM
ROCHESTER, NY
ROCHESTER, NY
Same with the HR-V and I believe that Honda is moving in this direction with their vehicles.
"Retired"
'15 Honda Civic LX
Re: Honda gas cap questions [Re: ltslimjim] #4469643
07/25/17 06:43 AM
07/25/17 06:43 AM
WatUpDoc
WatUpDoc
Oh, I definitely avoid running the engine during fuel ups. I just was curious if a cap that seemingly requires no effort to remove after tightening down a few days earlier was normal? In other words, if I tighten until it clicks should it not hold that seal and therefore require some sort of effort to remove it? Instead, it seems to just be resting as though I didn't tighten it enough at previous filll up. That's the best way I can describe it and, yes, I did have the CEL once for "Check Fuel Cap".
However, I've noticed since disconnecting the battery the other week; to clean the terminals, it hasn't passed all readiness tests yet. It's been at least 500 miles since. If I had a way to see what has yet to set I'd guess EVAP system at this rate. shrug
By the way, if I wound up replacing the cap are there any decent aftermarket caps these days? AC Delco, Gates?
Interesting note on newer models not having a cap.
Re: Honda gas cap questions [Re: ltslimjim] #4469649
07/25/17 06:46 AM
07/25/17 06:46 AM
ROCHESTER, NY
ROCHESTER, NY
Sure there are some decent aftermarket caps however with a HONDA vehicle, I would stay with the HONDA Cap!
"Retired"
'15 Honda Civic LX
Re: Honda gas cap questions [Re: Char Baby] #4469653
07/25/17 06:49 AM
07/25/17 06:49 AM
WatUpDoc
WatUpDoc
Ah, I suppose you're right. No experience needing to replace a gas cap before but it figures with a Honda.
Re: Honda gas cap questions [Re: ltslimjim] #4469665
07/25/17 07:03 AM
07/25/17 07:03 AM
ROCHESTER, NY
ROCHESTER, NY
I had to replace a Lexus gas cap early in the life of the Lexus(like 3 yrs)due to an EVAP code.
NONE of the tightening, tweaking of the gas cap did anything to get rid of the code including an aftermarket STANT cap but, replacing with an OE cap cured it just fine.
"Retired"
'15 Honda Civic LX
Re: Honda gas cap questions [Re: ltslimjim] #4469667
07/25/17 07:04 AM
07/25/17 07:04 AM
IL
GimmeTorq Offline
GimmeTorq  Offline
IL
I have a Stant gas cap in my 2010 Fit and I haven't had any issues. Replaced it because I wanted a key lock in the cap.
2017 Mazda CX-5 Touring AWD 2.5L
2014 Honda CTX700N
2012 Honda CR-V LX 2.4L
2010 Honda Fit 1.5L
2003 Honda Odyssey 3.5L - Traded-in
2002 Nissan Maxima 3.5L - Traded-in
Re: Honda gas cap questions [Re: ltslimjim] #4469733
07/25/17 08:08 AM
07/25/17 08:08 AM
Fernandina Beach FL
Dan55 Offline
Dan55  Offline
Fernandina Beach FL
The only time I had a problem with the gas cap is when the Fit was relatively new and someone else tightened the gas cap !
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Honda gas cap questions [Re: ltslimjim] #4469838
07/25/17 09:32 AM
07/25/17 09:32 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
One thing I've noticed on my F150, and then heard others say the same thing, is that when I would fill it up, I mean all the way to the top before heading on a long trip, I'd get the same issue and sometimes the engine would run rough for a few minutes. Don't know if Ford has some type of return line way up on the neck of the fill tube or some sort of vapor lock that the gets stuck in the system. So, as any other Ford owner had learned, don't fill the tank all the way up to the top.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: Honda gas cap questions [Re: ltslimjim] #4469891
07/25/17 10:21 AM
07/25/17 10:21 AM
MN
TmanP Offline
TmanP  Offline
MN
I'm thinking that if it loosens over the period of a few days, then it's not doing its job correctly. If you tighten it three clicks and it's tight at that point but then a week later it's loose, I'd replace the cap. And I'd go with a Honda OEM.
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Honda gas cap questions [Re: TmanP] #4470020
07/25/17 01:15 PM
07/25/17 01:15 PM
Nebraska
Duffyjr Online content
Duffyjr  Online Content
Nebraska
I had the CEL come on a few weeks ago and it turned out to be the gas cap. My mech told me to go home and clean the cap and neck really good and CEL has not returned how ever I did notice what you are, little or no effort at all to remove the cap. I have to admit I didn't pay any attention to it before so I'm not sure it didn't do that before. If it the CEL comes on again I'll get a new cap and be done with it.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Honda gas cap questions [Re: ltslimjim] #4470170
07/25/17 03:47 PM
07/25/17 03:47 PM
London, England
bigjl Offline
bigjl  Offline
London, England
Running a Honda Pilot when filling up can cause a MIL to illuminate.
Never heard of that before but interesting to know.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
