Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 6 invisible), 776 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
kohler ECV749 #4469480
07/24/17 10:40 PM
07/24/17 10:40 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
Gravely Commercial Pro Turn 260, 60 inch cut. It has a Kohler V-twin Model ECV749, 26.5 hp with 1,250 hours. I use it nearly everyday at work(thankfully have not had to sit in that old work truck at the gate lately) and it gets worked hard. I've been using 15W40 at 50-60 hr intervals with no problems, the one time I tried 20W50 it really did seem to lack power, so I've been using 15W40 since. We crank them up(we have two of them), let them idle for 2-3 minutes, then its full throttle till both fuel tanks run out, constantly bogging down in thick,wet grass shutting off the engines stopping in between. I looked up the oil specs for this engine, it shows 10W30 for 0 to 100 degrees, and straight 30 for 50 to 100 degrees. With 1,250 hrs on it, would it be safe to use straight 30, and would it maybe free up some power over the 15W40? Whatever I decide to go with, I'll start changing it at the recommended 100 hrs.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: kohler ECV749 [Re: mobilaltima] #4469503
07/24/17 11:12 PM
07/24/17 11:12 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I think 15w40 would be fine, 20w50 is overkill and might affect the hydraulic lifters
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: kohler ECV749 [Re: mobilaltima] #4469505
07/24/17 11:16 PM
07/24/17 11:16 PM
Houston, Texas
Houston, Texas
Thats pretty much what I'll do for the first start of the day. Start the mower and then I'll go and put the blower and weed whacker in the backyard. I don't always warm them up though, but most times I'm not really cutting thick grass so it's not like the engine is heavily loaded.
Re: kohler ECV749 [Re: mobilaltima] #4469620
07/25/17 05:43 AM
07/25/17 05:43 AM
MD
AirgunSavant Offline
MD
Kohler is all over the place with those graphs.
They list 20w50 for my 33 HP and suggest 10w30 is like a winter blend.
I think T6 Rotella 5w40 would be ideal for your commercial mower.
Great oil.
Re: kohler ECV749 [Re: mobilaltima] #4469755
07/25/17 08:29 AM
07/25/17 08:29 AM
MD
MD
This is one of the many graphs Kohler puts out
And they change rapidly
This is for the Command series
Re: kohler ECV749 [Re: mobilaltima] #4469757
07/25/17 08:30 AM
07/25/17 08:30 AM
Houston, Texas
Houston, Texas
A mower needs synthetic oil imo.
Re: kohler ECV749 [Re: motor_oil_madman] #4469764
07/25/17 08:39 AM
07/25/17 08:39 AM
MD
MD
I'm with that since it is a commercial machine and run hard plus at high temps
