2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
44 registered members (chiefcook, A_A_G, BlakeB, carlprop, burla, bdcardinal, 3 invisible), 1,212 guests, and 28 spiders.
Topics294,668
Posts5,064,166
Members69,303
Most Online3,532
Jul 30th, 2019
high quality tire inflator recommendation #4468765 07/24/17 09:42 AM
N
NissanMaxima Offline OP
N
Hi all:
I would like to get a nice tire inflator to avoid having to run down to gas stations or tire stores every time I need to add some air to my car tires. I was looking on Amazon but the majority seem cheaply made - some manufacturers don't even have websites! Ideally I would like to find a heavy duty, made in USA unit that will last, not blow fuses like many report on Amazon, and come with an additional AC adapter or at least battery adapter so I don't even have to worry about using my 12V accessory and potentially blowing fuses. The majority on Amazon are around the $40-50 USD mark but it would seem I should be able to find something to fits my requirements for $100 or so. One reviewer commented how he even plans to throw his away when it fails rather than send in for repair! Google searches of "heavy duty made in USA tire inflators" have turned up zilch.
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468779 07/24/17 09:53 AM
9
901Memphis Offline
9
Viair 00088 88P Portable Air Compressor https://www.amazon.com/dp/B005ASY23I
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: high quality tire inflator recommendation [Re: 901Memphis] #4468781 07/24/17 09:54 AM
R
Ramblejam Offline
R
Exactly what I have. With the direct-to-battery clips (instead of silly cigarette outlet connection), it does a great job.
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468784 07/24/17 09:55 AM
M
Miller88 Offline
M
I have had two of these
https://www.harborfreight.com/12v-100-psi-high-volume-air-compressor-69284.html
I did have to change the end so it clips onto the battery. I seem to be able to get 2 years of pretty constant use out of them. Every weekend I have used one or the other to inflate my oversized jeep tires, then someone else ends up borrowing it to inflate their tires too.
For the occasional flat, it would be perfect.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468792 07/24/17 09:58 AM
P
Panos Offline
P
Some time ago, Michelen had some quite robust ones.i happen to own one for 12 years. Not used much and the digital dial-cut off pressure sensor screen went kaboom when i inflated a 7 bar rated bicycle tire but the compressor still works fine after all those years
Ford Fiesta 1.6 '05 - Motul specific 913D/Motul Gear 300 180K+ Kms
Kawasaki Ninja 250R '08 - Shell Advance Ultra 4T 10w40 75K+ Kms
Honda CBR600F pc41 '14 - Motul 7100 10w30 25K+ Kms
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468819 07/24/17 10:32 AM
CT8 Offline
A Harbor freight compressor that is 110 volts can also be used . They are under $200.00
2015 F150 2.7
2018 F350 6.2
Re: high quality tire inflator recommendation [Re: CT8] #4468872 07/24/17 11:47 AM
K
kpatter Offline
K
had this one for 7 years; never failed me and would buy again right now..
https://www.amazon.com/Master-Flow-MF-10...er+flow+tsunami
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468886 07/24/17 12:10 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I use a bicycle pump... though it's a bit of a workout.
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468887 07/24/17 12:12 PM
B
bubbatime Offline
B
These harbor freight units will blow away any of those dinky 12v units. You SHOULD have a dedicated 110 unit for the house, and perhaps a smaller 12v unit for your trunk.
Use the 20% off coupons they have its $44. I have the older version that is 15 years old and it still works like new. I expect it to still be working in another 12 plus years.
https://www.harborfreight.com/air-tools/...ssor-61615.html
https://www.harborfreight.com/air-tools/...ssor-97080.html
19 Honda CRV 1.5T factory bulk
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
06 GMC Sierra SuperTech 10W30
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4468911 07/24/17 12:45 PM
SirTanon Offline
I've never been a fan of those tiny portable "plug in to your car's power point" type of inflators.. so I went a different route.
I already had a decent upright air compressor in my garage, so I just went to Harbor Freight and bought one of these:
If memory serves, it was only about $25 on sale.
I fill it up on my compressor at home, to about 95-100 PSI, and leave it in my trunk. I set up some magnets on the trunk liner and side, so the tank doesn't move when I'm driving.. just stays nice and snug in place until I need it, then a nice tug on it separates it from the magnets. 95PSI will easily pump up many low tires, and at least two flats.. and if it ever gets low, I just fill it back up at home. Never have to worry about whether my fuses will blow.
2013 Nissan Altima SV - 2.5 liter/CVT - 119,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 67,500mi
2010 Ford Fusion - 274,600mi
Re: high quality tire inflator recommendation [Re: 901Memphis] #4468942 07/24/17 01:19 PM
U
UncleDave Online Content
Online Content
U
2nd the viair products are quality units.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4469082 07/24/17 04:30 PM
N
NStuart Offline
N
Although I've upgraded to a much larger compressor I've had my Harbor Freight for 6 or 7 years running very very hard and now I've actually turned it up to a higher output, I also have it running to another tank the same size about 30 gallons feeding that tank, the reason I did that is because the Harbor Freight only has a quarter inch air Outlet and when you pull the trigger on a large gun or tool you could hear the air rushing back into the line. And when I say a big gun like a Matco 1/2 inch impact, it is a monster now with the other tank however I barely use it because I bought a service truck compressor and I Crank It Up every time I need air to keep the motor in good condition
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4469096 07/24/17 04:42 PM
L
Langanobob Offline
L
Another vote for Viair. They've been around for many years and are the compressor of choice for serious off-roaders.
I'm probably not going to make many friends around here, but Harbor Freight gives me a headache.
Re: high quality tire inflator recommendation [Re: Kestas] #4469471 07/24/17 10:26 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
+1
Re: high quality tire inflator recommendation [Re: NissanMaxima] #4469964 07/25/17 12:19 PM
V
Vikas Offline
V
Is there no small footprint *good quality* reasonably priced 110V tire pump?
