Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
24 registered members (bmod305, Black_Thunder, AnthemBassMan, bfleeman, Brad_C, 555, 2 invisible), 489 guests, and 68 spiders.
Topics286,263
Posts4,905,495
Members67,589
Most Online2,967
Mar 10th, 2019
you shouldn't allow an acetylene tank to freeze? #4469416
07/24/17 09:29 PM
07/24/17 09:29 PM
Chicago, IL
tomcat27 Offline OP
tomcat27  Offline OP
Chicago, IL
I am looking at purchasing an oxy/acetylene setup and was reading safety info on the like. I was surprised that it said to not store an acetylene tank below freezing - that the acetone in the tank could separate and theoretically be unsafe. is this true? I certainly don't want to bring the tank inside in the winter!
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4469426
07/24/17 09:45 PM
07/24/17 09:45 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There shouldn't be ANY water in there, and acetone doesn't freeze (as far as I know)
When I lived in North Dakota, the Acety tanks were in freezing temps all the time.
Re: you shouldn't allow an acetylene tank to freeze? [Re: Linctex] #4469431
07/24/17 09:50 PM
07/24/17 09:50 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted By: Linctex
There shouldn't be ANY water in there, and acetone doesn't freeze (as far as I know) ...
Neither does acetylene, as far as I know.
2011 Toyota Prius now at 97K
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4469440
07/24/17 09:58 PM
07/24/17 09:58 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Acetone that absorbs the gas in the cylinder has a very low freeze point, -93 C to start freezing according to google I hope to never see those kind of outdoor temps. Greater danger is to get the gas to a pressure above 15 lbs or around copper
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: you shouldn't allow an acetylene tank to freeze? [Re: bioburner] #4469474
07/24/17 10:33 PM
07/24/17 10:33 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I thought it was 20. I know at my welding school they had it in the danger level on the gauge and i think i turned it down. Nothing ever happened. I forgot what they said would happen, but I think it was actually propylene due to cost and safety.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: you shouldn't allow an acetylene tank to freeze? [Re: bioburner] #4469506
07/24/17 11:16 PM
07/24/17 11:16 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
copper?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: you shouldn't allow an acetylene tank to freeze? [Re: Chris142] #4469554
07/25/17 02:57 AM
07/25/17 02:57 AM
Australia
Ducman Offline
Ducman  Offline
Australia
copper?
Copper.
That's a new one on me.
They never taught us that in college.
Three things come to my mind that we were taught.
1, Don't lay the cylinder down as it will draw off the Acetone.
2, Don't draw it off at too high a volume as it will also draw off Acetone.
3, Don't use it at a greater depth than 1 metre when submerged under water.
Nothing about freezing or Copper.
Re: you shouldn't allow an acetylene tank to freeze? [Re: Ducman] #4469578
07/25/17 04:02 AM
07/25/17 04:02 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: Ducman
Copper.
They didn't mention anything about setting the pressure regulator to 5 psi did they ?
Re: you shouldn't allow an acetylene tank to freeze? [Re: Merkava_4] #4469629
07/25/17 06:13 AM
07/25/17 06:13 AM
Australia
Ducman Offline
Ducman  Offline
Australia
Copper.
It doesn't ring a bell.
We don't work in PSI here anyway, that is unless one is inflating tyres or working with compressed air in general.
Besides where I did my time we never used Acetylene as it's best suited for welding due to the higher temperature it burns at so we only used it at college for Oxy Welding and a very little bit of cutting. Come to think of it the only time one would be drawing Acetylene off at or near maximum would be pre heating and or Oxy welding Cast iron by Brazing or Fusion welding
In our workplace all our work was exclusively cutting with Propane which was more economical for high speed(at the time). No Oxy welding of any description.
We often found that welding Cast iron was best done with Cast craft electrodes or Stainless steel electrodes.
The dedicated Acetylene gas regulators have a red zone to indicate the maximum limit one could draw it off at so it was safe. In that case there was no need to be concerned about specific values.
The equation changed drastically when Propane became more expensive.
Then a little later on everybody was changing over to Plasma cutting anyway which had a different set of issues.
Later it changed to HD Plasma cutting for some applications where one required a better finished cut edge.
Now days it's Laser cutting for the thinner stuff, or abrasive water cutting for the really thin stuff where no distortion is required and clients have very deep pockets.
At the end of the day, I'm well and truly out of date.
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4469637
07/25/17 06:26 AM
07/25/17 06:26 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Everything freezes at some point. However that may not happen on earth naturally. Lowest temp ever recorded was -89.2C and that is above the freezing point of acetone.
2015 Ford F250 w/Powerstroke
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4469689
07/25/17 07:26 AM
07/25/17 07:26 AM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
My acetylene tank has been stored in my unheated backyard shed for the last thirty five years and there has been zero issues with freezing. The tank always works when I need it, even in winter.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4470252
07/25/17 05:31 PM
07/25/17 05:31 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Well the likelihood of the acetylene tanks freezing in the real world is pretty much zero.
Look up copper reacting with acetylene. That's why one never sees the gas plumbed around with copper pipe that and the fact it should never go above 15 psi. Look at the gauge set for it and the red zone is at 15 plus.
My father wore two hats, one was a master welder and the other was for blasting and taught explosives in the military. One way or the other its going to go down:)
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4470271
07/25/17 05:51 PM
07/25/17 05:51 PM
Florida
laserred96gt Offline
Florida
Never heard anything about freezing when I went to school ( Florida ), instructors did mention not to lay them down, 5 psi on acetylene 20 on oxygen for HVAC copper soldering.
2017 4Runner Limited, 44k
04 E-150, 4.6, 231K, Synblend 5w20.
11 Camry 2.5, 63K, PU 5w20.
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4471910
07/27/17 11:54 AM
07/27/17 11:54 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I worked in a machine shop for 24 years and all of our gas (including acetylene) was stored in an unheated shed, sometimes in temps down to -10F. Never had a problem. The gas company was the ones that put the gas in our shed. However, we had to store the oxy in a different shed (unheated) for safety reasons. We got hit by OSHA for that one.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: you shouldn't allow an acetylene tank to freeze? [Re: tomcat27] #4473163
07/28/17 03:58 PM
07/28/17 03:58 PM
CT
CrAlt Offline
CrAlt  Offline
CT
Are you planning on welding with it? If not then I would look in to oxy/propane. For cutting, heating, brazing it works just fine with less hassle. Can use cheap BBQ tanks.
'16 Wrangler JK PYB 5w20 / MO 349
'77 Corvette JG HR2 10w30 / AC PF454
'83 Trans-Am JG HR2 10w30 / AC PF454
'91 Dodge D150 QSGB 10w40 / AC PF13
