Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Walmart Oil Change?
by Talent_Keyhole - 01/18/20 12:50 AM
Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
2EHA, jonnyb433, kzbd, 54Robert, CPA1989
70464 Registered Users
105 registered members (4WD, 53' Stude, 14Accent, 55hambone, 54Robert, 3 invisible), 2,018 guests, and 15 spiders.
Topics300,274
Posts5,172,171
Members70,464
Most Online3,728
Jan 11th, 2020
Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k #4469338 07/24/17 07:27 PM
SubieRubyRoo Offline OP
Ok so here's my oil report from my 06 Odyssey, first run on PPE 0w-40, Microgreen 201-7 filter. Oil looks darn near brand new, TBN was still 6.0 at 7.65k miles with zero top-up! Tell me if I'm wrong, but this oil combo looks like it may last 15-20k?!? My other UOAs on the sheet looked nowhere near this good with slightly less mileage... first sample was unknown (purchased van with this fill), 2nd sample was old PP 5w-20. I went with the PPE because of higher HTHS with a lot of hot summer driving. I'm super impressed so far... opinions?
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469365 07/24/17 07:45 PM
P
pbm Online Content
Online Content
P
It doesn't seem that the 40 weight hurt anything (in a motor spec'd for 20 weight) and it certainly seems robust. 10K would seem easy to do on this oil in this application.
PS: I just realized you're running a Microgreen oil filter....you could probably change the filter at 10K and run another 5K (on the same oil) using a cheap oil filter.
'Journalism is Dead'
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469367 07/24/17 07:46 PM
T
Trav Offline
T
Best you run 0w20 because that's what the engineers that built your van designed it for.
So much for that nonsense. LOL I have been posting for years how well the 0w40 Euro oils do in these engines.
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469368 07/24/17 07:46 PM
Seventh Offline
Doesn't get much better than that.
I'd be stretching that OCI for sure if it were mine.
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469373 07/24/17 07:49 PM
Dyusik Offline
15 to 20k is Euro oci, my old e39 had some bars left when I dumped oil at 17k. I bet that Honda can run 20k with even better (adjusted for mileage) results. Thanks for sharing.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k STP SYNHM 10w30, WIX 57047
18 RAM 3500 8k DELO SDE15w40, DBL7349
96 Cherokee
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469388 07/24/17 07:58 PM
Yeah I am really impressed so far with it. I didn't dump the oil, this sample was out of the Microgreen filter. I was hoping it would look ok, but this was phenomenal news. I will do another UOA from the filter at 15-16k and see how it compares. Even gas mileage hasn't suffered much- just did an 850-mile, 13.5 hour one-way trip thru the Alleghenies with the air on, cruise at 75, 4 people and the entire area behind the seats full of luggage... and still knocked down 24.2mpg (calculated). Last year a trip from Phoenix to Indiana with two people and no luggage returned about 25.1...
If these wear rates keep up, I probably won't drain until TBN gets down around 1.5. I know DNewton has said several times with wear rates at basically 1 ppm Fe/ 1k Miles, LET IT RIDE! 😁
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469396 07/24/17 08:06 PM
dblshock Offline
might degrade quickly as it ages..stay on it.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: pbm] #4469398 07/24/17 08:06 PM
PBM- I am just changing the filter but replaced it with another Microgreen. I do have a few Bosch D+, but the Microgreen promises piqued my interest. I only dropped at 7650 because this was my first time with this oil and filter, and knew I had a 2k+ mile trip coming up this week. I wanted to know what was going on in the dump before rushing out foolishly. This time, my top up was all Lubegard Bio/Tech (about 4oz... a filter full) and next filter change will likely be PPE 0w-40 since it will likely be dumped shortly after that. Since I already have a UOA at 7.6k, the next sample will give me unbiased data on exactly what the Lubegard does!
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: dblshock] #4469403 07/24/17 08:11 PM
Dblshock- I will keep an eye on it, but most of what I have seen is TBN normally drops quickly at the start of service and then tapers off slowly... the other thing is this is an ACEA A3/B3 oil specced for long term use in very demanding applications.. so I am hopefully but will be cautious. I'm trying to push the envelope to give the board some good info! Thanks!
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469414 07/24/17 08:25 PM
dblshock Offline
My 1.5 did 44.8 mpg. (meter) 240mi. Sunday at least 5 pedal to metal passes, 170 mi. of I-system 75-85 air on and over sized tires...hardly an engine struggling with the extra lubrication films.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469418 07/24/17 08:29 PM
I'm not quite sure what you meant to share there... the Civic is a totally different machine. My point was that for a 3.5L brick with a running weight of around 54-5500lbs, I was pretty pleased with 24mpg actual at 75 in the mountains with the air on.
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469423 07/24/17 08:42 PM
dblshock Offline
Sharing the xW-40 grade success.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469449 07/24/17 09:06 PM
O
oil_film_movies Offline
O
Euro Pennz 0w40 is great oil, yet it looks like a Castrol Edge Extended Performance 5w30 gold jug is best for that rig. Or M1 EP. 5w30 has more viscosity but not that much more so you don't lose as much power and MPG. 50% excessive HTHS in the 40 over a 20, 15% of power loss is engine friction, of which half of that is hydrodynamic (viscosity surfing), so about 7% of the 50% is 3% MPG and power loss. Most might not notice it. Using a dexos1 5w30 cuts it down to around a 1.5% MPG & power loss.
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: SubieRubyRoo] #4469456 07/24/17 09:12 PM
dblshock Offline
-3% is a very reasonable number.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: Pennzoil Plat Euro 0w-40, 06 Odyssey, 7.6k [Re: dblshock] #4469497 07/24/17 10:03 PM
69GTX Offline
Shannows's fleet taxi data UOA's showed that it was more than just TBN that decided when an oil was done. In those studies the TAN crossing the TBN often triggered the end of the effective OCI. And in most cases that occurred at a TBN of around 4.0 to 4.5 on longer OCI's.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
