Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
89 registered (Aero540T, Audios, bdcardinal, Atesz792, 77GrandPrix, Astro14, 6 invisible), 1663 Guests and 39 Spiders online.
65262 Members
67 Forums
285524 Topics
#4469122 - 07/24/17 05:10 PM Pressure gauge fail
redbone3 Offline
Loc: Reno, NV
I just received a 15 PSIG pressure gauge (China) from ebay. I'm going to use it to monitor the pressure when I pressurize the fuel tank to look for leaks (soapy water method). This test is done at 2 PSIG or less. Knowing the reliability of pressure gauges in general, I checked it's accuracy before using it. The needle didn't move off the peg until 4.5 PSI!! It read 2 PSI with 6.5 PSI was applied. That would likely have damaged my fuel tank. So, a word to the wise: bourdon tube pressure gauges are OFTEN way out of tolerance from the factory. I have found this to be true for both those of US and China origin. Fortunately, repositioning the needle put mine on the money.
Edited by redbone3 (07/24/17 05:10 PM)
2014 Passat Wolfsburg, 1995 Miata.
#4469222 - 07/24/17 06:46 PM Re: Pressure gauge fail [Re: redbone3]
Linctex Offline
Loc: Waco, TX
The closer the "sweep" of the needle is to 360 degrees, the more accurate it usually is.
Good on you for checking it first.
#4469306 - 07/24/17 08:04 PM Re: Pressure gauge fail [Re: redbone3]
Fsharp Offline
Loc: Kentucky
Good to check, I doubt 6.5 PIS would have done too much though. I put 30-40 psi in a tank to de-crumple it. Worked, but my tanks a little rounder now than I would like.
#4469337 - 07/24/17 08:27 PM Re: Pressure gauge fail [Re: redbone3]
L_Sludger Offline
Loc: Ohio
I think that out of 100 buyers of those gauges, maybe 2 or 3 actually check their accuracy before first use!
too many cars and oil combinations to list in 150 characters or less
#4469351 - 07/24/17 08:36 PM Re: Pressure gauge fail [Re: redbone3]
Silk Offline
Loc: New Zealand
I have a manometer, but prefer to use vacuum gauges to set the carbs on my bike. Todays job, so calibrated my gauges, different ages and brands, both US brands. So long as the give the same reading they are good enough for the job.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4469405 - 07/24/17 09:15 PM Re: Pressure gauge fail [Re: Linctex]
redbone3 Offline
Loc: Reno, NV
Actually, it's more complicated than that. The most common gauge a mechanic is going to see is a grade B. Grade B gauges are 2% of full scale in the central 50% of the range and 3% of full scale in the first and last 25% of scale. The important part to understand is the full scale designation. For example a 100 PSIG class B gauge would be 3 psi at 10 psig (30% of reading), 2 psi at 50 psi (4% of reading), and 3 psi at 100 psi (3% of reading). If the gauge had just been professionally adjusted it would have been adjusted at midscale to nominal, and would be most accurate there. Unless you have a gauge calibrated, with data, it's a [censored].
Edited by redbone3 (07/24/17 09:16 PM)
