oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
95 registered members (28oz, Aero540T, anndel, 53' Stude, Aichiguy, 97f150, 15 invisible), 1,891 guests, and 39 spiders.
Topics295,018
Posts4,926,128
Members66,666
Most Online2,553
Oct 27th, 2018
Manual cranking v electronic" remote" start cranking #4468804
07/24/17 09:11 AM
07/24/17 09:11 AM
il usa
merconvvv Offline OP
il usa
I am thinking of a getting a remote start for the 1999 expedition.
Are there any downsides to getting a remote start. Can it leave you stranded on a long trip whereas one cannot even start the car with manual cranking.
How many seconds does the remote start crank the engine? Can the remote start cause more wear than an experienced manual cranker:)
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4468827
07/24/17 09:43 AM
07/24/17 09:43 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
My 2006 Mazda 3 has what you can call manual cranking. It will crank as long as I hold the key in the start position, if that's what you mean.
In any case, I installed the OEM remote starter kit when the car was two-three months old and it has worked flawlessly ever since. I use it daily during winter.
Some of the aftermarket units can have either the crank times adjusted, or read the tachometer signal for cranking times. There is nothing to worry about as long as the quality of installation is good.
2015 Dodge Grand Caravan-27k miles.
2006 Mazda 3-163k miles
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4468849
07/24/17 10:02 AM
07/24/17 10:02 AM
il usa
il usa
Thanks good to hear.
Yes by manual cranking i mean with the key like in the 1960's.:)
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4468860
07/24/17 10:29 AM
07/24/17 10:29 AM
California
nthach Online content
nthach  Online Content
California
Most remote starts will run the starter until it sees the engine is running above cranking via tach signal(tapped from the coil or an injector wire) or a "emulated tach" via voltage sense, if the charging system is above 12.6V it will consider that as running.
The units themselves are fairly reliable - DEI has most of the market via Viper/Clifford/Python. The only trouble spots are interfacing with the OEM wiring - especially the engine side and power connections. You might also need a immobilizer bypass as well.
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4468895
07/24/17 11:17 AM
07/24/17 11:17 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
An improper installation can cause all kinds of wonky electrical gremlins. Be careful.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4468952
07/24/17 12:30 PM
07/24/17 12:30 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
I wouldn't do it. I'd never splice into an oem electrical system for any reason.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4469195
07/24/17 05:25 PM
07/24/17 05:25 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Turning a key isn't much more "manual" than pressing a button on a remote.
Hand cranking is a bit more "manual" and allows you to start the engine without using the starter motor, which can be useful, though (unless its a diesel) or is fitted with a dynamo, you'll still need enough juice in the battery to activate the coils in the alternator to provide power to the ignition. My Lada had hand cranking, also the 2CV, but anything recent would need it retro-fitted, which'd probably be quite difficult.
You can get spring-powered starter motors that you wind up, and others powered by compressed air, though mostly intended for big commercials, marine engines and plant. Might be difficult/impossible to find room for one in a car and they are probably quite expensive.
Remote starting could be useful if you are on a witness protection programme, and had reason to believe your car might be wired for bangs. Also if you don't like getting into a cold car.
I hired a scooter here that had a remote starter. [censored]-on-a-bull useless, unless there are a commercially significant number of ex-Mafiosi riding hired scooters around Taiwan.
Re: Manual cranking v electronic" remote" start cranking [Re: Ducked] #4469393
07/24/17 08:04 PM
07/24/17 08:04 PM
il usa
il usa
By turning the key i can crank it forever or stop when i think the motor has started. Whereas with remote i think you just press the button and computer does the rest ?
Re: Manual cranking v electronic" remote" start cranking [Re: aquariuscsm] #4469959
07/25/17 11:12 AM
07/25/17 11:12 AM
California
California
You can buy a T-harness that will interface with the OEM connectors - no butt splices, T-taps or soldering required. You still need to get your tach signal and bypass the immobilizer - there are inferfaces made by DEI(Xpresskit) or iDatalink that will read off the serial data bus for the immobilizer but it does involve splicing into the OEM wiring and that's where things can go wrong.
I've installed an alarm in a friend's old Honda using an iDatalink interface to tie into the car's CAN bus. It worked, but I did see a few body control related DTCs when I hooked up the HDS to it. I still think it's better than tapping into the car's doorlock wiring but I don't advise alarms for new cars anymore.
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4470006
07/25/17 12:05 PM
07/25/17 12:05 PM
BC, Canada
userfriendly Offline
BC, Canada
Two 20th century inventions; giving women the vote and electric starters.
Re: Manual cranking v electronic" remote" start cranking [Re: nthach] #4473411
07/28/17 08:15 PM
07/28/17 08:15 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Seems like a lot of hassle for a rather marginal advantage.
Re: Manual cranking v electronic" remote" start cranking [Re: merconvvv] #4473445
07/28/17 08:48 PM
07/28/17 08:48 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
I have regretted almost every aftermarket alarm I have ever had installed.
Re: Manual cranking v electronic" remote" start cranking [Re: Ducked] #4476486
08/01/17 11:32 AM
08/01/17 11:32 AM
California
California
Now with the OEMs offering telematics, doesn't make sense either. If I had to do it all over again, I'd install an OEM remote start that plugs into the body control modules and it requires a PCM reflash.
The aftermarket integration kits still need the vehicle's wiring to be altered.
