Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Yet another overfill question... #4468764
07/24/17 09:41 AM
07/24/17 09:41 AM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Backstory: Normally, I do my own oil changes. I never have any reason to contemplate damage caused by overfill because I know how much goes into my cars. However, today I needed to take it to my buddy at the dealership who did the oil change for free (I brought his tech the oil and filter) because we are getting ready to go on vacation tomorrow and I don't have the time or desire to break out the ramps and do an oil change in 100 degree heat.
My 2017 Elantra 2.0L takes 4.23 quarts of oil with drain and filter change. I supplied the tech 5 quarts and a filter for the job. Well, he dumped in all 5 quarts, overfilling by 3/4 quarts. I did a search on here for overfill and I feel like this is right in the middle of "safe to run" and "too much". It seems like a 1/2 quart is just fine and a full quart is too much. My question is, do you think this extra 3/4 quarts do any damage? I didn't catch it until I got home when I thought it was weird that I didn't get my remaining quart back.
Re: Yet another overfill question... [Re: JustN89] #4468782
07/24/17 09:55 AM
07/24/17 09:55 AM
Greece
Panos Online content
Panos  Online Content
Greece
You could just unscrew the oil filter and drain it, then screw it back.I guess there would be no sealing problem. If you worry about sealing just screw a new oil filter. Should get about half a quart out of the engine.
Alternatively just crack the drain bolt open and let some go then screw again.
Messy, but I would do it.
I would probably go with the second option.
Ford fiesta 1.6 mk6 Motul specific 913D/Motul Gear 300
Kawasaki ninja 250r Shell Advance Ultra 4T 10w40
Honda cbr600f Pc41 Motul 7100 10w30
Re: Yet another overfill question... [Re: JustN89] #4468789
07/24/17 09:58 AM
07/24/17 09:58 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
There are extractor pumps at parts stores or Harbor Freight for $10-15 with a tube you put down the dipstick tube.
I'd work at getting the level correct. Believe the spec.
Re: Yet another overfill question... [Re: JustN89] #4468793
07/24/17 09:59 AM
07/24/17 09:59 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Is the oil filter easy to get to ?
How much can you get rid off from the oil filter ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Yet another overfill question... [Re: JustN89] #4468794
07/24/17 10:02 AM
07/24/17 10:02 AM
NY
demarpaint Offline
demarpaint  Offline
NY
A half quart over for a small sump like that would be my limit. There were three suggestions for getting the excess oil out, pick one you'd be comfortable doing and get some of the oil out. I have an extractor, so that's what I'd do. I have also removed and dumped filters and reused them w/o issue, but in your case I think you'd have to drain it, run the engine, and drain it again. With a big trip looming, I'd probably pass on that approach.
God Bless Our Troops
Re: Yet another overfill question... [Re: JustN89] #4468810
07/24/17 10:17 AM
07/24/17 10:17 AM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
I don't have an extractor, but the dealership is less than 10 miles away, so I'll stop in and get it drained. Thanks for the advice!
Re: Yet another overfill question... [Re: JustN89] #4468821
07/24/17 10:37 AM
07/24/17 10:37 AM
Canada
i_hate_autofraud Offline
Canada
On the dipstick is it 1/2" over the top of more then 1"?
Usually the worst that can happen is the oil is beat into a foam and the
oil pressure light turns on, then some oil needs to be drained.
Or the oil spits out into the breather or into the air intake via
crankcase ventalation lines, then drain some oil.
But you don't report an oil light, so you may be fine.
How far have you driven since the oil change?
Re: Yet another overfill question... [Re: JustN89] #4468825
07/24/17 10:42 AM
07/24/17 10:42 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Smart move. Then check the level yourself to confirm they got it right.
Re: Yet another overfill question... [Re: JustN89] #4468842
07/24/17 10:55 AM
07/24/17 10:55 AM
US
TheOilWizard Offline
US
Sounds like someone needs additional training. Ask your buddy what the techs qualifications are. Dumping all 5 quarts in (if true) is completely ridiculous.
Re: Yet another overfill question... [Re: JustN89] #4468856
07/24/17 11:21 AM
07/24/17 11:21 AM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Oil change was just this morning, so right at 10 miles on it. It will be roughly 20 miles total by the time I can get it back to the dealership.
Yeah, I agree. Dumping all 5 in is ridiculous. I'd say something about it, but I used to work there and I'm good friends with a lot of those folks. It's also not a Hyundai dealership, however, it's not hard to look up what the manual calls for.
I don't know how far above the dipstick it is, I'd say probably a 1/3 of an inch. However, I know exactly how much is in it since I gave them 5 quarts and he said he put all 5 in.
Re: Yet another overfill question... [Re: JustN89] #4468859
07/24/17 11:26 AM
07/24/17 11:26 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I would have given him 4qts and topped it off - They never seem to get this right. I just checked the oil level on my wife's Subaru this past Sunday - that just had a 150 dollar oil change at the Subaru dealer - and it's about 1+1/2 inches above the full mark COLD! ;(
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Yet another overfill question... [Re: ARCOgraphite] #4468866
07/24/17 11:38 AM
07/24/17 11:38 AM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
That's actually a really good idea, and I'll have to remember to do that next time (should there have to be a next time - I remember why I like to do these things myself).
Re: Yet another overfill question... [Re: ARCOgraphite] #4468893
07/24/17 12:17 PM
07/24/17 12:17 PM
Vermont
John_VT Offline
John_VT  Offline
Vermont
I - that just had a 150 dollar oil change at the Subaru dealer - and it's about 1+1/2 inches above the full mark COLD! ;(
I had to tell our dealer not to overfill ours the couple times they changed the oil. They would have it about a 1/4" high on dip stick. If my car was overfilled by an inch and half I'd be back and they would be making it right. The last time they changed the oil they left the fill cap loose-off. What a mess that made 😡.
14 crosstrek 5 spd.Milesyn sxr 0-20
98 k1500 suburban 5.7L.Milesyn sb 5-30
03 Pontiac Montana. St 5-30
01 mojave,86 trx350,2-110cc atv's
Re: Yet another overfill question... [Re: John_VT] #4468999
07/24/17 02:26 PM
07/24/17 02:26 PM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
When I take the Buick in I always dump a half quart out of the jug to make it faster for him and in case my buddy isn't there I don't have to worry about the new guy over filling.
I think your smart getting some drained out since you will be on vacation.
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: Yet another overfill question... [Re: JustN89] #4469034
07/24/17 03:36 PM
07/24/17 03:36 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Yeah I'd be uncomfortable with a .75 qt overfill, especially on a road trip where there's a risk of oil aeration.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
