Ranger door handle
Golden Meadow, LA
on my '01 Ranger, there is a rod that connects from the inside, to the outside door handle that allows you to open the door. it then connects to the latch through a hole with a bushing that the rod goes through. It must be wore out as the rod keeps coming out and i cant open the door from the outside. Does anyone know if I can buy the bushing by itself or will I need to buy a whole new latch? I've looked online and in parts stores with no success for the bushing.
You would probably have the best luck going through a Mazda dealer. They keep aftermarket parts much longer than their Ford counterparts. That's basically my only good source for NOS products on obsolete shared Ford/Mazda platforms.
D2VY-65219A38-B is the bushing that goes into the handle.
F57Z-1021952-B is the bushing/retainer on the LH latch.
F57Z-1021952-A is the bushing/retainer on the RH latch.
